Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 10-01-2012, 05:11 PM   #1
Green Lake , Wisconsin
Differences In Running Gear
I am contemplating purchasing an Airstream travel trailer. I have a general idea of the differences in the interiors between various models such as Safari, International and Classic. I would like to know if there are any differences in the frames and axles, etc. between the models. My guess is that there probably isn't much difference but I really have no information on this.
wisconsin is offline   Reply With Quote
Old 10-01-2012, 05:16 PM   #2
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
They are for the most part the same design. If you are looking at vintage trailers, there were some design changes over the years, but not much since 1961 or so.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 10-01-2012, 05:44 PM   #3
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
I had heard the Classic has a heavier frame but have never seen anything specific about it. However if you pick a year and do a search the specs reveal some info. For example a 2012 27FB Flying Cloud has a GVWR of 7600# while a 2012 27FB Classic has a 9000# GVWR. Remember, GVWR is the maximum allowable weight for the trailer and whatever you put in it. Part of that comes from the axle ratings, but I can't tell if the frame is different.
A couple less obvious differences is the Classic's freshwater tank is 15 gallons larger and a pair of 40# LPG tanks are now standard. Maybe someone else can say if there are other differences under the skin.
AIR 47751
Silver Goose is offline   Reply With Quote
Old 10-20-2012, 08:20 AM   #4
Keep in mind, that the strength of an Airstream is in it's shell.
That's the principle of "monocoque construction" or as the case may be for Airstream, "semi-monocoque" since the shell side to side does not make a complete structural circle.
Therefore, the frame (chassis) can and is lighter than would be required for a SOB travel trailer.
Also, since the shell flexes when in motion, the chassis must also flex with it.
Beefing up the chassis, when a complete make over project is taking place, is not always a good idea, since the shell and it's attachment to the chassis, must also then be "beefed up".
If not, in time,major failures will occur.
One of the more recent huge helps is the availability of balancers such as Centramatics. They do not solve "every" out of balance issue, when scalloped tires are still being used, or with some of the old style 3 piece drums, that are known to be as much as 3 pounds out of balance, but they do solve the issue for the vasr majority of owners.
That takes care of the issue of finding a shop that can properly balance the complete running gear.
We have been amazed at their popularity amoung Airstream owners.
Andy Rogozinski
Inland RV Center
Corona, CA
