Old 02-28-2008, 05:47 PM   #1
Sheridan's Avatar
1965 17' Caravel
Mountainous , Utah
Dexter order on 1965 Caravel
I just ordered a Dexter axle for my 65 Caravel and during the measuring process, I got two different readings: one with the wheels on and trailer on the ground, and one with the wheels off and the trailer jacked up and on stands (under the old axle). There was about a 1/4" difference which I contribute to the axle tube camber ( the axle spreads out slightly when under the weight of the trailer). I talked to a tech at Dexter and he said use the "jacked" measurement (1/4" shorter) because when they are fabricating them on a bench, the are not under load...obviously.
If I have done something wrong in my measuring, or I'm just stupid, please let me know soon, I can call Dexter and change the order.
Thanks, Dan
Sheridan is offline   Reply With Quote
Old 02-28-2008, 06:23 PM   #2
1962 16' Bambi
Merritt Island , Florida
Will Dexter weld a shock bracket for you? I shopping for an axle manufacturer right now.
C Ray is offline   Reply With Quote
Old 02-28-2008, 06:31 PM   #3
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
I recommend that you use the search tool on the upper blue bar and search axle replacement. You will find many threads about this very topic with varying opinions about what brand of shock would best suit your replacement scenario.
You will find that axles are the subject of some heated debate. Have fun reading
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 02-28-2008, 06:32 PM   #4
GreatPumpkin's Avatar
Colville , Washington
Images: 70
Yes
See post here: http://www.airforums.com/forums/432351-post43.html
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 02-28-2008, 06:33 PM   #5
Images: 70
Thanks, Dan
My measurements were "under load" and came in just fine.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Old 02-28-2008, 06:43 PM   #6
Sheridan's Avatar
1965 17' Caravel
Mountainous , Utah
I asked that question when I called the Dexter tech. First he said I didn't need one, then he basically said "no", we don't do shock mounts any more, the trailing arm or "the bone" (because it's shaped like a dog biscut) is cast not forged like they used to be and dosn't accept a weld as well. However, the welder at GSM Vehicles said he does it all the time with no problem.
I plan to cut the old ones off and have them welded to the new axle and use new shocks....not to improve the ride as much as extend the life of the axle.
Dan
Old 02-28-2008, 06:49 PM   #7
Central , Mississippi
build spec's
I just ordered a Dexter axle for my 65 Caravel ... I can call Dexter and change the order.
Thanks, Dan
The absolute best thing you can do right now is to request a copy of the build spec's from Dexter before it's built. From my experience the axle will match those exactly. If you don't know what some of the notations on the Pick Sheet mean, post them here and there is a GOOD chance some of us can help decode it to assure your order has been processed properly.
Take it from a fellow Forums member, you don't want to deal with an axle that doesn't meet your intent...
P.S. They did shock brackets as of 3 weeks ago...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 02-28-2008, 07:43 PM   #8
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Originally Posted by HiHoAgRV
P.S. They [Dexter] did shock brackets as of 3 weeks ago...
Hi C Ray:
Please be aware that Airstream changed from vertical to horizontal shocks on its Henschen axles around 1967 -- I don't recall the exact year. Do a "Search" for axle shock or other similar word combinations to find my earlier detailed post on that precise topic. Or search under my name for my earlier posts.
NOTE WELL: The shock brackets that Dexter welds on are for horizontal shocks only and do not [necessarily] work with vertical shocks that came on your 1962 Bambi. Be informed before you submit your order!
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 02-28-2008, 08:51 PM   #9
munimula's Avatar
1993 34' Excella
1962 16' Bambi
New Haven , Connecticut
I'm having a new Dexter installed on my '64 trade wind. it should be delivered next week. my installer - South Jersey RV has done many of these Dexter installs and Ron of SJRV swears the shock is not neccessary.
munimula is offline   Reply With Quote
Old 02-29-2008, 03:26 PM   #10
1962 16' Bambi
Thanks for the heads up WeeWind
Old 02-29-2008, 03:34 PM   #11
CanoeStream's Avatar
St. Cloud , Minnesota
I am not worthy...
Originally Posted by 47WeeWind
Hi C Ray:
But I will point the way to Fred's excellent info. He's referring to this thread - http://www.airforums.com/forums/f460...tml#post348754
5 meter Langford Nahanni
Old 03-01-2008, 11:45 AM   #12
Sheridan's Avatar
1965 17' Caravel
Mountainous , Utah
C Ray, This is a picture of the shock mount on my 65 Caravel. I plan to cut it off and weld it to my new Dexter axle when it arrives in about ten days. I'll let you know how it turns out. Thanks to 47 WeeWind for clarifying the transition from vertical to horizontal shocks in the 60's.
Dan
Name:	Shock- mount.jpg
Old 03-01-2008, 01:21 PM   #13
1962 16' Bambi
Hey thanks, I will have to weld mine on to the torsion arm but I'm not sure if the original ones will be long enough because I am upgrading the original 2500# to 2800# and from 22.5 deg. to 25 deg. all this may add up to getting a new set of longer brackets. At least I will be able to measure the old one and repeat the same angle. So, Here's what I ordered.
#10 torsion axle, down-rated to 2800#
Straight beam (with standard toe and camber bends)
74" Hub-face to Hub-face
58" Outside Frame width
Reverse orientation
Side mount hangars
25 deg. down
Electric brakes
10" hubs (5 lugs on 4 and 1/2 centers)
Old 03-01-2008, 02:01 PM   #14
Images: 59
C Ray,
Would you please double check the 25 deg. down angle on your order? I don't think Dexter offers any choices other than 0, 10, 22.5, and 45 degrees.
1965, 1965 caravel, caravel
Almost done with our 1965 Caravel toastie Member Introductions 31 12-30-2007 05:37 PM
A/C for a 1965 Caravel toastie Furnaces, Heaters, Fireplaces & Air Conditioning 9 08-21-2006 07:32 PM
1965 Caravel toastie Plumbing - Systems & Fixtures 1 12-31-2005 03:27 PM
1965 Caravel sunnyhillfarm 1965 Caravel 4 01-28-2004 07:39 AM
