03-14-2013, 10:51 AM
1996 28' Excella
Portland
, Oregon
Dexter Torsion Axle Lift Kit
Dexter makes a 2-5/8ths and 3" lift kit for Torflex axles.
You can find the installation instructions here: http://www.dexteraxle.com/i/u/614960...x_Lift_Kit.pdf
I also found an aftermarket kit listed on Amazon, but it's an old listing
Dexter Torflex #11 Torsion Axle Lift Kit - Amazon.com
Looks like they're made by this company in TX. They offer a $79 kit for #10 axles, but I didn't call to see if they have one for #11. I assume they do becuase the Amazon listing was for #11. I imagine the differences will be a thicker sidewall block and 5/8ths hardware.
perfectcasita.com
There is a way to get a higher ride height without just ordering new axles with a higher start angle. This would actually be a better option because you can keep the the loaded arm angle at a more desired 0 degrees.
Disclaimers: (or frankly, don't waste your breath)
1. Raising your Airstream will raise the CG (center of gravity).
2. Raising the CG will contribute to inducing sway or PIO (Pilot Induced Oscillations).
3. Raising the CG will reduce emergency handling characteristics.
4. Raising the coach will increase air resistance and decrease fuel economy.
5. Raising the coach will most likely require raising the TV ball height accordingly.
6. A lift kit is no replacement for warn out axles. If the rubber has solidified in any torsion axle it should be replaced.
7. Raising the coach may require adding another step so Great Aunt Mildred can get inside.
8. Lifting an Airstream could induce scoffing from Airstream traditionalists. Mutterings of "Clown!" and "Humph!" could and may be heard under-breath.
9. Some Airstreams need to have the undercarriage tank protection skins modified for clearance because there is some interference with the axle bracket.
10. It should be noted that the pictures listed here are for regular mounted bracket orientation. Airstreams use "reverse" side bracket mounting which would make threading the side bolts into the nuts inside the block kind of tricky.
-Kevin
1996 Airstream Excella 28'
2007 GMC Duramax 4x4 CCSB
03-14-2013, 11:04 AM
Common Sense
Those lift kits are popular with Casita owners because they typically have an issue with draining the holding tanks, and some folks desires to be able to go farther off road. Those that have changed seem to be happy with the change.
Regards,
Steve
03-14-2013, 12:57 PM
1981 31' Excella II
New Market
, Alabama
Might be a good idea with longer trailers that tend to drag tail on the slightest incline.
Perry
1974 Argosy 28
Fresno/Clovis
I like #7.
Roger
03-14-2013, 01:40 PM
1981 31' Excella II
New Market
, Alabama
I don't use my lower step anyway so adding 3 inches would make that lower step usable.
Perry
03-14-2013, 02:31 PM
Corona
perfectcasita.com
-Kevin
Kevin.
It appears from your photo's that the axle torsion arm, with no load on it, is parallel to the mounting bracket.
That says, the rubber rods are history.
Adding a lift kit is OK, but it will not take the place of good axles, nor will it provide a soft ride for the trailer.
Therefore, the shell will take a beating when the coach hits bumps.
Adding that lift kit, to new axles or axles that still have serviceable rubber rods, is an entirely different situation.
03-14-2013, 02:42 PM
1977 31' Sovereign
1989 34' Excella
Johnsburg
I agree the proper answer for this unit was to replace the axles with ones with proper down angle and load rating.
03-14-2013, 03:12 PM
1996 28' Excella
Portland
, Oregon
What unit?
None of the pictures in this thread are of my trailer. They are pictures from the advertisements for the lift kits that I listed.
-Kevin
03-14-2013, 03:21 PM
Corona
What unit?
For the unit that's in your photo's that you posted.
Unless that's not your Airstream.
03-14-2013, 03:27 PM
1996 28' Excella
Portland
, Oregon
Kevin,
Andy,
Agreed.
I thought this information might be useful to someone with good or new axles looking for a lift solution.
I searched for hours on this forum for ideas on lifting the ride height and all I found were hundreds of answers; and they all basically said: "Buy new axles".
-Kevin
03-14-2013, 04:02 PM
1981 31' Excella II
New Market
, Alabama
I think the lift kit makes sense if you are trying to get more ground clearance and it is better than increasing the starting angle too much. The kits should not be used to get ground clearance back resulting from a bad axel. My trailer is not riding lower than normal and it drags the tail on gentle inclines entering and exiting gas stations.
Perry
03-14-2013, 06:12 PM
1996 28' Excella
Portland
, Oregon
Sorry if I wasn't clear. None of the pictures in this thread are mine. For that matter, none of the pictures in this thread are even an Airstream.
The first one is from the installation instructions for the Dexter lift kit.
The 2nd one is from the perfectcasita.com kit, assuming that's a Casita trailer.
I used them as an illustration for the products.
Perry,
Yes, I think it's a great alternative if you have good axles, but not enough ride height.
-Kevin
02-13-2015, 04:31 AM
Aftermarket supplier
Duncanville
Perry
Perry,
Just curious - did you ever add a lift?
--Jim
02-13-2015, 11:38 AM
Regular Guy
1978 31' Sovereign
Hot Springs
, Arkansas
Thank You Kevin.
02-13-2015, 01:30 PM
2007 22' International CCD
Corona
Bump to follow
03-12-2015, 09:25 AM
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
Wanting to lift my 2010 27fb for driveway clearance, how do I know which axles I have? 10? 11? 12???
Thanks!
08-24-2015, 06:33 PM
Senior Member
Sparks
, Nevada
Follow up: axles are 11s on a 27FB. Kit went on quite easily by myself. No apparent change in towing behavior but I tow with an F350 so your results may differ. Very happy not to be dragging arse in the usual places.
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
08-24-2015, 08:52 PM
Mission
Photos!!!
01-25-2016, 11:47 AM
explorer
On the Road Full Time
, Utah
Originally Posted by nrgtrakr
Photos!!!
x2, I've been wanting to see a few pics of a taller airstream.
01-25-2016, 12:09 PM
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
I would love to see a 27FB lifted, what kid did you use? 2 or 3" - also do you still have 15 inch tires or 16 inch tires?
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
