Old 03-16-2011, 08:14 PM   #15
Baltimore , Maryland
Originally Posted by tlavergne View Post
Those of you that have done this...did you have to do any alignment or is there no adjustment? You bolt them in and go.
Tom
Yes, there is a small amount of slop there. Put a wire loop around the jack to hook on a tape measure. Run back to the hub centers and measure the centers.
Old 03-16-2011, 08:15 PM   #16
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Tom
Bolt them in & go.
Colin
Colin H is offline   Reply With Quote
Old 03-16-2011, 08:27 PM   #17
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
Great. I'll probably be calling you some this summer Colin.
Tom
"Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid." -- Frank Zappa
tlavergne is offline   Reply With Quote
Old 03-16-2011, 09:31 PM   #18
Originally Posted by glacierrunne View Post
Alright, I already started soaking the nuts. The second picture shows I only jacked up the hub around 2 inches before it started lifting the trailer. Am I right it should have flexed around 4 or 5 inches? It has a 3000lb axle is there any reason to change that spec? Thanks, Don
The axle rating can be upgraded, within reason, depending on what you traveling game plan may be.
Also, the starting angle can be changed to help rigging to a high profile tow vehicle.
Do not reduce the brake size to 10 inches. Stay with the 12 inch brakes.
Old 03-16-2011, 09:46 PM   #19
Colin H's Avatar
1959 28' Ambassador
1949 24' Limited
Peru , New York
Tom
Great!
Colin
Old 03-17-2011, 07:25 AM   #20
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Axles...
Originally Posted by Colin H View Post
Great!
Colin
I actually just picked up my axles last night! Bought them through Colin. I had to get 2, but they came completely assembled, strapped to a pallet. Just drove down to a local shipping terminal and they loaded them right up. The forklift guy asked what they were going on, and then I left about 30 minutes later He suggested a campsight that was off the beaten path hosted by a farmer that just likes people to come enjoy his spot by the river, but he doesn't put up with any mess! Meaning, he likes you to pack it in and pack it out, but enjoy yourself when you're there.
Anyway, the axles looked great. All powder coated and ready to go. Now I have to get the old ones off, Por 15 the frame, and bolt on new ones.
robwok is offline   Reply With Quote
Old 03-17-2011, 10:39 AM   #21
Any comments on if I should go to a 3500 rated axle or stay with a 3000? After seeing all the mess in the interior after a 300 mile trip I needed to check the axle. Thanks for all feedback! Don
You should consider going with 3200 pound axle, with 12 inch brakes and at least a 32 degree starting angle.
Old 03-17-2011, 01:35 PM   #22
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I put a 3500 lb Dexter axle on mine in 2004 and I've been very happy with it. There was some concern that it might be too stiff, but that hasn't been an issue.
Stephanie
Old 03-17-2011, 01:44 PM   #23
Steph.
All torsion axles are too stiff.
And, all torsion axles are inadequate for the payload.
It all depends on the loading.
Each person, must determine, within reason, the total payload that will be imposed on the axle/axles.
In that way, a fair judgement call can be made as to the rating of a replacement axle/axles.
As an example, some owners insist on a full tank of water, others travel with no water aboard.
For that matter, full water should always be carried, as it lowers the center of gravity of the trailer, which helps it track better, and, in the event of a blown radiator hose, all you need is a little duct tape, and of course some of that water, that hopefully, is in the trailer.
Old 03-17-2011, 03:55 PM   #24
1980 20' Caravelle
Coeur d alene , Idaho
Andy and Colin, thanks for all the great information! Don
glacierrunne is offline   Reply With Quote
Old 03-17-2011, 04:45 PM   #25
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Andy is a big fan of duct tape.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 03-17-2011, 05:14 PM   #26
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
I prefer 2" Tape, pressure sensitive adhesive, OD green NSN 7510-00-890-9872
Lance
Top is offline   Reply With Quote
Old 03-17-2011, 06:01 PM   #27
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
Regardless what you choose for an X jack the trailer up enough to work comfortably and block it up fore and aft well. Good solid base, cribbing is worth the effort. Bottle jacks only can get real tippy. Once up and stable changng the X really is easy. Things can go bad quick if the axle is down and you need more height or start to loose a jack point.
putback is offline   Reply With Quote
« Axles | Top | Spindles »
Video - Successful Axle Job on 1964 Safari JitneyBead Axles 10 05-21-2012 09:07 AM
Axle weights limits vs. combined weight - What am I missing? Section8 Towing, Tow Vehicles & Hitches 25 02-15-2011 07:46 PM
