Old 03-16-2011, 03:41 PM   #1
1980 20' Caravelle
Coeur d alene , Idaho
Do I need a new Axle ?
Alright, I already started soaking the nuts. The second picture shows I only jacked up the hub around 2 inches before it started lifting the trailer. Am I right it should have flexed around 4 or 5 inches? It has a 3000lb axle is there any reason to change that spec? Thanks, Don
Name:	IMG_3638 (Small).jpg
ID:	124653   Click image for larger version
Name:	IMG_3655 (Small).jpg
Name:	IMG_3658 (Small).jpg
glacierrunne is offline   Reply With Quote
Old 03-16-2011, 03:55 PM   #2
rideair's Avatar
Sorry to say, it's time to write the check. Cha-Ching!
Paul Waddell
rideair is offline   Reply With Quote
Old 03-16-2011, 04:45 PM   #3
Mexray's Avatar
1978 28' Ambassador
Morada , California
We 'lock hubs' all the time around here regarding axles...do a quick search and you'll find plenty of threads to occupy your evening hours by the fireside...
As another that as been there - done that (replaced em')...it does look like it's your turn!
Enjoy - not all that difficult a job...we went with the 3,500# capacity replacements - the original's were 3,000# units...get the complete set-up with new hubs, drums, brakes, etc - you'll have some nice new stuff to roll down the road for another 30 years!
Ray & Pat; Morada, CA
Old 03-16-2011, 04:54 PM   #4
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
I did a dozen axles last year for people and I didn't find one that moved more then 1". If you are not making long trips, constantly on the move, that 2" will be OK for a few more years.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 03-16-2011, 05:30 PM   #5
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I could tell by how my trailer rode, it was getting pretty beat up, rivets popping, drawers coming open, pillows tossed around.
It rides so much better now, just floats along behind us. And it wasn't hard to put a new one on - because I paid someone else to do the work
Stephanie
Old 03-16-2011, 05:43 PM   #6
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Just my 2 cents
But I also saw the rivets popping in the area directly around the axle. It unrolled the TP and the ROLL TOWEL.OPENED DOORS and the frige. Things were thrown around the coach. Mine stayed in the same position when I drove the front axle up on three stacked 2x8's. I gained 4 inches in ground clearance and the destruction inside the coach stopped after I made the axle change.
DO WHAT EVER YOU THINK IS RIGHT>ITS YOU WHO WILL PAY.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 03-16-2011, 05:52 PM   #7
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
I hope that photo of a bottle jack under a piece of boken match lumber under the brake drum is a joke, or: Please get out from under that trailer until you show us a photo of some safe jacking practices. Please
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 03-16-2011, 06:50 PM   #8
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Single axle, thirty something years old.. If you don't mind too much spending the money a new axle would be awesome!
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 03-16-2011, 07:28 PM   #9
Splitrock's Avatar
Sioux Falls , South Dakota
All a trailer is, is a metal frame and axles and some kind of a deck or body. Axles seem sort of important to me. On the other hand . . . I'd never ask a barber if I needed a haircut unless I wanted a haircut.
Old 03-16-2011, 07:57 PM   #10
1980 20' Caravelle
Any comments on if I should go to a 3500 rated axle or stay with a 3000? After seeing all the mess in the interior after a 300 mile trip I needed to check the axle. Thanks for all feedback! Don
Old 03-16-2011, 08:00 PM   #11
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
Those of you that have done this...did you have to do any alignment or is there no adjustment? You bolt them in and go.
Tom
"Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid." -- Frank Zappa
tlavergne is offline   Reply With Quote
Old 03-16-2011, 08:02 PM   #12
DanielB's Avatar
From Andy's (Inland Rv) comments I gather that there will be a min and a max rating that is advisable for a particular trailer.
- Andrew Carnegie
Old 03-16-2011, 08:06 PM   #13
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
I would move up to the 3,500. Here is my very own axle thread. Since you only have one axle, I'd make sure it was new if you have the money to make it that way. Good luck, and all the best to you.
Lance
Top is offline   Reply With Quote
Old 03-16-2011, 08:14 PM   #14
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
This nominal size of axle can be rated from 2500 lbs to 3700 lbs, so you can request whatever you like in 100 lb increments. What you should request depends on what, if any changes you are planning for the restoration & how that effects the overall weight. Keep in mind that the load rating you choose will not effect the cost, providing you stay within this range.
Colin
Colin H is offline   Reply With Quote
« Axles | Top | Spindles »
Video - Successful Axle Job on 1964 Safari JitneyBead Axles 10 05-21-2012 09:07 AM
Axle weights limits vs. combined weight - What am I missing? Section8 Towing, Tow Vehicles & Hitches 25 02-15-2011 07:46 PM
