Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Prev Previous Post   Next Post Next
Old 06-24-2005, 02:53 PM   #1
JMR
Profile:
Floor Cracks, Door Cracks & more Cracks
Has anyone ever seen this type of damage before? I have three cracks in my floor that run across the trailer. One by the front door, one in the middle of the trailer and one near the bathroom entrance. The one by the front door seems to be following the joint where the two pieces of plywood are meeting. It appears that there is no support (outrigger) under the joint. I am assuming (hoping with my fingers crossed) that this could be the cause of the problem. I have a sneaking suspicion on what the true problem might be (bent or broken outrigger) but am hoping otherwise. To add to my problems the lower corners of my door frame have split. Has anyone come across this type of problem? If so how did you go about fixing it? (See attached photos if I've done it right)
Jeff
Name:	Front Floor Crack.JPG
ID:	12997   Click image for larger version
Name:	Door Crack 2.JPG
Name:	Door Crack.JPG
JMR is offline   Reply With Quote
Cracks forming on shell --- Repair Help !!! SlammaJamma Ribs, Skins & Rivets 3 05-26-2005 11:22 AM
Tire Cracks Action Tires 3 06-14-2004 02:09 PM
tire replacement? cracks daydreamer36535 Tires 4 08-17-2003 07:23 PM
How do you repair cracks in the headliner of a 1985 325 Motorhome rdm General Interior Topics 3 08-03-2002 09:19 AM
Repairing cracks in fridge plastic? Charcigar Refrigerators 2 05-01-2002 07:44 AM
