Old 12-04-2010, 10:12 PM   #1
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Dexter Toroflex
I'm liking the product literature on these.
Anybody know or hear anything about these axles?
A lot of people use Dexters I gather. We have a Dexter place here in Charleston, SC which seems like a big plus as well.
Second question. My Excella has a GWR or whatever of 7100 lbs. My new chassis is going to have straight C5x6.7 C channel with no holes to reduce weight. The interior will be a minimalist type interior, which will be less weight from "furnishings" and what-not.
Should I be looking at 4000-6000 lb axles?
DanielB is offline   Reply With Quote
Old 12-05-2010, 09:58 AM   #2
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
I installed 4500lb Henschen axles on my 77 and trailer rides great. It weighs 7500lbs loaded and Inland RV suggested going a little higher on the axle rating.
4RXLA is offline   Reply With Quote
Old 12-07-2010, 05:12 PM   #3
DanielB's Avatar
I called down to the Dexter place today.
For the Dexter Torflex (torsion axles-don't use shocks) 3500 lb:
Axle, hub, and brakes $405 each.
The sizes that they have are 3500, 5200, and 6000.
I wonder if the 5200s are too much and the 3500s too little...?
Old 12-07-2010, 05:16 PM   #4
Not a pound over 4500 #, as per Airstream.
Old 12-07-2010, 05:31 PM   #5
DanielB's Avatar
Well.. that probably eliminates that option.
Old 12-07-2010, 05:36 PM   #6
Trex's Avatar
1981 20' International
Shasta Lake City , California
Dexter torsion axles
I am in the same boat with my 72/31', my 38 year old axles are ready for replacement. So, I also need to know which wt. rated axles should I buy. Trex
Trex is offline   Reply With Quote
Old 12-07-2010, 07:38 PM   #7
Excella's used a different rating than the standard 31 foot international models.
Old 12-21-2010, 07:11 PM   #8
DanielB's Avatar
More info.. the
GVWR is 7100 lbs
GAWR for each axle is 3200 lbs
so 3500 lb axles should be fine.
Old 12-21-2010, 09:11 PM   #9
More info.. the
GVWR is 7100 lbs
The original axle rating for Excella's is 4000 pounds.
Old 12-22-2010, 04:51 AM   #10
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
DanielB,
Check the tag on the axle for the rating otherwise you could take the GVWR, subtract 10% and then divide by two and round up to get your axle minimal rating. As Andy has stated before you can generally upgrade the axle rating approximately 10% from the stock rating. So a stock 3200 would be ok at 3500. I believe the largest you can get the #10 axle is 3500 but it comes with 10" brakes. If you go to the #11 axle then you can get 12" brakes but a minimal rating of 3600 lbs. The #11 axle also comes with a larger spindle and bearings.
You can custom order the #11 Dexter axle in the 4000 lb rating if this is what you need.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 12-22-2010, 06:37 AM   #11
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Axle rating
They can down grade your # 11 axle to any rating you want,also they say 22.5 and 45 deg.axles only.One of our members said you can talk to them and they will do the 35 deg.axle.
I found out a 5/8 hole saw works a lot better at drilling the holes than a drill bit,no hanging up like a bit. Dave
easyride is offline   Reply With Quote
Old 12-22-2010, 06:51 AM   #12
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
After calling both dexter and Inland RV I installed Henschen axle on my 65 Safari. It did cost more money but was the right size, right angle and had the larger heavy duty 12' brakes. Only had to drill a few holes and a drill bit (a good one) worked fine for me. Only wished I had a torch to remove the old bolts. I was also able to save shipping costs as we made a road trip to tour AS factory and then picked up the axle in the same town.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 12-22-2010, 09:34 AM   #13
1967 22' Safari
1978 25' Tradewind
NEW LENOX , Illinois
I have been talking with Dexter for several weeks now including customer service, engineering, Airstream account rep, and sales V.P. The latest is that Dexter will NOT make a #11 axle downrated to 3,000. There was some concern about axle stability when using shortened rubber rods but I have not heard an official reason. Dexter "management" is considering getting into the vintage Airstream axle business but they have not decided. It's a volume issue I am sure, and if they think there will be enough to warrant their effort.
Of course, standard Dexter axles are available, my problem is only the down-grade-to-3,000 lb. for the #11 axle.
The good news is that you can order directly from Axis Products. They are making axles ('beams') for me now, 3,000 lb., complete with spindle for 12" disc brakes and with the horizontal shock mount welded on, and 35 deg down-angle. I am reusing the original Kelsey Hayes 12" disc brakes.
If I understood them correctly, they have the Airstream drawings to fabricate from. The only tough part of this process was for Axis to determine the correct axle. Apparently Airstream used 4 different axles for the 78 Tradewind. Ask for Shannon in customer service. She handled my order and was very helpful. And the price was very good.
John H
johnhh is offline   Reply With Quote
Old 12-22-2010, 12:07 PM   #14
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
Daniel,
Your deeper frame is stiffer and heavier, so it will transmit less inertia to the shell and AS contents. You can feel quite comfortable with uprated axles, compared against someone with a 3" frame, who needs to be a lot more careful.
Personally, I would get the Dexter #11 axle with 12" drums and the 3500 lb rating.
People have all kinds of opinions on this subject. What feels right to you?
TX-16
Dave Park is offline   Reply With Quote
The New Dexter Actuator thecatsandi Brakes & Brake Controllers 1 04-13-2010 12:53 PM
The right Dexter for '71 Tradewind? Lumatic Axles 23 06-05-2008 08:55 PM
Dexter or Henschen binkers Axles 51 04-11-2008 04:48 PM
Dexter Recall anyone? thecatsandi Axles 19 02-10-2007 06:56 PM
new products at Dexter john hd Axles 2 12-28-2003 10:33 AM
