Old 11-15-2006, 04:07 PM   #29
Originally Posted by TomW
Andy,
I never wondered if you had an Airstream because I figured you did. But I have wondered what year & length Airstream you had.
Tom
1967 28 foot.
Old 11-15-2006, 04:36 PM   #30
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Thumbs up I knew there was something about you I liked
1967 ...
You have made me smile.
Tom
Old 11-30-2006, 10:58 AM   #31
aproned dad
roamingwesty's Avatar
1968 17' Caravel
Carmichael , California
Images: 12
Catagory: '68 Caravel for $800. Here's the clue.....
During the return trip from San Felipe Mexico back to Flagstaff AZ this Thanksgiving weekend, our '68 Caravel developed some consistant brake drum noise. Sounded like a spring or some such rubbing the drum. The brake controller then became connected only intermittently, indicated by its LED display. We had to be home and made made our way carefully with no further problems - except that after we parked it and entered a few times to clean it, now the door won't open from the outside. A few searches led me to believe that the door issue could be just a symtom, pointing to the root cause of a worn-out original axle. This may be the time to replace it. I also worry about other problems I couldn't see with a newbie eye. It's probably time for a pro inspection to make sure all else, such as the frame, is intact and not damaged.
Immediate concern is the axle. I haven't gotten the weather to go take a more detailed look yet. But as soon as the day temp gets higher I'll be taking the wheels off and get the process started.
I'd like to ask Andy, if I were to order the axle from you:
What information would be required for a hassle free bolt-on procedure?
(Serial number, pictures of the existing axle, the shock mounting positions, and..??)
The info I gathered here in the past couple of days showed me 3 possible options with the hardware itself: Dexter, Axis or Herschen. I'm thinking Herschen for the stock compatibility, but would like to avoid the extra steps Clancy Boy had to take.
I'm ok with wrenching, having 4 old VWs to work on all the time; that's also where the habit came from to get the OG stuff as often as possible, or the closest to it.
Thanks.
Ricky
p.s. As to opening the door I will see if I can weasel in from the electrical access panel on the street side, underneath the bed/couch. After this Arctic cold front passes over.
roamingwesty is offline   Reply With Quote
Old 11-30-2006, 11:12 AM   #32
Thanks.
Ricky
All we need is the trailer serial number.
Old 11-30-2006, 11:36 AM   #33
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Andy,
Your post #20 states " Serial numbers provide detail specifications, but not for the 66-67 and 68 Caravels."
Don't you need more information for roamingwesty's 1968 Caravel?
Bill
Just my personal opinion
Old 11-30-2006, 11:38 AM   #34
Originally Posted by wkerfoot
Andy,
Bill
That issue for most part, has been resolved.
Old 11-30-2006, 11:47 AM   #35
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Thanks.
Ricky
If you're looking for an easy exchange just remember - you are trying to replace an axle for a 38 year old trailer from a manufacturer that has been bought and sold twice to a trailer design that has been changed several times over the years (and sometimes in the same year) and has no modern variant with what has to be a one off production axle that is 90% correct for your application. Some modifications and adaptations should be and probably are required - just be prepared for it. The end result is you will be much happier you did the change and will end up with a road worthy trailer to enjoy for 40+ years to come.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 11-30-2006, 03:35 PM   #36
Contrary to opinion, the new owners of Henschen, past or present, have not changed a single thing with respect to the manufacture of the torsion axles.
The retro fitting the new axles to the older trailers, is aboyt as simple as one can get.
Old 11-30-2006, 05:16 PM   #37
aproned dad
1968 17' Caravel
Images: 12
Honestly, Andy, I don't know what that means. Do you mean Henschen users are happy and loyal to the brand name, or they don't need to tweak/drill/weld to fit?
From what I have read/was told, the Henschen axle manufacturer does not supply replacement axles with any tailoring for an EXACT fit to my '68 Caravel. By tailoring I mean the new axle's shock absorber brackets will ALWAYS come on the opposite side (for my Caravel)as opposed to where they were on the stock axle brackets, so the 'cut and weld' of the brackets, for my trailer at least, is unavoidable -- Even if I took so detailed pictures that I can see Jesus in brake dust, the pictures won't prevent me receiving a Henschen axle that needs cut & weld.
Is that a fact of life, Andy, that for Caravels, especially mine, the brackets will need to be fixed/repositioned if I wanted to put shocks back on? Others too might want to know how the replacement will fit their different vintage year trailers, but I need to know for my Caravel; I want to take everything into consideration. Please tell.
Also, the Henschen fitting problems for '66 to '68 Caravels, as you said earlier, have been mostly resolved. Would you mind telling me what were the problems resolved, and what remains unresolved?
I don't mind drilling holes to fit the new axle on, don't mind getting Henschens even if it's more expensive, and Henschen axles do have a great feedback from the threads I read so far. Just want to know all about it so I stand firm by my desicion is all.
Again, thank you.
Ricky
Old 11-30-2006, 05:35 PM   #38
Somewhere , Indiana
Seems high?
I finally received an estimate for a new axle on my 68 Caravel. The estimate is for $1600. It is a single axle.
I found this shocking and appalling. Could this be accurate?
Geno
Geno,
Sounds a bit high - check:
http://www.airforums.com/forum...p-24964-2.html
Specifically post #12 - perhaps a PM to Mr. Crump is in order!
Just two cents from a retired axle dude,
Henry
axleman is offline   Reply With Quote
Old 11-30-2006, 07:30 PM   #39
Ricky
Ricky.
The 66-67 and 68 Caravels from Ohio and California, were if you wish, different in many ways.
Henschen builds axles to specs. Our specs, Airstream or whoever.
Henschen has no idea what axle will go on what coach when Airstream orders them.
The axle mounting issue for the 1968 and older trailers is caused by a change in 1969 of the mounting bracket.
We now ask, but only for the 66-67 and 68 Caravels, the shock position, since we now know that they varied considerably back then.
Other than that, drilling three 1/2 holes on each side takes care of the mounting. The alignment is automatic when the new axle is placed into position. Instructions are sent with each axle purchased for the 68 and older models regarding the new holes.
The shift from Henschen to Dexter was done by Thor, not Airstream. It was done because of internal silly differences, that have long been resolved.
The facts are that Henschen, this spring, will be the primary supplier of axles to Airstream, once again, especially on the larger models.
Airstream and Dexter do not have the congenial working relationship that one would think.
Word has it about a recall and product failures, as well.
As a dealer, we cannot spell out the existing problems. That, Airstream will do, in their usual moderated way, in due time.
For anyone on the outside to make guesses as to the cause of separation of Airstream and Henschen, is fool hardy at best.
There are a number of rumors being promoted, possibly to satisfy personal egos about the entire matter, of Airstream, Henschen and Dexter.
Most Airstream owners insist on replacing like for like, to keep their trailer in the Airstream family as much as possible.
There are many others who for their particular reasons, chose otherwise. Sometimes it's money and sometimes it's a "I will show you" kind of thing.
Airstreaming is a very large industry, and in time, it has gained many many different owners, with many different philosophies.
But the most important factor, is that the "way of life" continues on and on, and flourishes very well, since an agreeing as well as a non-agreeing owner, still make up the "family."
That family moreso than ever, travels the country, proudly towing their Airstream or Argosy, which keeps the Airstream image on the front line for the public at large to see.
That, makes Airstream happy.
And me too.
Old 12-01-2006, 11:52 AM   #40
aproned dad
1968 17' Caravel
Images: 12
Ricky.
Why do I feel the loving and pitying gaze from the mother duck telling that odd duckling, "Sorry, you're just, um, special.."
Thank you Andy. I will ask whatever questions left (mostly regarding the shock brackets still) when I am ready to get on the horn. Our weather is turning for the better so I should find out after the weekend what's wrong and what fixes are necessary.
And to you folks east of me, stay warm.
Ricky
caravel
2010 23d Int. Does this price sound right? Jezibels Buyer Guidelines 8 10-12-2009 06:49 PM
Buzzing sound from sound system, walking on floor makes it stop. foqus Electrical - Systems, Generators, Batteries & Solar 9 08-24-2009 08:22 PM
Right Rear Tire Wearing on Outside & Right wheels Closser together than left wheels Tnsawdust General Repair Forum 7 04-10-2009 07:49 PM
Straight Axle vs Drop Axle Sound off. soldiermedic Axles 12 03-24-2009 06:39 AM
The right acid works with the right applic got polish Cleaning, Stripping & Polishing 1 07-17-2008 08:50 PM
