Old 10-05-2010, 01:27 PM   #1
2006 30' Classic
Milton , Florida
Dexter Nev-R-Lube Bearing Spare Parts
We will begin extensive use of our 2006 AS (Dexter axels & Dexter hydraulic disc brakes) next year, and I have been giving thought to what I would do if I experienced wheel bearing problems while in South Sopchoppy, where they have never heard of such a bearing. I discussed this concern with Rick Kapsa of Dexter Axel, and he acknowledged that obtaining bearing service in remote areas might well be a problem.
There are two solutions to this concern.
One is to carry a Nev-R-Lube cartridge bearing (p/n 031-073-03 @$106.65) as a spare. This approach requires that the old hub/drum be removed from the TT and taken to a shop where the old cartridge can be pressed out and the new one pressed in.
The other approach is to carry a Nev-R-Lube hub/drum with a cartridge bearing and snap ring installed (p/n 008-404-80 @ $263.04) as a spare. This approach will permit me to remove the bad hub/drum assembly and install the replacement, should the failure happen anywhere.
After considerable thought, I have elected to carry both options with me. By so doing, I can get back on the road with a minimum of difficulty, and have the old hub/drum assembly rebuilt when I can reach facilities equipped to do so.
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 10-05-2010, 01:47 PM   #2
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Excellent plan.
Of course, having a backup set will insure you'll never have bearing problems
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 10-05-2010, 02:26 PM   #3
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Originally Posted by finalcutjoe View Post
Excellent plan.
I've had an extra set of bearings, seal and grease with me for 12 years and never needed them. Great insurance plan.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 10-05-2010, 03:02 PM   #4
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
One more option would be simply to remove the wheel and limp into a place of repair. Have the parts sent overnight and not have $370 bucks tied up that presumably you would never need. After all you don't carry these parts for your TV.
Like Doug I have carried bearings, seals and brake parts for many years and have never needed them.
Carrying the part numbers and a phone number is a good idea though
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 12-01-2016, 06:07 PM   #5
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
nickmeloy,
Curious as to how your plan worked out, ever need the spares?
And the Dexter Nev-R-Lube bearing is a sealed cartridge, not necessarily as easy to get as a classic tapered cup and cone. So not a bad idea to consider a spare.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 12-01-2016, 06:13 PM   #6
Senior Member
sheriff1's Avatar
2014 30' Flying Cloud
Sparks , Nevada
Exactly what I do. As long as you have it, you will never need it!
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
sheriff1 is online now   Reply With Quote
Old 12-01-2016, 06:18 PM   #7
dznf0g's Avatar
Oswego , Illinois
I carry one as well
-Rich-
Old 12-01-2016, 06:49 PM   #8
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Why not just have your axles bearings replaced now and not worry for another 10 year if you are concerned?
Kelvin
Old 12-01-2016, 09:33 PM   #9
dznf0g's Avatar
Oswego , Illinois
Kelvin
It doesn't always work that way.
-Rich-
Old 12-03-2016, 04:13 PM   #10
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
So the NevRLubes aren't really?
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 12-03-2016, 04:15 PM   #11
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Pat
Good question.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 12-03-2016, 04:46 PM   #12
GCinSC2's Avatar
The design is a pair of tapered bearings in an assembly with seals. You don't really have a way to grease them. But I don't think you can say that they can't wear out.
This same style is used on a bunch of passenger car wheel bearing applications, Ford and Chrysler mostly. Press out old, press in new, install retaining clip and then criticality tighten to torque specs. Dexter published a process.
The reason I searched this topic is a friend with nev-r-lubes just finished having them replaced. Found 1 tire wearing badly as symptom. A bit of confusion followed regarding repair options.
S/OS #001
Old 12-03-2016, 04:48 PM   #13
1973 31' Sovereign
Middletown , California
Has anybody on this forum ever had a never-lube failure? I would think that their track record is a little better than the old cup and bearing set up. Bearings seem to have an unpredictable life span in general so it can't hurt to have a spare. Also for myself I know if I have a spare I'll never need it, it's fun to trick Murphy!
ijustlee is offline   Reply With Quote
Dexter Nev-R-Lube Bearing Information nickmeloy Wheels, Hubs & Bearings 2 11-10-2010 07:40 PM
Dexter Disc equipped axles never-lube bearings - maintenance dznf0g Wheels, Hubs & Bearings 4 08-17-2010 04:35 PM
Dexter 'Nev-R-Lub' or Regular Bearings halimer Axles 3 07-01-2010 01:36 PM
Mex/Baja Spare parts? Furzwo Boondocking 23 12-16-2008 03:57 AM
Spare Parts/replacements lists Chuckles Mechanics Corner - Engines, Transmission & More... 2 08-14-2006 10:12 AM
