Old 05-16-2010, 06:14 PM   #1
Archersfin's Avatar
1986 34' Excella
Conroe , Texas
Free Axle parts
I just replaced the Axle's in my 86 Excella triple axle and have the old ones.
There is nothing wrong with the bearings, brake's and hub's if anyone is interested.
Please PM me
I will not ship, but will deliver within 50 miles.
Archersfin is offline   Reply With Quote
Old 05-16-2010, 06:28 PM   #2
New Borockton , Alabama
Images: 21
What was wrong with the axles?
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Old 05-16-2010, 07:26 PM   #3
Archersfin's Avatar
1986 34' Excella
Conroe , Texas
The rubber was hardened and set at 0 deg. Not much spring left.
Old 05-16-2010, 07:28 PM   #4
1972 Travelux Princess 25
Cobourg , Ontario
Has anyone tried pulling them apart and replacing the rubber rods?
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 05-16-2010, 07:35 PM   #5
Yes they have.
If you can deform the rubber rods and then freeze them to about minus 260 degrees F, and then quickly reinstall the metal shaft, with the frozen rubber rods, then you can do it.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 05-17-2010, 11:33 AM   #6
Cobourg , Ontario
How hard is it to get them apart?
The freezing and forming should be possible with dry ice.
Old 05-17-2010, 06:48 PM   #7
Dry Ice doesn't get cold enough.
Minimum temperature required to keep the rubber rods frozen for 30 to 45 seconds, when exposed to a normal ambient temperature, is minus 200 degrees F, or even colder.
Liquid nitrogen is how it's done.
But, try youir idea if you wish.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 05-19-2010, 10:03 AM   #8
Archersfin's Avatar
1986 34' Excella
Conroe , Texas
The Axle's are
GONE!
Old 05-19-2010, 10:24 AM   #9
vitag's Avatar
1958 26' Overlander
Webster Groves , Missouri
LOL
vitag is offline   Reply With Quote
Old 10-05-2010, 03:37 AM   #10
Thunder Bay , Ontario
I met a girl that could cool them that much , no problem!!
doneuald is offline   Reply With Quote
Old 10-05-2010, 10:52 AM   #11
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
The rubber cannot be replaced, but it can be restored by sitting the axles in a bath of seal restorer for a few days.
Not that I'd want to try this on an axle on MY airstream, and I'd want to see a million miles of testing before recommending it to anyone else... But this can fully restore the rubber to its original compressibility characteristics.
This works in many cases where rubber is in compression but should never be used on rubber in tension.
TX-16
Dave Park is offline   Reply With Quote
Old 10-05-2010, 11:00 AM   #12
I believe that will add rust to the interior of the axle tube.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-06-2010, 10:09 AM   #13
Free axle parts??
Free axle parts ????
We have lots of them.
Unfortunately they are all junk.
This is how we take care of that issue.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-10-2010, 07:34 PM   #14
Evanston , Wyoming
Where can I get the rubber rods? I'm willing to try replacing them myself
twinkieman is offline   Reply With Quote
Old 10-10-2010, 07:47 PM   #15
Don't go there.
The rubber content must be very specific.
You cannot replace the rubber rods, unless you can deform them correctly, and then freeze them to MINUS 240 degrees below zero.
Others have tried, with a "ZERO" success rate.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-10-2010, 08:14 PM   #16
Dave Park's Avatar
2005 22' Safari
It is simply not possible to replace them without some liquid nitrogen, a form press and some other special tools. Also, the rubber is a very unique formulation.
And, this is my 500th post!
TX-16
RM-75 Parts For Free Alumin8 Refrigerators 6 03-24-2011 06:57 PM
Free 1972 Overlander Interior Parts - Get 'em while they are hot (and free) amitchell Interior Restoration Forum 25 03-03-2009 05:02 PM
Parts for free LRPorter All Argosy Trailers 3 10-09-2008 06:05 PM
Free Parts!!!! soldiermedic General Repair Forum 29 11-04-2007 06:38 PM
