Old 03-19-2012, 12:21 PM   #1
idaramin's Avatar
1975 31' Sovereign
Dallas , Texas
Do I have an axle issue?? Wheel issues when reversing trailer on slant
Hi all- Newbie here! I have a 1975 Airstream Internation 31'. Currently the ship is empty (removed all interior for my studio). When we picked up the airstream from the PO we didnt have the issues listed below...
Yesterday we were leaving our storage facility and when we reversed on a hill we heard a pop and then realized one of the tires was not rotating in reverse...it was stuck. Then another pop and the airstream drop down a little, the tire was back on the ground and reversed just fine. This only happened when we were on a slope. We drove the airstream around the parking lot and it reversed just fine on flat land.
We recently greased the bearings and replaced the seals. Also got all 4 new tires that have less than 20 miles on them.
I dont know if my husband didnt tighten something enough, put something on wrong or our axles just decided to die on us. It just started to do this so I thought something may have gone wrong in changing tires or servicing the bearings.
I understand that these are old axles and we should probably consider replacing them....just want to see if it could be something else that would stop the tires from turning....
Thanks!
Thanks!
idaramin is offline   Reply With Quote
Old 03-19-2012, 12:27 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Rusty Brakes
Old 03-19-2012, 01:26 PM   #3
Thanks!
Thanks!
Sounds lik rusty drums.
Also the following will help you check out the axles.
The Dura-Torque Axle
Old 03-19-2012, 01:46 PM   #4
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Thanks!
Yeah, sounds like your brake shoes have rusted to the drum & broke loose when you backed up, and yes your axles are likely sagged out being this old, but old axles don't react like this, they typically have very little "give" left in them.
Colin
Colin H is offline   Reply With Quote
Old 03-19-2012, 01:49 PM   #5
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Rusty brake drums are the most likely culprit.. I also have had the problem with the brake arm where the magnets attach dragging , but only on the brakes with the oval magnets. This created a reverse wheel lock up problem. Grinding a few thousands off the arm where the oval magnet attaches fixed it.
I suspect your 75 may still have the round magnets though
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 03-19-2012, 02:08 PM   #6
idaramin's Avatar
1975 31' Sovereign
Dallas , Texas
Rusty drums it is- ill take a look at it this week. Any suggestions on where to order replacements and what parts I need? Thanks for your input!
Old 03-19-2012, 02:19 PM   #7
Splitrock's Avatar
Sioux Falls , South Dakota
Check your breakaway switch.
Old 03-19-2012, 03:53 PM   #8
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
You can clean the rust off the inner services with sandpaper or a wire wheel.
Breakaway switch would not likely be the problem as the brakes would be on forward and reverse. Even if the wheels would turn you would feel like you were pulling a rock and any distance you moved more than around the yard would get things hot and smelly
13 Ram 2500 TD
Dexter Axle replacement ljmorr3 Axles 17 03-29-2013 01:42 PM
Question on 2nd /AC or generator input mefly2 Electrical - Systems, Generators, Batteries & Solar 9 06-18-2012 08:04 AM
Our Turn for Floor Rot - Do We go to Ohio? Frank&Mike Repairing/Replacing Floor &/or Frame 50 05-23-2012 06:18 AM
02/12: New Tire Discussion on Woodalls: LT versus ST and more. slowmover Tires 128 04-10-2012 05:09 PM
First time with an Equailizer thecatsandi Hitches, Couplers & Balls 81 03-28-2012 10:35 AM
