10-05-2010, 01:27 PM
2006 30' Classic
Milton
Dexter Nev-R-Lube Bearing Spare Parts
We will begin extensive use of our 2006 AS (Dexter axels & Dexter hydraulic disc brakes) next year, and I have been giving thought to what I would do if I experienced wheel bearing problems while in South Sopchoppy, where they have never heard of such a bearing. I discussed this concern with Rick Kapsa of Dexter Axel, and he acknowledged that obtaining bearing service in remote areas might well be a problem.
There are two solutions to this concern.
One is to carry a Nev-R-Lube cartridge bearing (p/n 031-073-03 @$106.65) as a spare. This approach requires that the old hub/drum be removed from the TT and taken to a shop where the old cartridge can be pressed out and the new one pressed in.
The other approach is to carry a Nev-R-Lube hub/drum with a cartridge bearing and snap ring installed (p/n 008-404-80 @ $263.04) as a spare. This approach will permit me to remove the bad hub/drum assembly and install the replacement, should the failure happen anywhere.
After considerable thought, I have elected to carry both options with me. By so doing, I can get back on the road with a minimum of difficulty, and have the old hub/drum assembly rebuilt when I can reach facilities equipped to do so.
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
10-05-2010, 01:47 PM
2008 30' Classic S/O
Dearborn
, Michigan
Excellent plan.
Of course, having a backup set will insure you'll never have bearing problems
10-05-2010, 02:26 PM
1960 28' Ambassador
1998 25' Safari
Avonton
, Ontario
Originally Posted by finalcutjoe
Excellent plan.
I've had an extra set of bearings, seal and grease with me for 12 years and never needed them. Great insurance plan.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
10-05-2010, 03:02 PM
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown
, Tennessee
One more option would be simply to remove the wheel and limp into a place of repair. Have the parts sent overnight and not have $370 bucks tied up that presumably you would never need. After all you don't carry these parts for your TV.
Like Doug I have carried bearings, seals and brake parts for many years and have never needed them.
Carrying the part numbers and a phone number is a good idea though
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
12-01-2016, 06:07 PM
2007 30' Classic S/O
Somewhere
, South Carolina
nickmeloy,
Curious as to how your plan worked out, ever need the spares?
And the Dexter Nev-R-Lube bearing is a sealed cartridge, not necessarily as easy to get as a classic tapered cup and cone. So not a bad idea to consider a spare.
Gary
12-01-2016, 06:13 PM
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
Exactly what I do. As long as you have it, you will never need it!
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
12-01-2016, 06:18 PM
Oswego
I carry one as well
-Rich-
12-01-2016, 06:49 PM
2008 25' Classic
Full Time
Why not just have your axles bearings replaced now and not worry for another 10 year if you are concerned?
Kelvin
12-01-2016, 09:33 PM
Oswego
Kelvin
It doesn't always work that way.
-Rich-
12-03-2016, 04:13 PM
Ready-to-Travel
2012 30' International
Walkerton
, Virginia
So the NevRLubes aren't really?
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
12-03-2016, 04:15 PM
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
Pat
Good question.
@living.somewhere.yonder | Instagram
12-03-2016, 04:46 PM
Somewhere
, South Carolina
The design is a pair of tapered bearings in an assembly with seals. You don't really have a way to grease them. But I don't think you can say that they can't wear out.
This same style is used on a bunch of passenger car wheel bearing applications, Ford and Chrysler mostly. Press out old, press in new, install retaining clip and then criticality tighten to torque specs. Dexter published a process.
The reason I searched this topic is a friend with nev-r-lubes just finished having them replaced. Found 1 tire wearing badly as symptom. A bit of confusion followed regarding repair options.
12-03-2016, 04:48 PM
1973 31' Sovereign
Middletown
Has anybody on this forum ever had a never-lube failure? I would think that their track record is a little better than the old cup and bearing set up. Bearings seem to have an unpredictable life span in general so it can't hurt to have a spare. Also for myself I know if I have a spare I'll never need it, it's fun to trick Murphy!
