Old 03-08-2007, 05:51 AM   #1
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Down angle
Anyone know how much the height changes of the trailer if you increase the angle say 2, 5 or 7 degrees greater than the 22 1/2?
'77 Sovereign Intl 31' CB
Old 03-08-2007, 06:28 AM   #2
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Leo, what I'm trying to ask is if I have new axles made with an angle greater than 22 1/2 standard how much will the height under the belly or axles increase at various increases in the torsion arms?
Old 03-08-2007, 06:50 AM   #3
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Bob, the 22.5* axle will deflect with weight as will the other angles. It's difficult to say how much gain you'll have in ride height as the axle GVWR and your trailer weight will influence that as well. I don't think anyone can give you a definitive answer of "5.75" inches for example.
Andy may be able to give the best estimate as he does this all the time and he may have some "norms" figured out.
Depending on how worn out your current axle is though, you may see an increase in bottom-of-coach to street height of several inches with a new 22.5* and perhaps up to another two inches with a 45*, again depending on the way the axle is rubbered.
Roger
Roger
Old 03-08-2007, 06:55 AM   #4
empresley's Avatar
1984 34' International
1977 Argosy 24
Central , Georgia
Bob,
Using some basic geometry the important number in the following formula will be the length of the articulating arm. (the connecting arm from the center of the wheel to the axle beam) I did not go out and measure but for our example we will use 12".
example: if the articulating arm is 12”
you multiply 12" times the sine of 22.5 degs (.38268)
The sine of 22.5 deg. is .38268 multiplied by 12 equals 4.59"
The sine of 24.5 deg. is .41469 multiplied by 12 equals 4.97"
the sine of 26.5 deg. is .44619 multiplied by 12 equals 5.35"
So… each 2 degree increase will give you a rise of .38 inches.
To make the example work in real numbers you need to know the actual length of the articulating arm.
I think...
em.
Travelers by aluminum roadships, loyalists to one species,
masters of convenience, herdsmen steeped in maintenance and restoration.
empresley is offline   Reply With Quote
Old 03-08-2007, 07:15 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
The other consideration that influnces the height of the trailer is the load rating of the axles. I just changed mine from the original 2800 lb. axles to 3200 lb. axles and raised the trailer about 3 in. I my case the the original axles had gone to a negitive angle because they were under rated when originaly installed at the factory.
If you are using Henschen axles they can give you good advise on angles and loading.
2004 Excursion 4x4
Old 03-08-2007, 08:33 AM   #6
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Ok, great info that what I was looking for.
I think I'll add 4 degrees to get about 3/4" more ground clearance than stock.
Who knows it may extend the point in time they need to be replaced again????
Old 03-09-2007, 05:48 AM   #7
1973 23' Safari
Maryville , Tennessee
Images: 13
I was told going from 22.5 to 32.5 raises the trailer about an inch....about an inch for a 10 degree difference.
kneal is offline   Reply With Quote
Old 03-09-2007, 07:37 PM   #8
1993 30' Excella
1993 19' "B" Van Airstream 190
Apache Junction, AZ
Changing from stock to 35 degrees raised our 30' about 1 1/2 - 2 inches, but we had failing axles when I first measured. Henchen has charts (or did) on their web site which you can use to calculate the lift. The axles are only available in standard angles...you can't specify the number of degrees you want (or so I was told).
n7bdl is offline   Reply With Quote
Old 03-09-2007, 08:14 PM   #9
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I went with 32.5 down angle, and it raised my 63 Overlander an approximate actual 1.75in.
This is hard to answer precisely, since the axle rating and load in the trailer also change the ride height. But for a given set of weights in a given trailer, exoect an ride height increase of about 1.5in for a 10degree increase in down angle.
Uwe
www.area63productions.com
Old 03-09-2007, 08:48 PM   #10
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
I don't remember the dates exactly, but I think around 1980 or so Airstream changed the down angle of their axles from the old 22.5 degress to something like 10 degrees. This lowered the trailer heights relative to earlier years. And since axles are rated for the unloaded angle, once the trailer (and contents) are put on the axles, their resting angle changes quite a bit (I think more than 10 degrees is typical). Anyway, I mention this, because I have never seen a 1980's or newer Airstream with a positive axle angle, even pretty new ones. They are all negative and yet the amount of tire showing in the wheel well looks correct. I do not believe the old adage that "your axles are shot if they have a negative angle" applies to 1980's and newer Airstreams. That of course doesn't mean that they are not shot if the angle is negative, it just means that this method of determining if they are shot is not valid. If you put a 22.5 degree angle axle under a 1980's or newer Airstream, I think you will raise it above the original factory height. You can verify this if the ball height ends up more than 18.75" with the trailer level. As I remember it (didn't check recently), either the Henshen or Dexter web site lists both original and loaded angles for their axles.
In any case, since your trailer is a 1991, the angle may not have indicated that your axles were shot. Of course if they were over loaded, they may have sagged more than usual.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 03-09-2007, 11:06 PM   #11
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Another fact to consider is that some Airstream axles had high profile axle brackets, which raised the frame about 1in over the axle tubes. This might not apply to trailers built after 1980, because I have only seen these brackets on late 60's and early 70's trailers.
Uwe
Which is worse when towing, trailer angle UP or trailer angle DOWN? Streamer1 Towing, Tow Vehicles & Hitches 33 09-19-2006 08:43 AM
Hitch angle? Krazykraut General Motorhome Topics 2 07-01-2004 02:53 PM
Extreme Angle Backing Airstreamer67 Our Community 11 05-19-2003 08:45 AM
Hitch angle? working Hitches, Couplers & Balls 2 05-16-2003 06:33 PM
Replacing Metal Box for holding tank Mike Waste Systems, Tanks & Totes 11 10-26-2002 03:40 AM
