Old 06-24-2009, 03:35 AM   #1
NY_Chairs's Avatar
1971 31' Sovereign
Arcade , New York
Flexride Axles?
Hello all. I am in the process of looking for new axles for my 1971 31' Sovereign to get next spring near the end of the restore. I spoke with Andy last night and his whole axles package runs $750 complete, per axle.
Just to be fair though I researched some other torsion axles MFGs. Then I searched the forum here and didn't find a single mention of some of the MFGs.
For example, a 3500# complete 12" elect brake axle from Flexride is $386 per if you buy 2, this is almost half of the Dura-Torques. The only issue that I see with the Flexrides is that their default design bolts to the outside of the frame and I need it to bolt to the inside, I have not called Flexride to see if this is workable, but I am sure it is.
Just wondering if anyone has ever looked at or used other axles. I saw the thread on Dexter and the reasons not to use them. Though I found 3 or 4 other torsion axle brands out there as well.
Thanks.
-Rich
Rich
1971 31' Sovereign
1988 Chevrolet School Bus (Converted)
NY_Chairs is offline   Reply With Quote
Old 06-24-2009, 04:04 AM   #2
Gael79's Avatar
1970 31' Sovereign
Lombard , Illinois
hello Rich,
I am also looking at axles. Haven't decided yet, but I agree that $1500 like a lot of money. Let us know what you decide to do...
Best of luck,
Scott
I have a picture of my Airstream in my wallet, and I'm sitting on it...
...If that's not love, I don't know what is!
Gael79 is offline   Reply With Quote
Old 06-24-2009, 06:35 AM   #3
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by NY_Chairs View Post
Just to be fair though I researched some other torsion axles MFGs. Then I searched the forum here and didn't find a single mention of some of the MFGs...For example, a 3500# complete 12" elect brake axle from Flexride is $386 per if you buy 2...Just wondering if anyone has ever looked at or used other axles.
Rich -
Do a search on "Flexiride".
I did a comparison on them in this thread:
http://www.airforums.com/forums/f219...ign-14737.html
Post #49
In short, Flexiride could not supply a sufficiently "soft" rated axle with a "heavy duty" bearing and brake assembly.
In addition, their "split axle" mounting MAY have overtaxed the frame rails of an Airstream. After discovering I could not get comparable rated brakes and bearings from them I did not pursue the mounting problems.
I DID, however, really like their spline and groove adjustable starting angle assembly. The engineer I was conversing with (in New Jersey, IIRC) agreed that ALL rubber torsion axles have a finite life...all rubber will take a "set" sooner or later - sooner if not STORED in a relaxed state.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 06-24-2009, 06:36 AM   #4
NY_Chairs's Avatar
1971 31' Sovereign
Arcade , New York
Yeah, I spoke with them and encountered the same issues, they also could not provide 12" brakes. Think I am going with the Dexters. If anyone has done them on the '71 Sovereign or equivalent I would appreciate any detailed specs and info on how to get them ordered, via PM or e-mail is fine.
Thanks.
-Rich
Rich
1971 31' Sovereign
Old 06-24-2009, 07:10 AM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Have never heard of Flexride, but a lot of people use Dexters. There has been a plethora of information posted on comparing Dexters to the OEM Henshens
Old 06-24-2009, 07:53 AM   #6
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
Dexter will, if asked, weld on the shock mounts for you, so you can keep the factory shock set-up. My 2 3,000#, 10" brake EZ-lube axles were about $820, complete and shipped. Figure about a day to get them installed.
tphan is offline   Reply With Quote
Old 06-24-2009, 07:56 AM   #7
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Well good luck with the Dexters. I hope they get the measurments correct. They, I heard are not to accurate. I dont know what kind of guarantee they have if they miss the mark.
Sometimes ya just have to bite the bullet. We did and I agree that $1500 is too much money. But my new Henshens fit like a glove. No problems installing them.I had it done in 3 hrs.
But I wanted OEM and thats what I got.
GOOD LUCK with what ever brand you get.
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 06-24-2009, 08:18 AM   #8
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
My Dexters fit perfectly. Just get your measurements accurate and that's how they'll get built.
Old 06-24-2009, 08:34 AM   #9
CanoeStream's Avatar
St. Cloud , Minnesota
We could post about Ivory Snow and somebody would always take the opportunity to lift their leg on it. Dexters can work as later posters in this thread are suggesting. There was even a period starting about 4 years ago when Jackson Center was installing Dexters for about half a year. I know -- that's what is on my Safari. There's something at the edge of my mind that Dexters are installed on any unit spec'd for Canada.
5 meter Langford Nahanni
Old 06-24-2009, 08:45 AM   #10
reddogfox's Avatar
2008 20' Safari SE
Thumb Area , Michigan
My Safari was built in April 2007 and is equipped with Dexter axles. So far no problems.
Richard from MI
20' 2008 Safari SE, Dill TPMS Silver Dog House
2007 GMC 1/2 ton Sierra ARE Cap
AIR # 10494
reddogfox is offline   Reply With Quote
Old 06-24-2009, 09:17 AM   #11
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Ditto's to this statement - My Dexters work fine - the key is the measurements.
crispyboy is online now   Reply With Quote
Old 06-24-2009, 09:18 AM   #12
NY_Chairs's Avatar
1971 31' Sovereign
Arcade , New York
I spoke with Dexter engineering and he even mentioned they were now supplying the new Airstream axles. I got the spec sheet, just need to verify all the measurements on my trailer and go to the local distributor to get a quote and get them ordered.
Rich
1971 31' Sovereign
Old 06-24-2009, 09:50 AM   #13
brownsmtnlab's Avatar
1970 31' Sovereign
Greeneville , Tennessee
Images: 8
During our visit to Jackson Center last June, the first thing I noticed on the front desk was a cutaway "demo" of a dexter axle showing how they work...This was an advertising piece and so I inquired...Every Airstream being produced that day had Dexter axles.
My 1970 sovereign has Dexters...with 10 inch brakes...and a 45 degree start angle...These bearings and brakes are rated at 5400 lbs each and allow far more room for air circulation around the brakes and tire rim than the 12" brakes. There is far less heat transfer to the tire with the added clearance ( so says a TRW chassis engineer that helped me install them) My dexter dealer sent one of my old axles back to the factory for $50 and so no one measured anything on my end..The new ones both slipped right in.....To stir the puddin' even more I might add I did not install shock absorbers, and have put on 12,000 trouble free miles so far. At least 2 other vintage airstreams the size of mine have the exact same set up and are also very happy.
If you don't know where you're going, any road will take you there
brownsmtnlab is offline   Reply With Quote
Old 06-24-2009, 10:22 AM   #14
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Isn't the starting angle rather steep at 45 degrees? Just wondering what angle they are at when you are loaded and heading down the road?
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
My '62 axles Frank's Trailer Works Axles 7 12-22-2007 08:17 PM
Axles nairnchyz Axles 3 04-02-2007 02:13 PM
New Axles garthbf Axles 4 08-07-2006 07:27 PM
Got Axles??? Action Axles 25 04-16-2006 08:09 AM
Need New Axles Navigator Axles 138 12-19-2004 10:00 AM
