09-19-2010, 12:30 PM
ground clearance
Sometime ago I heard about a spacer that goes between the frame and axles giving more ground clearance. Anybody got any info on this? thanx Ziffell
09-19-2010, 12:50 PM
Corona
Please don't believe to much of what you "heard".
If you use spacers, if not done correctly, it will mess up the axle alignment.
Next, the spacers, indeed, will give you more ground clearance for the shell, but not one fraction of an inch additional clearance for the axles tubes.
Spacers, will not help anything, if the rubber rods within the axles have expired. If the rubber rods are history, spacers will not stop any road shock.
The only sure way to increase the ground clearance of the shell and axle tubes, is to replace the axles, increasing the starting angle.
Ball park, new axles will increase the overall ground clearance by about 3 inches.
But beware, Airstream and Henschen both agree, to not have a starting angle in excess of 35 degrees.
09-19-2010, 12:55 PM
1968 28' Ambassador
Cedaredge
i'm betting that is a metal shop project as you would also need to have brackets for the shocks too.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
09-19-2010, 01:59 PM
1977 27' Overlander
Trotwood
, Ohio
I gained 4 inches in overall height.NOT 1 inch in ground/axle tube clearance.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
09-19-2010, 02:15 PM
Corona
Roger.
Please check it again.
When the starting angle increase, it raises the axle tube, and the trailer.
If it raises the trailer, the tube must also raise, since it's attached to the frame of the trailer.
09-23-2010, 08:23 AM
, Ontario
On other Travel Trailers / untility trailers that use Torsion suspension systems, I've seen folks install steel spacer "square tubing" between the trailer's steel frame and the steel torsion mounting brackets. For example, 4" wide x 3" high square tube - to give it a 3" lift. If torsion axle mounting bracket is 24" long, their steel spacer is 36" long (or as long as it can be). If wondering, they get their local welding shops to install this 4"W x 3"H steel spacer.
As others pointed out, if torsion axle is 15+ years old, I'd replace the torsion axle (AS WELL). Many say their internal rubbers don't last more then 20 years. For some shops, they won't touch a torsion axle that is 20+ years old. Also, do NOT weld anything to the torsion axle tube. It contains internal rubber and it will melt. Only "bolt" the torsion axle to the trailer's underside frame - using proper grade bolts.
If unsure, perhaps you can tow your trailer to a few local welding shops and ask for their "give it more height" ideas. Many shops are experienced with tasks like this. If wondering, I've seen 3 x torsion trailers with 4"Wx3"H steel spacers and all look great. To me, their ground height looks better then factory.
For more details about Torsion axles, surf: http://service.airstream.com/files/l...22708290a0.pdf
For pictures of square tubes for raising clearance, surf:
http://inlinethumb05.webshots.com/21...500x500Q85.jpg
http://media.photobucket.com/image/t...k/P4290142.jpg
If wondering, I raised my previous 19ft Prowler trailer by re-positioning its axle under its leaf springs. Thus, allowing me to raise its chassis 4". I never regretted giving my leaf spring trailer more ground height. IMO, its factory build "sat too low" and it also needed a lift. Glad I gave it a lift...
Hope this helps in your "give it more height" research.
09-25-2010, 05:30 AM
ground clearance
Thanx Andy..... What is the correct axle part # for this trailer? 1978 31 ft Excella rear bedroom. Also the factory GVW and axle weight class and $. Thanx...Ziffell...arnie@yousq.net
09-25-2010, 08:35 AM
1999 23' Safari
Perrysburg
, Ann Arbor
Don't forget that while raising the trailer will give you more ground clearance, it also elevates it's center of gravity. This in turn increases the likelihood of an overturn in an emergency maneuver. And you get to be the test pilot.
09-25-2010, 09:20 AM
Exeter
My old 1961 axels seem to be fine. I did raise the featherlite car hauler with great success. I did a little different. I used square tubing as shown in Spies' photo but I used one piece for both axeles- othere words Iused one long continuous piece for each side- seemed to strengthen everythin up alot. Also take note in that same picture I believe the axels to already be overloaded notice the swing arm in the positive position- which is probably why the owner felt he needed more clearance in first place.
09-25-2010, 10:00 AM
Corona
According to Airstream and Henschen, as an example, increasing the starting angle from the original 22 1/2 degrees to 35 degrees, will have a minimal effect on the center of gravity.
However, they suggested that traveling with an empty water tank, has even a greater negative effect on the center of gravity then altering the starting anglr by 12 1/2 degrees.
They also suggested that a starting angle in excess of 35 degrees, such as 45 degrees, is asking for trouble, in more ways than one.
Shimming the axle to gain a greater ground clearance, absolutely will absolutely, ask for problems.
Further, shimming the axle/axles will not change the ground clearance of the axle/axles tubing.
09-25-2010, 10:06 AM
Corona
The dollar cost is listed in our web site.
I am not at my office, therefore I cannot look up the original axle rating and changes that could be made, until Monday.
09-25-2010, 10:35 AM
2020 30’ Globetrotter
2001 30' Excella
Phoenix
We changed our axles over to a 35 degree down angle and it made a huge difference! Our original axles were definitely shot as you can see in these photos.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
09-25-2010, 10:40 AM
Corona
Very good, and nice too.
Now your Airstream will enjoy that "soft" ride.
09-25-2010, 10:42 AM
2001 30' Excella
Phoenix
another perspective
Before and after the axles were replaced.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
09-25-2010, 04:02 PM
Corona
The part number for the axles for a 1978 Excella is 20637.
09-26-2010, 06:21 AM
2001 30' Excella
Phoenix
That was a great recommendation by Greg at your facility to go with the 35 degree angle. Replacing the axles was the best investment we have made in our trailer. So far almost 3 years on the Henschens and no issues.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
09-26-2010, 06:52 AM
Corona
Thank you.
Ah yes, another Airstream trailer that knows it's in heaven, with that "soft" ride.
And the owners are enjoying it, too.
Good example of win-win.
10-05-2010, 09:41 PM
1976 31' Sovereign
Greenwood
, South Carolina
I intend to buy new axles for my 76 sovereign once I reassemble my new frame, floor and interior, that way I can get an exact weight measurement since I believe it will be heavier than before. I am also lowering the axles 1.5" on the new frame so it won't be such a tail dragger.
