Old 02-14-2008, 06:56 PM   #15
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Here's something else I've been thinking about. If you have a double or triple axle camper, do you need to make seperate measurements for each axle?
www.nesa.org
Air No. 6427
Old 02-14-2008, 07:00 PM   #16
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
I wouldn't think so or Andy at InlandRV would have the 2nd and/or 3rd axle listed on his website with and appropriate $$$$$ figure posted.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 02-14-2008, 07:30 PM   #17
Central , Mississippi
Henry Ford's Method
Mine is a double axle and I have using some self devised guidlines...
1) neither Airstreams
2) any axle manufacturer
-Could or would spec/provide product that has a tolerance of +- 1/8 inch or tighter on these type of measurments (no flames, it's my OPINION ).
I'm also 100% sure all of the axles on a particular trailer were intended to be the same dimensions so I kinda averaged and gave it my best shot, just like they did.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 02-14-2008, 07:59 PM   #18
Status
Here's where we are tonight. I've got a couple of really nice axles that won't follow the install process I intended to document, sorry folks . I'm hoping to get a favorable response to a mistake (made by me or the dealer) and get this thing back on track. The dealer is making an honorable effort to see what can be done. Actually, the manufacturer really doesn't HAVE to do anything because they built a product EXACTY as they were requested, keep your fingers crossed...
Just to keep priorities straight, we made camping reservation for this weekend
Old 02-14-2008, 08:19 PM   #19
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
Hub face on my 73 and 86 is 80". the easy way to check is measure from center of tread to center of tread on tires while sitting on level surface.These trailer have zero offset rims. I've not measured the inside frame rails but I'm thinking the outside measurement may be 62". This would eliminate the 3/8-3/4 thing during the manufacturing process. And if you're getting disc set up as others here have mentioned some of the rims do not fit, so now you could change the hub offset and get a larger selection of rims. Just a few thoughts.
This is a good thread, hope it stays civil.
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 02-14-2008, 08:20 PM   #20
Got gandkids?
Dang, I wanna ask what happened, but is it safe to do so?
www.nesa.org
Air No. 6427
Old 02-14-2008, 08:21 PM   #21
GreatPumpkin's Avatar
Colville , Washington
Images: 70
Originally Posted by HiHoAgRV
So at this point I want: (Here is the cheat sheet info…)
Axle Capacity: #11 axle derated to 3600 lbs. (stock is 3500 lbs, I wanted extra capacity, the #11’s are bigger that the stock, and come with the other options I wanted below)
79 7/8” Hub Face Dimension
61 3/8” Outside Bracket spacing
Bracket Orientation: Reverse, High Profile Side Mount, “HP-Rev (O)”
12” electric brakes. The stock ones work fine, no reason to change.
Hub & Drum Size: 12” 6X 5.5 with ½”-20 studs
Nev-R-lube hubs
35 degree down angle (per some Forum discussions this sounds good, but not really mandatory. SEE BELOW WHERE THIS ENDED UP!)
And for the stuff you WON’T get off of the Dexter website:
Shock Option E-1492
I wish I saw your post earlier, the bracket is extra and redundant, creating it's own set of "opportunities" when installing. See post #57 of http://www.airforums.com/forums/f437...nts-34646.html
and post #136 on of http://www.airforums.com/forums/f157...-22741-10.html
If you found out about the double secret Shock Option, I strongly suspect you have had some help from a very helpful forums member who also provided me with a lot of good advice and help.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 02-14-2008, 08:29 PM   #22
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
This is kind of a stupid question, but if you ordered it with the side mount hangers (which are unneccessary), are they still on the axle? And if so, is it just a matter of removing the side mount hangers to have your 61 - 3/8".
What does the white sticker spec from the factory say?
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 02-14-2008, 08:36 PM   #23
Images: 70
Originally Posted by PizzaChop
This is kind of a stupid question, but if you ordered it with the side mount hangers (which are unneccessary), #1 are they still on the axle? And if so, #2 is it just a matter of removing the side mount hangers to have your 61 - 3/8".
#1 Yes.
#2 No. I had to leave them on. The 61 - 3/8" included the extra bracket so removing them would have left an extra 1/2" (1/4" on each side)
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Old 02-14-2008, 08:41 PM   #24
After reviewing your posts (and every other axle post ) I tried to minimize the fluf but ended up with the extra brackets anyway. I summize that the reverse option INCLUDES them no matter what (they may end up being used in my case...)
Yup, the first thing I noticed when I pulled the Pick Sheet was OB=61.75... WAIT, THATS NOT RIGHT! The welded brackets are in fact at 61.75, not the 61.375 that I need.
Old 02-14-2008, 08:44 PM   #25
Originally Posted by GreatPumpkin
...If you found out about the double secret Shock Option, I strongly suspect you have had some help from a very helpful forums member who also provided me with a lot of good advice and help.
We all seem to have our sources.... , and they are all the same
Old 02-14-2008, 08:46 PM   #26
#1 Yes.
Not true in my case. The welded ones match the spec sheet, 61.75
Adding in the bolted brackets gets me to just over 62"
Old 02-14-2008, 08:53 PM   #27
PizzaChop's Avatar
1973 31' Sovereign
Images: 202
Pumpkin,
But I'm wondering if this is Vern's problem. My axles were produced exactly as spec'd at 61-3/8". I can't remember if the hangers were on or not (I think they were). The actual OB measurement on mine were about 61-3/4" until I removed the side mount hangers.
But the white tag on the axle will tell the truth (rating, OB, Hubface)
See below
Ron Kaes
Psalm 112
www.paparonnis.com
Old 02-14-2008, 08:56 PM   #28
PizzaChop's Avatar
1973 31' Sovereign
Images: 202
Code:
Adding in the bolted brackets gets me to just over 62":angry:
Okay...maybe not..
Ron Kaes
Psalm 112
www.paparonnis.com
axles katsix Axles 20 11-23-2007 09:53 PM
New Axles LHall Axles 10 10-06-2007 08:43 PM
Do I need new axles? Barbara Peerenboom Axles 11 12-19-2005 10:48 AM
New axles? mtnman All Argosy Trailers 1 12-02-2005 07:23 PM
Do I need Axles??? blucloud Axles 3 08-16-2004 06:23 PM
