Old 03-10-2007, 01:07 PM   #1
niftypkg's Avatar
1971 27' Overlander
Cornville , Arizona
Talking Grease Seals
Just repacked wheel bearings. Purchased grease seals at Carquest paid $8.99/seal BOS #412920. These were exact duplicates. Cheaper version: RVB 5605-23 2/ pack for $5.98. Wouldn't recomend those; one seal and tender. Used synthetic mobil grease again. Looked OK after 5 years and 25 M miles. FYI. Brakes were Ok but magnets so-so. Don't want to that again!
There is Something Worse than Dying--- That is NOT LIVING !!!
PERFECT Trailer- Dog loves it- Wife hates it!!! You're not camping until you're miserable!
niftypkg is offline   Reply With Quote
Old 03-10-2007, 01:55 PM   #2
Desert Fox
1985 31' Sovereign
Tucson , Arizona
Smile Hey Nifty
The only time I would be sad when camping is when I would have to sleep in a tent and on the graound. To me camping is an AS or nearest motel.
The repak and seal are great idea thakns for the part numbet. The last time I got them was from NAPA. They were Chicago Rawhide Co.
Regards from Russell in Sunny and Warm Tucson Az.
RUSSELL is offline   Reply With Quote
Old 03-10-2007, 06:29 PM   #3
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
Someone with more trailer experience than me will hopefully chime in, but the seals may not be the same part numbers through the years. If in doubt, either go through an Airstream dealer, or get the seal number off of the front surface of the seal. It should be embossed there.
Dave
Fyrzowt is offline   Reply With Quote
Old 03-11-2007, 11:07 AM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Grease seals I have used in the past are:
Timkin 442109
Auto Zone 012038
>>>>>>>>>>>Action
Old 03-11-2007, 12:06 PM   #5
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
IIRC, seals are different numbers depending on if you have 10" or 12" brakes. I am (of course) not where I can double check, but I ran across that issue a few years ago.
Old 03-11-2007, 02:57 PM   #6
niftypkg's Avatar
1971 27' Overlander
Cornville , Arizona
Russel, good to hear from a fellow Arizonian. When I purchased the seals I had an original AS seal with me that had the part number attached to match up. Paid $3.70 5 years ago directly from AS. I tried for fit before installing. Found a smigon of excess play on one wheel but bearings looked OK. Did the work in the storage yard. No AS dealer near me in Cottenwood. Can just the magnets be replaced? Never done that. I use the prodigy brake control. Good guess first time. I'm pulling with a 2000 F250 HD diesel so I am over powered but thought I may move up to heavier trailer but never did. Russel I often stop at 'City Gas' in Bensen on my way to texas. I do stop at all the Flying J's when ever I can and park right next to the $500M Prevosts' in the lot. Offered to swap but no takers.....yet.
Old 03-11-2007, 04:02 PM   #7
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by niftypkg
... Can just the magnets be replaced? ...
Yes. I did that on my Overlander.
I believe your Airstream originally came with round magnets. Modern-day brake assemblies use oval magnets.
Tom
New seals for windows linjoe21 Windows & Screens 1 04-17-2004 04:57 PM
Grease seals, hub trouble Silver Annie Axles 10 11-03-2002 12:46 PM
Seals and Weatherstriping niftypkg Leaks - Weatherstrips, Gaskets, Caulks & Sealants 16 10-29-2002 10:40 AM
Wheel Bearing seals!!! niftypkg Axles 1 07-30-2002 04:35 PM
Window Seals niftypkg Windows & Screens 0 06-14-2002 07:39 PM
