Old 02-15-2014, 10:25 PM   #1
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Extending axle mounting plates
Has anyone ever extended the axle mounting plate?
It would allow for deeper tanks and more road clearance.
Any thoughts?
Matt
rugjenkins is offline   Reply With Quote
Old 02-16-2014, 06:21 AM   #2
2003 25' Safari
Riverside , California
Check this out may be what you are looking for Dexter Axle - Trailer Axles and Running Gear Components - Torflex Lift Kit
2003 25' Safari
2005 Ram 2500 4x4
1994 Ram 2500 4x4
2015 Toyota Tacoma trd 4x4
2000 Jeep Wrangler 4x4
Bob4x4 is offline   Reply With Quote
Old 02-19-2014, 07:53 PM   #3
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
And if new axles are in your future you can order them with a "High profile mount". Not sure how high is ava. but I ordered mine + 1 inch. You'll be surprised how much difference that 1" makes backing into high angle sites added to the 3 inches on a new X. Also you can order increased down angle for even more clearance.
putback is offline   Reply With Quote
Old 02-27-2014, 06:11 PM   #4
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Any thoughts?
All torsion axled Airstream's came with 22 1/2 degree down angle arms (with the exception of a few smaller late model trailers), however when you order new axles, you can opt for 32 degree down angle for no extra charges. Most of our clients stay with the original down angle, however a few wanted greater ground clearance due to local camping preferences or driveway concerns. Keep in mind that deeper tanks will create other drain plumbing problems so think it all out before making the jump. We've installed a lot of the Vintage Trailer Supply grey tanks, allowing you a flush bellypan, along with the option to add capacity by installing multiples.
Good luck,
Colin
Colin H is offline   Reply With Quote
Old 02-27-2014, 07:40 PM   #5
KYAirstream's Avatar
Northeastern , Kentucky
Any concerns with adding 1" or the 32 degree angle? Effect on towing?
KYAirstream is offline   Reply With Quote
Old 02-27-2014, 08:12 PM   #6
Colin H's Avatar
1959 28' Ambassador
1949 24' Limited
Peru , New York
It raises the center of gravity & drag, but not to the point of being unsafe.
Colin
Old 02-27-2014, 08:25 PM   #7
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Saw one at Timeless in Denver that had been raised a huge amount. The owner wanted it raised up since he took it into rugged terrain in the Dakotas as I remember.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 02-27-2014, 08:27 PM   #8
Thanks. I've got two axles on my 1979 that I am hoping to do this summer.
Extending axle mounting plates rugjenkins Repairing/Replacing Floor &/or Frame 1 02-16-2014 06:22 AM
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
