Old 07-18-2004, 02:21 PM   #1
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Grease seal P/Ns
Viewers taking in today's traffic have probably figured out my hands have been greasy today
While I question the workmanship with what I have found, the fact remains that I will replace the grease seals on what appear to be the original Kelsey-Hayes, 12 inch electric brake drums.
Working on the streetside only, I found the forward wheel's single lip seal was stamped Kelsey-Hayes 42385 on the metal ring.
The aft wheel's single lip seal was stamped National 442109 on the metal side, and S-5152 was cast into the inner side of the rubber seal.
While the name Kelsey-Hayes is no longer around, I figure National probably is. Since I will probably have to mail-order any parts I need, does anyone have another seal vendor/part number to offer, or any other words of wisdom in dealing with my '67 Overlander?
Tom
Old 07-18-2004, 02:52 PM   #2
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
Tom
I can't speak for your 67 but, on my 87, I found a fairly good selection of sizes at O'Reilly auto parts. They have a line of american made german owned, and a chinese knockoff. Can't remember brand name.
Also found exact replacements at Luckey B trailer supply in Cookeville, Tn and on line at www.luckyb.com. They are all chinese. Bearing races are plain steel vs. alloy. Dexter brand. Lucky B people are fairly knowledgeable mainly due to how standardized the trailer industry is on 10" or 12".
Did your seals have a stainless steel coiled spring to hold them tight to the axle? These are superior quality seals and becoming hard to find. Airstream had the good ones when I looked in Lansing. These seals don't need changing but, every few years if they have the springs.
wingfoot321 is offline   Reply With Quote
Old 07-18-2004, 03:40 PM   #3
LOST , Hawaii
National and Chicago Rawhide are 2 biggies in the seal world. If you have a number any decent parts or trailer place should be able get these if they don't stock them
John
74Argosy24MH is offline   Reply With Quote
Old 07-18-2004, 03:49 PM   #4
TomW's Avatar
1967 26' Overlander
Originally Posted by wingfoot1
...Also found exact replacements at Luckey B trailer supply in Cookeville, Tn and on line at www.luckyb.com. They are all chinese. Bearing races are plain steel vs. alloy. Dexter brand. Lucky B people are fairly knowledgeable mainly due to how standardized the trailer industry is on 10" or 12".
Thanks for the info!
To my surpise, neither of the two seals I have removed had coiled springs ensuring a tight fit. The seals had weeped a small amount of grease into the brake shoe area, but nothing I was alarmed about.
I know Cookeville. I heard there was an Airstream dealer opening up on Commercial Drive. Been there yet? My wife and I will stay in Cookeville as a stopover on the World's Longest Yardsale trek next month. If you have been to the new dealer, is it worth stopping at?
Tom
Old 07-18-2004, 05:07 PM   #5
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Grease seal part #
The seal #'s that I have used are:
3M? 29031
Auto Zone 012038
Timkin 442109
Dexter 010-054-00
Some had a spring and some did not. All except the Dexter did well. I don't know about the Dexter cause I haven't repacked the bearings since I have installed them.
>>>>>>>>>>>Action
Old 07-18-2004, 08:36 PM   #6
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Any NAPA auto parts store has them, with the springs.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 07-18-2004, 10:30 PM   #7
1987 29' Sovereign
Sparta , Tennessee
Tom
I have stopped a couple times. He has a good selection of trailers(no 30' or 34' slides) and 3-4 motorhomes. I have checked a couple times on misc parts and have been referred to the Heritage Ford location to use their computer to order. Same owner.
I talked to one of airstream techs at Lansing and he said he had been to Cookeville one time to train their service people plus they have been to Jackson center. It sounds like they are slowing getting there. They still haven't built a service building on the Commercial drive site.
Old 11-03-2012, 10:06 AM   #8
1963 22' Safari
Mascotte , Florida
The national seal #412920 is an exact replacement for the Kelsey-Hayes 42385 and it has the spring that holds it tight to the axle. I got them at our local Advance auto parts.
Muckgyver is offline   Reply With Quote
Old 11-10-2012, 06:13 PM   #9
rogerdodger's Avatar
Fresno/Clovis , California
Welcome to the forum, but you are posting to an 8 year old thread.
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Hensley Hitch Grease Princer Hitches, Couplers & Balls 3 04-12-2004 03:57 AM
Help - Transmission Rear Seal Part No? swebster Mechanics Corner - Engines, Transmission & More... 8 02-29-2004 02:49 PM
Bulb Seal for 1963 Windows Alan and Mardel Windows & Screens 10 01-13-2004 11:29 AM
Grease seals, hub trouble Silver Annie Axles 10 11-03-2002 11:46 AM
Door Seal Types ??? Road Ruler Doors & Locks 3 09-07-2002 05:53 PM
