I found this article in the August, 1989 edition of Airstream Caravanner magazine, and thought it would be a nice addition to the archives. While the image contains "continued on next page", that page is not included as it only listed Service Centers.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC www.balrgn.com www.balrgn.com/Airstream.htm
Pretty cool design...
What happens when the rubber wears and the inner axle overrides the rubber?
Obviously it is time for replacement, but what if you are far from home?
Can you drive like this?
What design are the axles on my 89?
Thanx for the info, Bill
Life is Good-Camping all around New England
Good people drink good beer-Hunter S Thompson
Driver only carries $50...worth of ammo.
Tom
The following article tells you how to check your torsion axles.
We have changed hosts, therefore some things may take a little time to correct themselves.
Thanks Andy, I was confused as the diagram did not show any shocks-my axle has shocks! If your torsion arm angle is biased toward positive (a sign that your axle is going) is it also true that your wheel height relative to the body/wheel well will be changed (the wheels will be up inside the well?) Would you also notice a rough ride/bottoming out?
I checked my axles and the torsion arms are what I believe to be positive angle-not good! Unless I am interpreting this backwards…
Here is what I see; Torsion arm angle is up (rear “\” front not rear“/”front) going toward rear of camper, but wheel to wheel-well height is fine and ride of camper is fine. I also believe that this camper does not have a lot of miles/use. (All other signs are of minimal use; body, interior, upholstery, etc)
Am I interpreting this backwards?
Thanx, Bill
Thanx, Bill
Bill.
Your describing torsion axles that are gone.
When torsion axle rubber rods fail, for whatever reason, the trailer "will bottom out." When that happens, many different damages can and will happen. I just talked to a fellow this morning, who wasn't aware of his axle problem, but now he knows. His problem, is that the frame and axle mounting plate are severely cracked. Cause? Bad axles.
When the rods go bad, the wheels rise into the wheel wells, which is the same thing as the trailer becoming closer to the ground.
Mileage has nothing to do with the rods. Lack of mileage, which means little to no rubber rod movement, will cause a set to take place. Some owners have learned that the hard way, even on trailers less than 5 years old.
From 1974 and older Airstream trailers, the rods were made with composition rubber rods, that within themselves, would fail.
Additionally, if any torsion axle has a load imposed upon it, such as that caused by parking the trailer for a long period of time, the rods will take a set becasuse the rubber was not exercised.
Torsion axles must be exercised. If not, they will take a set.
That set can be avoided, when a coach will be parked for a long period of time, by taking most of the weight "off" the axles, using lifting type jacks, or jack stands, placed on the frame.
Stabilizing jacks cannot lift enough weight off the axles to avoid the problem.
Andy, I am going to remember your tip after I get the new axels installed. You did say put thejacks on the frame...any tips on where and how much pressure? I realize that this is sort of a generic question and there will be some variety according to the trailer size. In my case the old camel is a 25' dual axel.
I am assuming that the lifting jacks should relieve pressure and not lift the trailer very much???? Common sense tells me near the wheels but I have been wrong before!
Also thanks for all of the extra help you gave me. I will document the installation, if a somewhat disabled type like me can do it that should tell the able bodied something! I am actually looking forward to the project (plus getting on the road again).
Hi Andy, with your additional info I crawled back under there tonight; camper has been sitting since for about 2 months since last moved. Torsion arms, according to the diagram, are maybe 5-10 deg negative, which is good, but not by much. Wheels do not appear to be receeding into wheel well, camper does not sit too low.
Is this normal for a 25' of my vintage ("heavy") after sitting for a couple of months? (Camper is in winter mode, no fluids, but still lots of other stuff; all the appliances,etc)
Towing, the ride seems smooth as silk...
I will check the offset when we move her again in a month or so...
Next year, I will use jack stands for the winter...
As Smokin asked "where exactly to place jackstands"?
Thanx for your expertise,
Bill
Good morning Andy, any response on our last 2 posts?
Sure could use the info...
Thanx again, Bill
Storing a torsion axle trailer long term, is very different from "spring" suspension systems.
Place a jack under the axle mounting plate. After most of the weight is off the wheels, place a "jack stand" under the axle mounting plate, rearward of the "rear" tires. For a larger trailer, you can also place a jack stand forward of the front tires, again at the bottom of the axle mounting plate.
"DO NOT" attempt to lift the trailer with the stabilizing jacks. The are not designed for that stress and will quickly break.
Storing a "lifted" torsion axle trailer for years, will have no "ill" effect on the rubber rods, but instead, will preserve them.
Bill
Bill.
Check the position of the torsion arms, when the trailer is fully loaded.
When fully loaded, the torsion arms must not go above parallel to the chassis. If they do, then the party is over.
Additionally, even parallel torsion arms, suggest some deterioration of the rubber rods.
