Old 09-25-2010, 04:02 PM   #15
Originally Posted by ziffell View Post
Thanx Andy..... What is the correct axle part # for this trailer? 1978 31 ft Excella rear bedroom. Also the factory GVW and axle weight class and $. Thanx...Ziffell...arnie@yousq.net
Originally Posted by Inland RV Center, In View Post
If you use spacers, if not done correctly, it will mess up the axle alignment.
Spacers, will not help anything, if the rubber rods within the axles have expired.
The part number for the axles for a 1978 Excella is 20637.
Old 09-26-2010, 06:21 AM   #16
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
Very good, and nice too.
Now your Airstream will enjoy that "soft" ride.
That was a great recommendation by Greg at your facility to go with the 35 degree angle. Replacing the axles was the best investment we have made in our trailer. So far almost 3 years on the Henschens and no issues.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
LHall is offline   Reply With Quote
Old 09-26-2010, 06:52 AM   #17
Thank you.
Ah yes, another Airstream trailer that knows it's in heaven, with that "soft" ride.
And the owners are enjoying it, too.
Good example of win-win.
Old 10-05-2010, 09:41 PM   #18
musicmaster's Avatar
1976 31' Sovereign
Greenwood , South Carolina
I intend to buy new axles for my 76 sovereign once I reassemble my new frame, floor and interior, that way I can get an exact weight measurement since I believe it will be heavier than before. I am also lowering the axles 1.5" on the new frame so it won't be such a tail dragger.
musicmaster is offline   Reply With Quote
Increase Ground Clearance twilight10 Axles 7 07-03-2008 10:24 PM
Mud flap ground clearance? hazegrey Hitches, Couplers & Balls 4 10-31-2007 08:42 PM
What should the ground clearance be? 63air Towing, Tow Vehicles & Hitches 4 07-19-2006 01:01 PM
ground clearance/battery charge Kintscher Our Community 14 06-01-2005 03:36 PM
how much ground clearance? Chuck Plumbing - Systems & Fixtures 1 05-26-2004 10:10 AM
