Old 11-26-2009, 12:18 PM   #15
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Originally Posted by Lumatic View Post
I have bad feelings about Holiday RV.
I guess that clears that up.
Gene
Old 11-26-2009, 05:00 PM   #16
CanoeStream's Avatar
St. Cloud , Minnesota
Good suggestion Kip. I've used Oasis RV in Tucson for some parts sourcing. They gave up their Airstream dealership but know Airstreams backwards & forwards. They're more convenient than going to Dallas or California if you're going to hire the job done. Perhaps somebody more regional has had recent experience... Anyone?
Please post back here on the experience whatever way you go!
5 meter Langford Nahanni
Old 11-26-2009, 08:07 PM   #17
Kit
Kit's Avatar
1972 Argosy 20
El Prado , New Mexico
...hope you are all are having a fabulous Thanksgiving!!!
Thanks for all the advice everyone...
Holiday RV in Albequerque.....I was not treated with much respect there...I went to look at a couple of AS...I would not go back.
Lumatic, I will take some photos tomorrow, check the tire size...the tires did not drop at all when the tire company was jacking the trailer...so it is probably the axle...glad to know someone is close.....close at least by NM standards...
spare tire cover was found at a auto salvage in Colorado Springs! Pretty neat, huh...it is a little dinged up close...but still wonderful.
Am making some research calls tomorrow re: axle purchase. Still looking for someone to install it. What about local mechanics? At least they would have the tools and mechanical experience, which I don't.
I cannot fall apart because I cannot fall together....
-Andy Warhol-
Kit is offline   Reply With Quote
Old 11-26-2009, 10:19 PM   #18
When raising the trailer, and the tires do not drop, tells you that the rubber rods within the axle tube, has solidified. Therefore it offers no cushion.
Installing a single axle and replacing the shocks, depending on the shop, takes about 2 1/2 hours.
Old 11-28-2009, 04:58 PM   #19
Kit
Kit's Avatar
1972 Argosy 20
Ok here are some pics of the streetside tire without the hub, which still is loosing air, and what I could get underneath...
ID:	91610   Click image for larger version
-Andy Warhol-
Old 11-28-2009, 08:26 PM   #20
Try spraying the tire that's losing air, with a soapy water solution.
Look for small bubbles.
That will show you where the leak is at.
Also, don't forget to spray the valve stem as well.
When the shop reinstalled the tire on the wheel, did they brush any liquid on the tire where it fits on the wheel?
Changing a flat tire. yakman Jacks, Stabilizers, Lifting and Leveling 0 07-20-2009 07:47 PM
Flat tire tn2 Argosy Motorhomes 8 11-04-2007 08:00 AM
I have a 1965 Caravel and if I have a flat tire toastie Tires 11 09-07-2006 11:51 AM
Flat tire... Craig Tires 10 07-11-2003 12:49 PM
Flat tire detector Pahaska Tires 6 08-08-2002 06:38 PM
