Old 12-11-2009, 03:44 PM   #29
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Looks like some alternative plan may be brewing for Henschen/GKN. They have released an update to their announcement to this effect.
UPDATE: GKN releases statement concerning layoffs > RV Daily Report
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 12-14-2009, 11:38 AM   #30
Henschen
Looks like the fat lady, may have gone to the wrong airport, to catch her train.
Old 12-14-2009, 01:34 PM   #31
Images: 59
Sounds like a screw-up to me.
If you plan to get out of the torsion axle business you should shop it around to a buyer before you announce you're gonna close it down.
And they want their customers to wait around, in case the buyer wants to take them out to dinner and a movie?
It's more likely Dexter will buy it, run it for six months and then shut it down once they've worked over the customer list.
Old 12-14-2009, 02:45 PM   #32
People in other countries, don't always do it the American way. They have their ways, and we have ours.
Not.
Old 12-17-2009, 10:09 AM   #33
2009 34' Panamerica
Richfield , Ohio
I would rather have DEXTERs. The parts are more redily available, and when priceing an axle, can generally get Dexters installed for the same price as Henschens, un installed. Most enclosed trailers out side of Airstream use these axles for that reason. Dexter is a well made axle that has been time tested and proven, anyone who argues that is simply not in the know
FreeWilly is offline   Reply With Quote
Old 12-17-2009, 10:20 AM   #34
Originally Posted by FreeWilly View Post
I would rather have DEXTERs. The parts are more redily available, and when priceing an axle, can generally get Dexters installed for the same price as Henschens, un installed. Mast enclosed trailers out side of AIrstream use these axles for that reason. Dexter is a well made axle that has been time tested and proven, anyone who argues that is simply not in the know
There is no difference in parts availablity for Dexter's or Henschen. Most any RV store has them.
Brakes are brakes, bearings are bearings, hub and drums are hub and drums, and grease seals are grease seals.
Henschen is equally well tested, on Airstream trailers, and on thousands of agricultural/farm implements.
Old 12-17-2009, 12:29 PM   #35
1980 31' Excella II
Drummond Island , Michigan
USA or anywhere else big corporation profit rules. Recently the automakers and the RV industry had to shut down whole product lines because of a lack of sales and profitability. The physical assets and the tooling for Henschen in Jackson Center have value. I'm sure they will be sold or liquidated for whatever there worth. Hopefully someone will buy the torsion axle stuff and continue to make or remanufacture existing axles. Until Thor bought Airstream and then acquired Henschen before JKN bought them you could send your old axles to Henschen and have them remanufactured at a very reasonable cost. The spindles, axle tube etc. do not wear out unless they are neglected. What wears is the rubber inserts around the torsion bar. I'm lucky I guess, just had new axles installed about 6 months ago.
Ahzmyrah is offline   Reply With Quote
Old 12-17-2009, 12:58 PM   #36
The axle rebuiding program, by Henschen, was shut down a number of years ago.
Why??
The huge liability associated with rebuilding an axle, that had rust within the square tube. Many of those sent in for rebuilding had to be rejected for that reason.
Then the question came up of "are you just telling me that, or is it that bad". Arguements took place, all of were unnecessary.
Then there was the money wasted on the freight to Jackson Center.
All in all, it was deemed by top management, to discontinue the rebuild program, especially since attorneys are so active when it comes to liability, for their own usually, personal financial gains.
Please note, that Dexter does not rebuild either.
Old 12-17-2009, 01:29 PM   #37
2009 34' Panamerica
Richfield , Ohio
So they are a duplicate, or a knock off is what your saying. Thats good to know
Old 12-17-2009, 02:06 PM   #38
They are not a knock off.
Some travel trailers parts are availble most anywhere.
There are a number of hub and drum, electric brake, and bearing manufacturers.
A knock off, is a cheap copy of a better product, for the sake of profit, with quality and specs, in the far background.
Dexter and Henschen, are not in that category. They both build quality products, and strive to build a "perfect" product. Things being things, that rarely goes astray, with either of them.
Old 12-18-2009, 10:13 AM   #39
1980 31' Excella II
Bottom line reason for closing Henschen or the decision to stop rebuilding axles in the past was and is profitability. This is not a bad decision if you are in business to make money. It is not a good decision for your customers as it makes it difficult to repair or replace a worn out product.
The decision to stop rebuilding was corrosion of the axle tube which could weaken it and promote failure in the future if it was reused. Plus the cost and method of shipping the old axle to the plant and then reshipping it after repair. There are many replacement items used in the automotive repair industry that are remanufactured and actually superior to OEM parts. MOOG Corp. for one remanuctures steering racks and other suspension components that actually have a better warranty and service life than OEM parts.
The most expensive parts of a Henschen axle are the specially machined spindles welded to the torsion arm and bar. These parts unless they were badly abused or bent will basically never wear out. The old square torsion tube and mounting brackets could basically be removed and thrown away. Then the bare spindles could be shipped to a remanufacturer to be married to a new tube, rubber cushion strips and brackets made to fit the specs for that trailer and then shipped as a completed assembly back to the customer. That would remove the liability issue from the rusted tubes and should provide a quality product at a reasonalble price for the customer.
Old 05-29-2010, 09:27 PM   #40
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
Any updates since this last post??
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 07-13-2010, 10:53 AM   #41
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
I heard that Henschen closed their axle business in June.
SilverHoot is offline   Reply With Quote
Old 07-13-2010, 01:31 PM   #42
Henschen
Henschen has indeed closed their plant in Jackson Center.
The good news is two fold.
The axles known as Henschen, will reappear in about 3 to 4 months, as best as can be determined at this time, equal to their standards, but under a different name. The manufacture of them will be supervised and controlled by a former top notch Henschen manager.
The warranty on Henschen axles will still be in full effect, through Inland RV Center, Inc.
The other part of the good news is that over 300 various rating and specs axles are in stock, for usually next day shipment. This should cover the down time of the transition.
There is no need to be concerned or worried about the closure, since the availability presently is quick shipment, instead of the 3 or 4 week production time delay.
The bottom line, still remains, "business as usual".
Michigan is far away....Winter is closing in Melody Ranch Off Topic Forum 0 08-18-2009 03:28 PM
TORNADO - 5 miles away and closing clancy_boy Off Topic Forum 19 10-22-2007 10:53 PM
GKN Axle Service and Maintenance Manual Inland RV Center, In Commercial Listings 0 08-23-2007 04:37 PM
