Closed Thread
Old 12-04-2006, 05:09 PM   #1
1973 23' Safari
Maryville , Tennessee
Images: 13
Does this look like I will need a new Axle?
Overlander 26 Footer...Can you tell by the pics if the axles look like they are bad?
ID:	29404   Click image for larger version
Name:	Overlander Axle2.jpg
kneal is offline
Old 12-04-2006, 05:22 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
You most likely have torsion axles. Yes, they are very low and need to be replaced.
Richard
azflycaster is offline
Old 12-04-2006, 05:28 PM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Axel?
Yes!
Melody Ranch is offline
Old 12-04-2006, 05:33 PM   #4
MW64OVERLANDER's Avatar
1964 26' Overlander
Norman , Oklahoma
Images: 67
The short answer is yes, the axles are probably bad. With out knowing the exact year of that trailer, mid to late sixties I'm guessing, the question you should always ask is "Do I have any suspension?". If you jack the trailer up, do the axles even move. My guess is you will have little or no movement of the trailing arm. These are rubber torsion axles and they are over forty years old. They have a life expectancy like the other rubber parts of the trailer. One of the best investments and improvements that I made on my 64 Overlander was to replace the axles, but you have to base that decision on your own observations of your own trailer. Hope that was of some help.
Mark
Mark Wilson
1964 Overlander/2000 f250 Crew Cab 4X4 PS WBCCI# 5600
MW64OVERLANDER is offline
Old 12-04-2006, 05:34 PM   #5
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Curbside looks more sunk to me. Bottom line, yes, they look like they need to be replaced.
Silvertwinkie is offline
Old 01-16-2007, 11:03 AM   #6
1971 27' Overlander
albion , California
Mark
I'm new to this. I have a '72 overlander 27" what ball park price can you give me for axle replacement.
Thank you
Dclary@mcn.o is offline
Old 01-16-2007, 11:35 AM   #7
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
OK, you have another yes on this one. Looks like you have a 4" sag and the rims also look like split rims as best as I can tell from the photos. But be Happy! New axels are a good thing. If I have learned one thing, everytime you replace an item on a Vintage AS it is definatly one less thing to worry about; and that is a good thing. Keep us posted on what and how you do it!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline
Old 01-16-2007, 01:05 PM   #8
1964 26' Overlander
Norman , Oklahoma
Images: 67
Thank you
I can only speak from my own experience. I purchased the axles from Andy at Inland RV and paid approximently $800.00 for each axle. Shipping for both axles was about $200.00 and I did the install myself. You can find the axles cheaper from other sources if you are willing to do some research and measurement and use a brand other than the original Henschen axle.
For me, it was more desirable to pay more and get the original axle.
Hope this helps.
Mark
Mark Wilson
Old 01-16-2007, 03:40 PM   #9
Overlander & Sea's Avatar
Gulfport , Mississippi
Images: 30
That is what my axles looked like when I purchased my '61 Overlander. I also purchased new axles from Andy at Inlandrv. It's made all the difference & it's worth the money.
Rick--Airstream of Mississippi www.foleyrvcenter.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline
Old 01-16-2007, 04:19 PM   #10
Thank you
Depends on what quality you want and how much engineering you "do not" want to do.
They go from $250.00 (very iffy quality and safety), to $800.00 original equipment.
The old Sears thing, ?????, good, better and best.
Inland RV Center, In is offline
Old 01-16-2007, 06:40 PM   #11
Somewhere , Indiana
Yes!
Considering what the axle does and what’s riding on it – I would replace it!
Regards,
Henry
axleman is offline
Old 01-19-2007, 09:25 PM   #12
stanton66's Avatar
1968 30' Sovereign
1960 24' Tradewind
1951 21' Flying Cloud
Norwich , New York
yes they need replacing.you will be amazed at how well your airstream will ride with new axles.if you need any help call chevy ave. restorations 607-334-4253.
stanton66 is offline
Old 01-20-2007, 05:58 AM   #13
1975 27' Overlander
High River , Alberta
I recall that Inland RV's $800 per axle deal gives you complete brake assemblies. Worth considering because your brakes are probably due for a complete overhaul too, and you'll save a lot of time and trouble just replacing everything at once.
Also, if you buy something else and are not careful you can end up with rubber torsion axles without shock absorber brackets. I bought a trailer like this, and learned firsthand that shocks do make a significant difference in trailer ride (smoother tow, less porpoising and rocking). They are beneficial for the structure of the trailer too.
AlbertF is offline
Old 01-21-2007, 08:47 AM   #14
Somewhere , Indiana
Two cents!
If you need an axle or two (and dont have $1000 each laying around or want to fool with doing the install yourself) this is worth checking out
http://www.airforums.com/forum...elp-24964.html
Regards,
Henry
axleman is offline
Closed Thread
Duratorque Axle Replacement Andy R Axles 18 03-19-2017 08:54 PM
Tag axle shock rdm Mechanics Corner - Engines, Transmission & More... 8 07-10-2008 07:15 PM
Who made my axle? Pahaska Axles 44 07-25-2007 10:08 AM
one or two axle? vallan1980 Airstream Trailer Forums 5 09-17-2002 05:47 PM
Axle Offset Question DanLyle Axles 11 08-28-2002 09:35 AM
