Old 08-22-2010, 06:18 PM   #15
Addicted
exthemius's Avatar
1971 27' Overlander
Currently In: Skowhegan , ME
Images: 16
I know, Tom's the one who had it and did the work -- that's why I'm puzzled -- I totally think he would have caught shot axles.
-Shawn
TAC OK-42
Visit our crazy full-timing blog (us,kids and dogs living the dream): http://www.airstreamingdreaming.com/
Join us at the TAC Walt Disney World Rally, November 4th - 10th, 2012: http://www.theairstreamersclub.org/rallies/tac-fw-wdw
exthemius is offline   Reply With Quote
Old 08-22-2010, 06:23 PM   #16
Originally Posted by garry View Post
Check with Griffith RV in OK City he is a specialist working on Airstream and does outstanding work.
There is a factory frame kit for reinforcing the frame at the axles.
Griffith RV Recreational Vehicle Service - Oklahoma City - (405)-495-2590
Garry.
The "frame beef up kit" does not eliminate rear end separation.
For most part, all it does is separate you from some of your money, and creates a false sense of additional frame security.
Axle mounting plates sometime show up with a ripple, which is caused by the axle mounting plate not being properly welded to the frame.
If someone wants to change the tandem axles out to say 5000 pounds each, because they will be creating a trailer that will be used for a restaurant business, or the like, then the axle beef up plates would be in order.
But for normal use, NADA.
DIY or go pro panel replacement truckasaurus Ribs, Skins & Rivets 28 03-06-2017 12:36 PM
Axle Replacement went well. tkasten Axles 2 07-22-2010 04:17 PM
Another Axle Replacement The Flintstones Axles 6 09-06-2007 12:38 AM
Axle replacement Pick Axles 92 02-18-2006 08:27 PM
Axle Replacement ??? FC54 Axles 6 10-10-2003 05:01 PM
