Old 02-29-2008, 05:07 PM   #99
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Well, there's another option as well (from reading) that seems a winner as well. One can order the #10 axle and upgrade JUST THE SPINDLE to #12 (to get the bigger brakes) and get what one wants........ (from Dexter ..... ) No cutting of the mounting plate required.
Marc
Old 02-29-2008, 07:47 PM   #100
Somewhere , Indiana
Yep!
Originally Posted by adonh
How do they "de-rate" an axle?
Don
Chuck is correct - the length of the rubber cord (or rod) determines the axles capacity! The 4000 - 6000# axle family differs only by rod length!
The shorter the rod the less capacity!
Additionally, Marc is correct also - by placing a longer rod in a #10 axle, the capacity can be increased!
The 4000# axle would however be a larger and stronger tube body - in simple terms more "heavy duty'' all around!
Good thread all!
axleman is offline   Reply With Quote
Old 02-29-2008, 08:26 PM   #101
munimula's Avatar
1993 34' Excella
1962 16' Bambi
New Haven , Connecticut
Having read every post in this thread y'all have provided confirmation that i did the right thing by letting my local RV repair shop handle my single axel swap for me. in that it's a relativly quick project, labor should come in at 2 hours tops or $160.
however, the info gleaned here is invaluable when the time comes that i have to swap out my 3 axles on the 34. with that job the labor costs will add up.
not to stir the pot too much - my repair guy swears i won't need the shocks.
thanks for sharing!
munimula is offline   Reply With Quote
Old 03-08-2008, 12:45 AM   #102
TOM CRUMP's Avatar
1970 27' Overlander
Braxton , Mississippi
Images: 26
My Overlander needed axles back in 2006 and I put the whole job on a local Dexter dealer. He had previous experience installing Dexters on Airstreams. And to him it was all pretty routine. He spec'd the #11 Axles derated to 3600# with 22.5 degree down angle, 12'' brakes and Nevrlube sealed bearings. I went along with the dealers recommendations because I knew if there was a problem, it would be on him. He did explain that I would need 4 new Dexter wheels to accomodate the Nevrlube bearings, this was OK with me because I needed new tires (Marathons I bought from Tire Rack) When my dealer called Dexter placing the order he spoke with a Dexter engineer in Indy, who he knew on a personal basis. Three weeks later my axles were delivered. What surprised me the shock mounts were factory installed, but my dealer said I would NOT need shocks I would think the shocks would only contribute to a more smooth ride, although I've been running without shocks and have no complaints at all and don't have the chore of repacking wheel bearings. And the total bill for axles, new brake assemblys, wheels, Nevrlube bearings and labor was $1300. Job well done.
ID:	55717   Click image for larger version
TC
TOM CRUMP is offline   Reply With Quote
Old 03-08-2008, 12:59 AM   #103
TOM CRUMP's Avatar
1970 27' Overlander
Images: 26
Nevr-Lube Bearings
ID:	55720   Click image for larger version
TC
Old 03-08-2008, 08:25 AM   #104
It's interesting to read the opinions of some owners and non Airstream dealers, that shocks are not needed.
That would be against the design criteria of Airstream engineers, in spite of using torsion axles.
Most of those dealers don't have a clue as to the principal of construction of an Airstream trailer. If they did, they would tell you that shocks are necessary.
Shocks DO help the trailer have a softer ride, which an Airstream trailer loves.
When it comes to the purpose of shock absorbers, the name says it all.
Cars, trucks or trailers with torsion axles, all need working shocks.
Old 03-17-2008, 01:23 PM   #105
maccamper's Avatar
1974 29' Ambassador
1966 20' Globetrotter
Central , Illinois
to shock or not to...
Andy, our '74 did not appear to have been originally equipped with shocks. When I put new axles on, should I try to retrofit some shock mounts and install them? Thanks once again.
maccamper is offline   Reply With Quote
Old 03-17-2008, 01:40 PM   #106
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
It is interesting because my dealer has made a similar statement. Supposedly he says is that the shocks are there because as a premium priced product, the consumer expects to see shocks there. He noted that based on their placement and angle, they provide minimum motion dampening. In a normal vehicle a shock reduces the vertical bounce of a wheel where the axle is cushioned by by coil or leaf springs. In a dura-torque axle the rubber rods within the axle are purported to provide the necessary resistance to offset the bounce.
I may be wrong but didn't Airstream produce a trailer in the last 10 years that didn't have shocks? For some reason I thought it may have been the early CCD's. There are obviously differing opinions out there.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 03-17-2008, 05:35 PM   #107
1975 Argosy 26
1963 24' Tradewind
That would be the 22ft CCD. I'm not sure if the current 23s have them or not.
Marc
Old 03-17-2008, 05:41 PM   #108
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Jack
I find it funny that Airstream would put shocks on a trailer when they are not needed but for many years sold trailers without a spare. I don't believe Airstream is known for adding extras to a trailer because the consumer expects to see them there. I can name a few things I would expect to see on a quality product which are not there. I have to agree with Andy.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 03-18-2008, 04:34 PM   #109
Never lube
We use a company that has 18 warehouses in the USA.
Amoung many other things, they handle Dexter axles as a distributor.
We asked them about Dexter Never lube hub and drum assembly availability.
Since a regular hub and drum will not fit a Never lube spindle, what does a person do when traveling, if they needed a Never lube hub and drum.
Their answer was that they would have to order it, as none of their 18 warehouses, stock the 12 inch Never lube hub and drum.
Our suggestion then is for those that may choose the Dexter axles with the Never lube bearings, to buy a spare Never lube hub and drum assembly.
In that way should you have a failure, you will have a replacement with you.
Old 03-20-2008, 09:45 AM   #110
Central , Mississippi
no real progress
Well,
No physical progress so far. I'm looking forward to getting some new axles under Epiphany and running the final round of tests. I may pull the existing shocks off and see if I can measure any ride difference with the existing axles ...nah, it's spring and I'm goin' camping...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 03-20-2008, 10:38 AM   #111
HiHoAgRV
Sometime back, you said you would also report how much time you have spent on the replacement Dexter axles.
Please include the time you have spent with your credit card company to get the original charges reversed.
I would assume that you will have to start all over again, with Dexter.
If we can help you with axles, please let us know.
We guarantee the right axle, the first time, and all we need is just the trailer serial number.
No hassles, no drawings needed, no specs to provide, guaranteed fit, no need to reverse credit card charges, and no need to fight over meeting the axle specs for the trailer, and no problem increasing the start angle or weight capacity.
Sorry that your having so many problems with your replacement axles.
We can only offer you encouragement to hang in there.
Old 03-26-2008, 07:02 AM   #112
Back in post #60 I displayed a graph that showed a 3 hz bounce in the recorded data. That has been buggin me and this morning on the way to work I saw an example of what was going on. I got behind an enclosed trailer with rubber suspension and noticed the hub never moved up and down relative to the body as the trailer hit rough sections. The tires were taking all of the beating and seemed to be bouncing up and down about 3 times per second !
I now suspect my suspension is so stiff that it is unable to absorb any shock, similar to a flatbed trailer with no load.
axles katsix Axles 20 11-23-2007 09:53 PM
New Axles LHall Axles 10 10-06-2007 08:43 PM
Do I need new axles? Barbara Peerenboom Axles 11 12-19-2005 10:48 AM
New axles? mtnman All Argosy Trailers 1 12-02-2005 07:23 PM
Do I need Axles??? blucloud Axles 3 08-16-2004 06:23 PM
