Old 06-09-2016, 05:12 PM   #1
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Question Has anyone ever tried rejuvenating a rubber torsion axle?
Seems like you could jack the trailer up to unload the wheel, drill a couple holes in the flat sides of the axle near the ends, squirt in half a tube of RTV silicone, and wait like 24 hours until it sets.
I'm sure someone has tried it; I'm just interested in what happened...
Old 06-09-2016, 05:23 PM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
I seriously doubt that would make a difference. And there are hundreds of old axles that have been removed. (if not thousands)
It isn't about the surface of the rubber which is all you would reach by spraying into a hole in the axle. AND the rubber over fills the metal tube. So drilling a hole might have rubber squeezing to get out the hole.
The longer the rubber rods the more weight it can handle. So the rubber rods come in different lengths and are nearer to the outside of the axles.
>>>>>>>Action
Old 06-09-2016, 05:35 PM   #3
drboyd's Avatar
1978 25' Tradewind
I was thinking that if the trailer is lower, then it's because the rubber rods are permanently squished and hardened. The RTV would fill the space that used to be occupied by the now smaller rods.
Old 06-09-2016, 05:50 PM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
There is no space inside the axle housing.
The rubber has hardened not contracted.
>>>>>>>>>>Action
Old 06-09-2016, 05:50 PM   #5
1991 25' Excella
Stanfield , Oregon
You could squirt all the rtv you want in there. But the rubber wont magicly renew itself and there's little to no room anyways.
SpletKay06 is offline   Reply With Quote
Old 06-09-2016, 06:23 PM   #6
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Conventional brake fluid will rejuvinate old rubber....temporarially
Old 06-09-2016, 07:00 PM   #7
eubank's Avatar
Airstream - Other
Bosque Farms , New Mexico
If you use silicone brake fluid, it may cause the rubber to swell. But the stuff makes pretty good shoe polish (do not ask; another MG story). And, needing a lot of it, you will probably be better off financially by buying new axles.
Lynn
eubank is online now   Reply With Quote
Old 06-10-2016, 11:07 AM   #8
1963 22' Safari
Vail , Arizona
Call Inland RV and talk to Andy Rogozinski -- 800-877-7311. He is an expert on axles. I think the answer is that you can't rejuvenate one.
morganobenn is offline   Reply With Quote
Old 06-10-2016, 11:41 AM   #9
Thalweg's Avatar
1962 24' Tradewind
Buffalo , Wyoming
I've often wondered if heat would rejuvenate the rubber. It will with some rubbers an plastics. I replaced my axle a couple of years ago, and my old one is still out in the yard, waiting to go to the recycler. I'm tempted to try it just to see what would happen. If only I could figure out a way to heat it without burning the rubber. The wife would probably be unhappy if I tried shoving it in the oven.
Thalweg is offline   Reply With Quote
Old 06-10-2016, 12:35 PM   #10
Native143's Avatar
2013 20' Flying Cloud
2014 16' Sport
2019 23' Flying Cloud
Dunedin , Florida
I have just dealt with an axle. And getting lessons about it. Yes the rubber bushings inside the axle compress, and do not rejuvenate. As they compress the axle bends. Speak with Billy at American Frame and Axle 813-620-9151. He's very helpful.
Native143 is offline   Reply With Quote
Old 06-10-2016, 02:26 PM   #11
mcomeaux's Avatar
2016 27' Flying Cloud
Sunriver , Oregon
No way....
mcomeaux is offline   Reply With Quote
Old 06-10-2016, 03:59 PM   #12
altnbndr's Avatar
1967 17' Caravel
1968 22' Safari
Sacramento , California
Images: 11
Dexter axle cut-away
After changing my axle I had to see the "mysterious" inside of the old one.
ID:	264186   Click image for larger version
altnbndr is offline   Reply With Quote
Old 06-10-2016, 05:01 PM   #13
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The four rubber rods in that axle are what create the spring! The longer the rod the higher the load rating.
>>>>>>>>>>>>Action
Old 06-10-2016, 07:51 PM   #14
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Spring rate
I have never measured the spring rate for my trailers. If the rubber compound Airstream/Henchel/Dexter uses is the same for all axles and only the length is increased to increase the load capacity, the axle's spring rate will also increase. That means, the higher the load capacity, the more severe the ride.
Old 06-10-2016, 11:10 PM   #15
drboyd's Avatar
1978 25' Tradewind
Here's what I mean about drilling a hole in the side of the axle tube and filling some of the voids with RTV.....
Much thanks to altnbndr for the excellent photos....
Name:	rubber axle w rtv.jpg
Old 06-11-2016, 06:56 AM   #16
1963 22' Safari
Vail , Arizona
It is a torsion spring axle. The square-ish rod is the torsion spring. The rubber 'rods' are the internal dampers. The rubber rods are inserted at the time of manufacture by freezing them in liquid nitrogen to make them shrink and become rigid for insertion. Over time, the rubber will harden and the torsion suspension takes a permanent set thus requiring replacement.
Old 06-11-2016, 08:10 AM   #17
Dingo Girl's Avatar
1967 17' Caravel
Oak Creek , Colorado
Thanks for posting. I always wondered.
Dingo Girl is offline   Reply With Quote
Has anyone ever seen a broken axle mounting plate on an AS? Hummer Axles 26 11-28-2012 05:51 AM
Has anyone tried this flooring? wannaroam Floor Finishes 164 10-18-2012 08:15 AM
Has anyone tried Fort Getty Campground in Rhode Island? Eckhart On The Road... 6 12-07-2010 06:17 PM
Anyone tried diamond or coin grip rubber flooring? tvanwave Floor Finishes 6 11-27-2010 11:43 AM
has anyone tried to finance and Old A/S lately? volvophile Financing 16 11-20-2005 11:17 AM
