Old 04-24-2016, 10:43 AM   #127
1964 24' Tradewind
Lawrence , Kansas
Yes, tack welded. Not sure it was needed but went ahead anyway.
ttbikes is offline   Reply With Quote
Old 06-13-2016, 06:24 PM   #128
Boxite's Avatar
2008 22' Sport
Originally Posted by Inland RV Center, In View Post
It's much easier to look at the trailing arm, or torsion arm at it's position.
When it's parallel to the ground or even nearly so when the trailer is empty, that's it. THey have served their useful life.
It would be much harder for the shocks to be parallel, and even if possible.
Andy,
I've visited the Dexter Axle website after looking at my 2008 22' Sport axles (which have about 10-degree NEGATIVE angle of the trailing arm) and find that Dexter actually makes axles which START OUT at MINUS trailing angles. Their 4100-6000 lbs axles are #11 axles and the trailing angle can be specified.
I have a hard time believing my axles are "worn out" after only 8 years of (mostly) storage and less than 10K of travelling.
Dexter's website also specifies a 3" travel for the upper edge of the tire to any contact with the trailer and mine certainly meets that spec also.
I do want greater clearance and am trying to decide on which lift-kit to order (since they only sell them for tandem axles and I have a Bambi.) Their No. 11 axle (which is what is on my 22' Sport) has dimensions that cannot be met by their single-axle kit for #8 axles (the only single kit they offer.)
I have the ability to make my own but would rather simply buy what I need. Does your company offer a single-axle lift kit which fits the #11 axle?
Thanks.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 06-13-2016, 07:24 PM   #129
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Visually looking at the angle of the trailing arm is a quick method of check the health of an axle. The better method is to raise the trailer and measure the drop of the axle.
>>>>>>>>>>>>>Action
Old 06-13-2016, 08:16 PM   #130
Boxite's Avatar
2008 22' Sport
>>>>>>>>>>>>>Action
Apparently it's not just a simple matter of seeing if the trailing link declines or not... as Dexter made all kinds of different angle axles, from 42 positive to 24 negative angles, in each model of axle. Dexter.com
Rambox
Old 06-13-2016, 09:31 PM   #131
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Like I stated, it isn't the best method to determine the condition of the axle. If the trailer is not yours and you are considering buying it. (Or some other reason) And you don't have permission to lift the trailer it has some merit. Especially if the observation is the trailing arm is in the downward position.
Lifting the trailer and observing axle drop is the single best method for determining condition.
>>>>>>>>>Action
Old 06-14-2016, 01:17 PM   #132
Boxite's Avatar
2008 22' Sport
>>>>>>>>>Action
I understand you, I think, ... the only thing I was attempting to express is that the actual/original specification of the axle/installation is necessary to "eyeball" it for the trailing edge angle. A "downward" position is NOT universal at all.
My 22' Sport has a 10-degree UPward trailing angle and is designed to be such. Anyone looking beneath it and seeing that might conclude the axle is worn out, when in fact it's just fine.
Rambox
Old 06-23-2016, 04:29 PM   #133
SilverEagle6's Avatar
2013 25' Flying Cloud
2008 30' Classic
On The Road To Wherever We End Up , Traveling the USA
After install report
Installed the lift kit a couple months ago on a 2008 30' Classic Ltd. since then have towed about 1,000 miles. Absolutely no negative impact on driving/towing. I knew a couple pitfalls were the effect on stabilizers and step. Neither of these I view as negative. I knew the jack would be different and I am thankful that my jack has an 18" travel. I have to add nearly three inches of block to my jack stand. Note: I also have have 16" Michelins.
We have just started on a long 1.5 - 2 year journey so I wanted in make sure that after the install the alignment was good.....and it was not. Had it corrected at Jackson Center.
Very happy that the lift kit was installed and thrilled of the added height at hook up and dump time.
Jeanne and John, and always with us...Jake
2008 30' Classic Ltd Rear twin, 2014 Ford Super Duty
WBCCI 3100, unit 12, TAC USA-1, Escapees 129379
https://instagram.com/silvereagle3100/
SilverEagle6 is offline   Reply With Quote
Old 06-24-2016, 08:52 AM   #134
explorer
2010 30' Flying Cloud
On the Road Full Time , Utah
We had to get ours aligned as well. Cost $200.
It was pretty close left and right, but the camber needed some adjustment(which means it needed adjustment from the factory too).
2007 Ocean Breeze 23D "Reynold"
1997 7.3L Diesel Ford 4x4 High-Top Van, Fred
Follow our journey living and working from the road full-time: https://themoreweexplore.com
explore more is offline   Reply With Quote
Old 06-24-2016, 11:00 AM   #135
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
John called and described the alignment and it sounds like actual axle alignment was corrected slightly but axle position somehow inexplicably was good. Not sure how that happened.
John & Jeannie travel safe. Go find that largest ball of twine and take its picture. RT 66 still needs explored.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 06-25-2016, 02:26 PM   #136
1972 27' Overlander
If it doesn't sag at that point, could it also mean the 40year old shocks are probably bad. Shouldn't the torsion axle drop without the shocks in place?
Or will it drop even with bad or good shocks in place?
sir_tob is offline   Reply With Quote
Old 06-25-2016, 03:04 PM   #137
2016 30' Classic
Lorton , Virginia
Any way to put the axle lift on without ruining the alignment? Reference marks?
Zybane is offline   Reply With Quote
Old 06-26-2016, 09:57 AM   #138
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
My trailer frame was notched firmly and precisely placing the axles. I simply used a carpenters framing square to drop the notch location onto the new material.
My axles are well enough aligned that the tires wear perfectly even, and my trailer pulls dead straight.
Close enough for me.
Superat stultitia.
Old 06-27-2016, 01:30 PM   #139
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Good or bad original type shocks have no influence on total axle movement with one exception. The shocks are there only to slow the movement not to prevent movement. The exception is if the shocks are frozen in place which is a rare event. The more likely event is internally there is no more resistance and that is a bad shock as well.
So if the shocks are on, the axle will still drop assuming the rubber rods are in good condition. It may take slightly longer for an axle to drop with the shocks on however the amount of time is maybe a minute or two.
>>>>>>>>>>>Action
Old 06-27-2016, 08:30 PM   #140
2016 30' Classic
Lorton , Virginia
Superat stultitia.
J, good idea. I think I will do the same and deal with an alignment afterwards if it needs it down the road.
