Old 02-04-2008, 06:56 PM   #1
binkers's Avatar
1993 34' Excella
Portland , Maine
Dexter or Henschen
I've read posts from people who've purchased and installed both brands of torsion axles (Henschen & Dexter). I understand that Henschen are a simple install, and Dexters require a bit of work. Everyone seems to be happy with the end result. There seems to be a significant price difference between the two...why should I use one over the other? I am looking at replacing all three axles on a 1993 34' excella, and I'd like to do the most economical thing. Thanks in advance.
binkers is offline   Reply With Quote
Old 02-04-2008, 06:58 PM   #2
soldiermedic's Avatar
Florissant , USA
I don't know about ease of install, but I just towed my new 29' Ambassador yesterday with new Henschen axles at 75 MPH with disc brakes and had NO ISSUES at all.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 02-04-2008, 07:47 PM   #3
Central , Mississippi
Dexters
I expect my new Dexters to be delivered next week and I will do a no-holds barred posting of the entire process, costs included.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 02-04-2008, 07:58 PM   #4
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
I have never seen a 34' that needed an Axle Replacement even units with very high mileage on them. Are you sure the original axles are that worn out? On a 34' there is so little weight per wheel that the axles tend to last a long time.
What is your ball height when the trailer is level?
Andrew
Andrew T is offline   Reply With Quote
Old 02-04-2008, 08:00 PM   #5
binkers's Avatar
1993 34' Excella
Portland , Maine
I'd like to know how you made the decision to buy Dexter?
Old 02-04-2008, 08:02 PM   #6
binkers's Avatar
1993 34' Excella
Portland , Maine
Andrew: I'm just buying the thing. All I know is that the trailer is parked, and the orientation of the axles is positive...according to forum members, this is indicative of axles that are finished, as they should have a negative orientation.
Old 02-04-2008, 08:10 PM   #7
In fairness to others, please include the time "you" have spent on the phone in it's entirety, from begining to end, that it took to order the Dexters, and how many phone calls it took, as well.
To order Henschen, it takes less than 5 minutes, which includes you name, address, phone number, credit card number, and the trailer serial number.
Also, after the fact, how lonbg did it take, total man hours, to install the Dexters.
How long is Dexters warranty.
We will share with you, that at this point, that dozens of Dexter axles have gone bad on 2000 and newer Airstreams.
Old 02-04-2008, 08:26 PM   #8
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
What's that smell......
Time to start making popcorn!!!
crispyboy is offline   Reply With Quote
Old 02-04-2008, 08:37 PM   #9
_
-are u planning to add new brakes too?
-gonna go with disc brakes?
-do u plan to use the original rims?
i like the henschens/kodiaks that came on my unit,
and they DO work with the original alcoa rims...
i think the dexter axle/brake combo is fine product too.
what's the price quotes and dollar difference you've been given?
the henschens for a 93 can be purchased by/from any a/s dealer right?
if the issue is dealing with ONLY ONE vendor 4 the henschens...
the answer is easy, GO DEXTER!
but i'm pretty sure the dexter disc brake will not fit behind your oem rims...
so you'd need to change rims or stick with drum brakes on the dexters...
to figure the 'most economical' approach, you need to include this brake type/rim issue...
cheers
2air'
Old 02-04-2008, 08:59 PM   #10
No Problem
In fairness to others, please include the time "you" have spent on ...Andy
That's what I meant by 'no holds barred'
It will be a 'here is what I did'
'here is what worked'
'here is what went screwy'
no braggin' about the great deal just to feel better about my deal...
just the Facts.
Oh, if things work out, I plan on showing ride quality inside the trailer before and after (really neat equipment... )
Shocks?, we don't need no stinkin' shocks...
Old 02-05-2008, 12:43 AM   #11
gparker's Avatar
1970 31' Sovereign
Denham Springs , Louisiana
Trailer-cam?
Vernon, just what do you have up your sleeve? Can't wait to read all of your posts. As you know, I need new axles too. I don't have enough time or enough tools to be diddling around trying to make something that doesn't fit fit. On the other hand, I don't have a money tree in my backyard to pay for Henschens to be shipped here. Keep us posted on everything, including your research. Tell Mac and Sarah hello.
Greg, Ashley, Olivia, and Jane Ashley
AIR # 13681
gparker is offline   Reply With Quote
Old 02-05-2008, 05:42 AM   #12
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
I just replaced the axles on my AS. The originals were flexing the wrong way, and the trailer looked like a low rider. I purchased the Henschens. The swap took about two hours, including using a cutting torch to remove two bolts that woud not budge with an air/impact gun. They were a direct fit, and make the trailer tow like a dream. New axles, bearings, brakes (drum), and my wheels went right back into position.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 02-05-2008, 10:09 AM   #13
Shocks
Airstream and Argosy trailers love a "soft ride."
When the rubber rods go bad, that ride becomes rough and results in all kinds of damages to the trailer.
Likewise, shock absorbers help dampen the road shock, which maximizes the "soft ride," and goes hand in hand with good axles.
If it has been determined the the trailer is getting a rough ride from bad axles, then according to Airstream engineers, shocks won't eliminate that problem, but not using shocks, will increase the road shock that the trailer will receive, even with new axles, or for that matter, bad axles as well.
New axles within themselves must be within a certain weight rating, so as to protect the frame and shell, from unnecessary road shock.
A rating that is too light is just as bad as a rating that is to heavy.
Original ratings can be increased, to a limited degree, but not more than 10 to 15 percent, except in very special applications, where heavier weights will be carried 100 percent of the time.
Old 02-05-2008, 11:10 AM   #14
I agree that my Airstream would like a smoother ride - the trip to the '08 Can Opener took me down some very rough sections of road and resulted in the kitchen wall pulling away from the shell. Mrs. HiHo announced that I had to do something, I was "tearing up her Airstream" . That plus the fact the trailer has dropped 1 -2 inches in the last year tells me it's time for new axles.
Maybe now my clothes will stay hung in the closet
Henschen Manual. Inland RV Center, In Commercial Listings 6 08-08-2007 05:04 AM
Can Henschen Survive? markdoane Axles 10 10-08-2005 08:26 PM
Henschen Axles hex Axles 37 04-15-2005 06:27 AM
Dexter vs Henschen Ericjeeper Axles 38 03-31-2005 11:16 AM
