Old 03-15-2012, 05:45 PM   #1
SafariFaye's Avatar
1964 22' Safari
Livonia , Michigan
Getting Safari 'off the ground' for new axle.
I'm looking for some advice on the best way to get our 64 Safari up off of the ground so I can replace the axle. I've spent the last week reading all of the posts on how to remove and replace the axle, but I haven't the foggiest on how to get her up off the wheels (safely).
I've got plenty of jack stands (6) and hydraulic jacks (3), but I'm not sure of the best locations for them. As far as I can tell, the only "exposed" frame areas are right next to the axle (and that isn't much), near the rear of the trailer and the very front ("A" frame?). The belly pan and banana wrap hide everything else.
Any input would be greatly appreciated. Don't feel like getting squished, so I'm doing my due diligence first.
Thanks for helping out a noob!
Jason
SafariFaye is offline   Reply With Quote
Old 03-15-2012, 06:01 PM   #2
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I use the steel plate my axles mount to. When I did the axle change I think you can see the jack stands in one of the pictures. I used the same plate as my lift point.
http://www.airforums.com/forums/f437...ion-72600.html
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 03-15-2012, 06:03 PM   #3
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
P.S. I suggest lifting between your axles (just guessing you have two) and then placing the jack stands outboard of h axles if you have space.
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 03-15-2012, 06:41 PM   #4
SafariFaye's Avatar
1964 22' Safari
Livonia , Michigan
Actually, we only have one axle. There is the rub. There is very little space to place the jacks/jack stands. We are having some serious thunderstorms this evening, but I may take some pics to post tomorrow after work. Replacing 2 axles may actually be easier than 1.
Old 03-15-2012, 06:55 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome Aboard....
Jason,
Find a plate that looks a bit like this...and jack away.
Used the axle plate on our 63 Safari to jack up & when I put it on stands for Winter storage, very stable, but for axle replacement you might consider two sets, two stands on the plate and two on the frame in rear just before it goes into the belly pan just for extra support. the majority of the load on the tongue jack and axle plates.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 03-15-2012, 06:58 PM   #6
Tool Hoarder
West , California
Jack on the mounting plate just fore and aft of the axles. Make sure to do it on level ground. I used a 3 ton floor jack 2 bottle jacks and 6 4 ton jack stands. I did it my self ( use a friend trust me)
marzboy is offline   Reply With Quote
Old 03-15-2012, 07:03 PM   #7
SafariFaye's Avatar
1964 22' Safari
Livonia , Michigan
Thank you SO MUCH. You all have been very helpful. It is amazing the amount of information available in one place.
Old 03-16-2012, 01:07 PM   #8
Noob
JazzDad's Avatar
2009 22' Sport
Columbus , Texas
I goes without saying (so why am I saying?): make sure your jacks and stands are on a solid surface. No small squares of 1/2" plywood sitting directly on the tposoil.
All kids are gifted; some just open their packages earlier than others. - Michael Carr
JazzDad is offline   Reply With Quote
Old 03-18-2012, 03:49 PM   #9
SafariFaye's Avatar
1964 22' Safari
Livonia , Michigan
Thanks again to everyone for their help... The axle is on. I'm in one piece and learned a TON about our trailer. I'll feel even better about pulling her now that we have new brakes, new shocks and 4 inches of additional lift.
What a rush, seeing her back on 2 wheels.
Old 03-18-2012, 04:16 PM   #10
W. H. Auden
Amanamus
"Tahawus"
Photos of Safari 1954 restoration safari 1954 1954 Safari 81 08-14-2012 06:01 PM
What did a Classic Motorhome Cost New? Keyair Classic Motorhomes 42 08-12-2012 06:39 PM
Looking for Streamline Logos gmaof20 Vintage Kin 8 06-30-2012 10:38 PM
Help to Install new teardrop LED marker lights Air-Texas Lights - Interior & Exterior 19 03-21-2012 10:51 AM
Getting Safari 'off the ground' for new axle. SafariFaye Axles 9 03-18-2012 04:16 PM
