Old 12-27-2010, 09:51 AM   #71
pickerdd's Avatar
1971 23' Safari
Marietta , Georgia
How often should an Airstream be moved to exercise the axles? My '71 Safari's axles need to be replaced, which I'll do this coming Spring. I don't know the history of my AS other than what the previous owner relayed to me when I bought it from him, so I don't know if it sat in place for years with little or no movement before he bought it.
- David
1971 23' Airstream Safari - "Moe"
2017 Ford F350 4x4 6.7 CCLB - Silver/Black - "Max"
pickerdd is offline   Reply With Quote
Old 12-27-2010, 10:04 AM   #72
There are no stats to provide an exact positive answer to your question.
However, experience can offer one.
Move the trailer at least once a year for 15 or 20 miles, or more. Storing the trailer on jack stands helps, but again, that does not provide the necessary exercise, for the rubber rods.
Also keep in mind, that the life of the rubber rods can be extended, but never forever. Average life of the rubber rods, with frequent exercising, seems to be about 25 years of use. Non use, can ruin the rubber rods in as little as 3 years, again based on experience.
Old 12-27-2010, 10:30 AM   #73
Harry W's Avatar
1978 31' Sovereign
Scottsdale , Arizona
If you install new Henschen axles, be sure to check the alignment. Don't assume that it is correct (as I did).
Harry W
4CU Charter Member
AIR # 13858, WBCCI # 2420
Harry W is offline   Reply With Quote
Old 12-27-2010, 11:29 AM   #74
The torsion axles are aligned, when manufactured.
However, motor freight carriers can and often do unbelieveable damage.
Certainly, checking the alignment is a good thing to do.
Old 12-27-2010, 11:41 AM   #75
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
I was looking at the google satellite images of Jackson Center a while ago, and I noticed the former GKN/Henschen factory to the northeast. I'm not surprised they closed. The roof of their factory was pitch black.
They probably couldn't make a profit because of the cost of running the AC so hard all summer.
The Airstream factory roof is bright white.
TX-16
Dave Park is offline   Reply With Quote
Old 12-27-2010, 12:01 PM   #76
The Henschen plant's roof was typical industrial heighth, like 24 feet or more.
I have been in that building on a "hot" Jackson Center day, and it was much cooler than outside. Also their working hours took advantage of the cooler hours of the day.
Old 12-27-2010, 12:16 PM   #77
Dave Park's Avatar
2005 22' Safari
Darn. I forgot the smiley so people would know it was a joke :P
TX-16
Old 12-27-2010, 02:15 PM   #78
pickerdd's Avatar
1971 23' Safari
Marietta , Georgia
Thanks Andy. I appreciate the info. It's amazing how many trailers sit still for the majority of their lives. If nothing else our Moe will (and does) get plenty of exercise moving between the storage facility and our house when I'm working on it, which seems to be most of the spring and summer.
I'm looking forward to getting the new axles installed this coming Spring. It should make the trek out to Kansas in September much more comfortable.
Thanks again and Happy Holidays,
- David
Old 12-27-2010, 02:16 PM   #79
pickerdd's Avatar
1971 23' Safari
Marietta , Georgia
Thanks Harry - will do. I appreciate the heads up.
- David
Michigan is far away....Winter is closing in Melody Ranch Off Topic Forum 0 08-18-2009 04:28 PM
TORNADO - 5 miles away and closing clancy_boy Off Topic Forum 19 10-22-2007 11:53 PM
GKN Axle Service and Maintenance Manual Inland RV Center, In Commercial Listings 0 08-23-2007 05:37 PM
