Originally Posted by overlander63
For reference:
Nev-R-Lube= sealed non serviceable bearings.
EZ Lube = standard bearings with a zerk fitting so you can pump enough grease into the hub to blow the inner seal, and contaminate the brake shoes.
Lol! I had a trailer with EZ Lubes, and I never liked them. I serviced every two years, because I wanted to pull the drums to check the brakes. And yes, I had a set of contaminated linings one summer.
I repacked in the conventional manner.
I prefer cotter pins to the EZ Lube retainers as well.
