Old 03-26-2016, 01:48 AM   #85
1996 25' Excella
Central Coast , California
Dexter Torsion Axle Lift Kit
sheriff1, sorry to hear about your friend. This was my first time jacking up the trailer and I don't think I would do it the same again.
I left the rear tires mounted while installing the spacer on the front axle, but realized I hadn't jacked the trailer up high enough to remount the tires on the front axle after the spacer was installed. Rather than raise the height at that point, I elected to go ahead and install the rear spacers and raise the height once I was ready to remount the tires on both axles.
jwgilesjr is offline   Reply With Quote
Old 03-27-2016, 08:15 AM   #86
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
When I did the tire swap on the 25FB in a storage unit, I worked on one side at a time. I took one wheel off and installed the steel wheel spare and then removed the second wheel and took them to CostCo for the swap. The jack stand was supporting the trailer and the spare was there just in case. I replaced them in the same manner and did the other side the same way. The third trip took care of the spare.
When doing things like this alone, I try to keep safety paramount as I have read too many unfortunate stores when common sense is ignored.
Old 03-27-2016, 01:04 PM   #87
explorer
2010 30' Flying Cloud
On the Road Full Time , Utah
I didn't want to put the entire weight of the trailer on an axle that was rated for half that weight, so I used jackstands under both sides of the frame. I had the hydraulic jack under there as a secondary safety, but I felt quite safe the entire time. Just make sure your jack stands and jack are rated for the weight of the trailer.
explore more is offline   Reply With Quote
Old 03-27-2016, 02:38 PM   #88
1976 31' Sovereign
Oswego , Illinois
dexter lift kit
Tandem axle AS can be towed with one wheel off when tire is flat for short distance, so won't damage installing lift kit. The trailer is not moving and bouncing like on road, besides I don't trust any jack stands etc. I pull one wheel on ramp of boards, either one side or both to do what I work on, with axle on ground and blocked it's not in danger of falling or worry of possible damage to frame when jacking.
Old 03-29-2016, 08:37 AM   #89
explorer
I know the old ones could do this, can the new ones do this too? Of so, that's fantastic news
Old 03-29-2016, 08:38 AM   #90
explorer
Here's my install video. Hopefully it helps, since Airstream installs vary from the instructions a bit.
Old 03-29-2016, 08:47 AM   #91
1976 31' Sovereign
Oswego , Illinois
Smile dexter lift kit
Why not the axles are same as previous years.
Old 03-29-2016, 12:30 PM   #92
explorer
The axles are the same, but the trailers have gotten a lot heavier.
I'm new to airstreams, so my assumptions may be way off. I actually hope my airstream can handle running with 3 wheels for a while.
I'm also not sure how axles are rated. I would assume a 5000lb axle would be rated to hold 2500lb per wheel.
So take a 8880 lb trailer. Let's split the weight down the middle, for 4440lb per side (for simplicity's sake).
Now let's say you remove one of the curb-side wheels. The road-side would have 4440 lbs on (2) axles rated at 2500lbs each,so it'd be fine.
The curb-side would have 4440 lbs on an axle rated at 2500 lbs. I imagine that would wreak havoc on the rubber dowels, and possible the spindle of the axle.
I could be wrong though, I'm just trying to think of it logically.
To be honest, I'm hoping my "logic" proves wrong, and we find out it's still kosher to run with 3 wheels for a bit without doing damage, as that would really open a lot of options in a blowout or flat tire situation.
Old 03-29-2016, 12:43 PM   #93
explorer
Here's one more video of the pros and cons of lifting your trailer (according to me). Common sense for a lot of people, but a lot of our viewers haven't ever considered lifting their trailer. This may help some newer users make a decision. Plus it's quite relevant to this thread.
Old 03-29-2016, 12:59 PM   #94
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
I am pretty sure nothing on a trailer running gear is even from side to side or front to back. explore more, you might want to weight your trailer at each tire individually to find out how uneven your current set up may be.
In the event a tire/wheel assembly was not functioning on a dual axle trailer traveling a short distance and extremely limiting speed would be needed to protect the 3 remaining tires and wheels. (Assuming a spare tire change was not possible immediately)
>>>>>>>>>>>Action
Old 03-29-2016, 10:49 PM   #95
explorer
one person commented on the YouTube video asking if I weakened the grade 8 bolts by welding to them. I looked it up, and sure enough, welding to a grade 8 is a no-no. I torqued it down to spec, and it's holding, but now I'm thinking it'd be a good idea to replace these with fresh grade 8's and find some other way to keep the bolt head from spinning. Any ideas?
Old 03-29-2016, 10:57 PM   #96
2007 22' International CCD
Try a steel wedge driven in hard with a hammer into the space between the head of the bolt and the lift block sides? I can see that welding to a hardened bolt could degrade it because of heat.
Or cut off a cheap box end wrench, tape it in place, and leave it in there. Worth the few bucks it would cost.
KE4GNK/AE
Old 03-29-2016, 11:24 PM   #97
explorer
I've thought about cutting up a few 15/16" wrenches. I'm digging these:
http://www.stage8.com/amc.html
Since I only welded to part of the hex head, I wonder if I weakened the "core" of the bolt, or just the area I welded. They're BIG bolts, and the heads never got red-hot, but I still want to make sure I'm safe and not putting others in danger when I'm on the road.
Old 03-29-2016, 11:46 PM   #98
Those bolts with the lock ears might be an even better idea. Nothing to rattle around much or fall off. If they are cheaper than a wrench from harbor freight why not try them, assuming you can get them in.
KE4GNK/AE
