Old 07-24-2004, 10:07 AM   #15
A direct replacxement axle (Henschen) takes less than 3 hours labor, including shocks to replace.
However, if the axle mounting plate is too short vertically, like it is on the early 60's trailers, then add another hour.
That hour is for the purpose of drill 6 half inch holes. Certainly plenty of time.
Old 07-24-2004, 10:50 AM   #16
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Originally Posted by 53FlyingCloud
Yea, I see what you mean..
Sorry Tim..
When I said under it..The intent was ' over the top of it '...
(from gnd up)
I've spend way too much time laying on my back under the GT...
ciao
53FC
Vern... No problem. I am glad Shari straighted us out though. Now I can turn my computer monitor right side up again!
Steph.. Looks like a great job on all the work they did. I'm sure your going to feel really good about towing it where ever you want!
-Tim
theVAP - Airstream Podcast
Old 07-24-2004, 01:35 PM   #17
MW64OVERLANDER's Avatar
1964 26' Overlander
Norman , Oklahoma
Images: 67
Originally Posted by InsideOut
Hey Vern...are you standing on your head?
The red line is going over the axle in Steph's attached photos...it's higher off the ground than the axle thus it's 'over'.
Whatever...
The question is the same, why between the axle & belly pan instead of under the axle?
Shari
The original axels mounted up with no space between the square axel tube and the belly pan. The propane line that runs back to the water heater had a loop bent into it so it could pass under the axel(s). The new axels, when mounted hard against the square cutout in the mounting plates, still leave about a one inch space between the square axel tube and the belly pan. This allows you to re-run that propane line flush against the belly pan without looping the line under the axel where something could hit it.
Mark Wilson
1964 Overlander/2000 f250 Crew Cab 4X4 PS WBCCI# 5600
MW64OVERLANDER is offline   Reply With Quote
