Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Closed Thread
Old 02-03-2007, 08:45 PM   #1
LI Pets
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
Dexter axles - What I wanted & what I got
Moderator note: this post appears out of sequence in this thread and should be post 2.
Bill B.
I think you need to get them replaced with the correct 3200 lb axles.
Those will give you a harsh ride and may create wear and tear on the whole rig.
Get a lawyer to sent them a letter and if you used a credit card..........
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
LI Pets is offline
Old 02-04-2007, 06:37 PM   #2
bilby05
bilby05's Avatar
Profile:  1969 31' Sovereign
Canyon , Texas
Dexter Axles, a cautionary tale
I posted this as a reply on another thread by mistake. Shoulda been here.
For those following the great axle debate I would like to add an installment.
I picked up my Airstream from the axle shop day before yesterday and just now am able to speak(write.) You may be able to ascertain that I have been rendered almost speechless by the entire experience. I prepared a list of instructions for the dealer(non Airstream dealer) containing information from the Dexter web site and my personal specifications for what I wanted, as follows:
2-Dexter #10 axles 3200pound rating
22.5 degree down aspect
regular 10 inch brakes
ez-lube axles
re-welded shock mounts
What I got?
2-Dexter #?? 5200# rating
Zero aspect (level)
12 inch brakes
ez lube axles
rewelded shock mounts
2 inch bracket to provide the proper mounting?????
Huh?, I said. How did you end up with Zero degree up/down aspect? He said: Well, that's what they were at when you brought it in. Me: That’s because they were worn out, shot, used up, aaaaaaargh. Me: my old axles were 2800# rated, that's why I requested 3200# axles, to replace the old ones and bump them up just a little bit to possible cover added weight or maybe someday a new graywater tank. Him: Well the 3200# axles would have barely covered the dry weight of the trailer and any additions, like water or junk, would raise it above the limit. Me: But airstream used 2800# axles on this model and I didn’t want to go WAY over that. Him: well, trailer companies put on different weight rated axles and label them the same, as long as they are not under the limit. Me: Sheesh!
Hey look at the bright side, I told myself. The price was about what they said. $1200 plus sales tax. The extra axle rating will be really handy when I want to add a gray water tank, rear frame bracing and the Sherman tank that I may want to buy someday and convert the Airstream into a toy hauler.
All seriousness aside. I think: What to do, oh, what to do? Remember the 20-20 expose on restaurant staff, that said that if you send food back to the kitchen to be redone, they spit in it. Or worse. Makes me wonder what they do to Airstreams that are sent back to the kitchen.
The moral of the story. GET IT IN WRITING, GET IT IN WRITING, GET IT IN WRITING. Oh yea, be sure to get it in writing, too. Make them look at your specs and recite them after your reading aloud of them. Compel them, by threat of whatever it takes, to inform you of any changes that they feel that they have to make to your "grand plan."
Thanks for listening to my rant. Hopefully the story will give someone else the insight to tell the "experienced trailerman, that does this sort of thing to Airstreams all-the-time," that his high level of experience does not trump your obsessive desire to have it DONE RIGHT.
Sorry, I yelled. Just practicing to see how it sounds for future reference. Where ever I go from here.
cheers, bill b.
I think I hear rivets popping out in the driveway.
bill b.
1969 Airstream Sovereign 31'
2001 F250 7.3 Diesel
bilby05 is offline
Old 02-04-2007, 10:01 PM   #3
3Ms75Argosy
3Ms75Argosy's Avatar
Profile:
welll......
any pics? What's with the new two inch mount. Is this a spacer? Sounds botched.
Hmmmm.....
Marc
3Ms75Argosy is online now
Old 02-04-2007, 10:11 PM   #4
2airishuman
2airishuman's Avatar
Profile:
hi billy05
thanks for posting the lesson...
'get it in writing'
given how little the job cost...
and how valuable this trailer is to you...
i'd take it back and ask it be done correctly...
perhaps split the cost of the redo (you didn't get it in writing) with the dealer....
even dexter will likely support the position you've got too much axle now.
also it would seem with the angle changed, 2 inch spacers and wheel size altered...
your trailer will ride much differently...
not necessarily a good thing...
spend a little more now, as painful as it might seem...
shell repair, leaks and so on could be much more painful as a lesson....
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
2airishuman is offline
Old 02-04-2007, 10:16 PM   #5
TIMEMACHINE
TIMEMACHINE's Avatar
Huntington Beach , California
Darn
I hate when this kind of stuff happens....hope it all works out for you. I think we have all been there at one time or another.
TIMEMACHINE is offline
Old 02-04-2007, 10:33 PM   #6
doorgunner
INSANITY CENTRAL
doorgunner's Avatar
Profile:  1986 32' Excella
1973 29' Ambassador
Lodi , Ca. U.S.A.
Images: 35
Looks like you never spent any time in the Marine Corps.
Wherever we want to go
We go
That's what an Airstream is
You know
It's not just a frame, aluminum skins
and wheels.
That's what a Airstream needs
not what a Airstream is.
What a Airstream is,
is Freedom.
Proud Appellation American
doorgunner is offline
Old 02-05-2007, 12:15 AM   #7
3Ms75Argosy
Profile:
wondering
if one was to call Dexter and order an axle for a 22 or 23 ft current safari, if this would get the right axle with bolt holes in the right place. I'd love it if someone with that size trailer and the new Dexter axles as supplied by AS would confirm that the bolt holes and spacing, etc were the same as those on the 70's 8ft wide tandem trailers.
I think their GAWR rating is simular to the 25 ft tradewinds.
Marc
Old 02-05-2007, 05:21 AM   #8
boatdoc
boatdoc's Avatar
Profile:  1973 Argosy 26
Norristown , Pennsylvania
Arrow Dexter Axles.
Hi Bill; I am very surprised to say the least. When I ordered my axles, Dexter, was not even willing to discuss the order until I presented them with filled out spec sheet provided by them. This sheet contained numerous drawings of different configurations. Have you dealt directly with Dexter or a dealer? In any case Dexter had called me back after receiving my filled out spec sheet to go over my figures. I thought that it was very professional of them to do so. For my 26' Argosy I wanted 5000 lbs axles so that I can have large bearings 1 3/4"inside and 1 /14"outside with 12 " brakes while having 22.5 Degree drop and 3500 lbs torsion arm capacity per axle. My axles came as I specified with the exception that the capacity was not tested yet, because trailer is not complete. I guess the person who did the specifications may be to blame. Thanks, "Boatdoc"
You can count on changes in life. "At times you are the doggie, the rest of times you are the fire hydrant". "boatdoc"
boatdoc is offline
Old 02-05-2007, 08:40 AM   #9
Action
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
Originally Posted by 3Ms75Argosy
if one was to call Dexter and order an axle for a 22 or 23 ft current safari, if this would get the right axle with bolt holes in the right place. Marc
No. They want all they data on the axle they are creating. Dexter does not keep data on what trailer (A/S and non A/S) has what axle. They are a supplier for A/S and hundreds of other trailer manufacturers.
Airstream places and order for 50 axles based on the job they want done. Dexter (or any other vendor) makes the part and has no idea what it's going into. In this case Dexter, makes thousands of axles each year for many different customers for many different uses.
>>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Action is offline
Old 02-05-2007, 05:45 PM   #10
bilby05
bilby05's Avatar
Canyon , Texas
The Dexter Axle Saga improves
Hi,
I decided to chill a bit and go back to the shop and talk it over with the axle guy. He was very nice about it. Answered my questions and agreed to redo the job. He said he was sure that 0 degree aspect was correct and suggested that I have the trailer weighed to avoid any confusion on axle strength. He called me later and said he had talked to someone at Inland RV, Gregg I think, and agreed that we need to go with the 22.5 degree down axle aspect and reduce the axle support weight down to the 3500# range. Said that Inland RV told him what they use and my original idea had been in line with that. He was a real gentleman about it and said he could probably get the new axles within about 3 days and would put them on in short order. So I am a happier camper today then yesterday. Will keep on with the update. BTW I wasn't in the Marines, but USAF and forgot to relate the project to the necessity of full instruction and confirmation that I learned there. I did know a Marine once tho. :-) Could tell some war stories about that. That was 34 years ago. I must be getting old.
cheers, bill b.
bill b.
bilby05 is offline
Old 02-05-2007, 06:00 PM   #11
clancy_boy
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
Glad things are working out - I have been following this thread to see where things would go. Looks like you found an honest merchant - maybe give him some credit and pass on his place of business after he corrects the axles for you so that others may call on him.
Good Luck.
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
clancy_boy is online now
Old 02-05-2007, 06:08 PM   #12
doorgunner
INSANITY CENTRAL
doorgunner's Avatar
1973 29' Ambassador
Lodi , Ca. U.S.A.
Images: 35
34 years ago- that mighta been me. Semper Fi. Glad to hear you did not need any help! To bad this shop weren't closer I'ld be giving them my axle business. DG
We go
You know
and wheels.
is Freedom.
Old 02-05-2007, 06:10 PM   #13
3Ms75Argosy
Profile:
Karma to Inland...
I'm happy that Inland helped out - really when they weren't even making a sale.
Thanks for the update - can't wait to see what you get.
Still want photos!
Marc
Old 02-05-2007, 06:34 PM   #14
Phil Gobie
Phil Gobie's Avatar
Miami , Florida
I have been looking into axle replacements myself. Reading the posts I think a couple points have been left out. When you weigh your trailer (and you should) and you consider the weight capacities of the new axles you need to deduct the weight of the running gear, all the unsprung weight. That is the wheels tires brakes etc. You should also deduct the tongue weight. so if your tongue weight and unsprung gear weight are deducted then add 1000 LB for cargo now you are looking at the axle capacity range. Also some people are saying to go to 30 deg. for greater range of motion instead of 22.5 deg. So with 30 deg. and the axles rating close to the adjusted weight you should end up with a smooth ride with out fear of bottoming out the axles. As for the spindle hub size it seems that AS has a unique combination of over sized or heaver hubs/brakes than the typical trailer industry. So when the non AS trailer expert looks at the brakes, bolt pattern, splines and bearings they say that they are 5200lb when AS built them with Henshen 3200LB! So be careful when the typical trailer guys look at the hardware and tell you what you have or need!
Phil Gobie is offline
Closed Thread
Service manual wanted hill4th@gvtc Classic Motorhomes 1 09-02-2006 04:58 PM
'92 Excella literature wanted Mark Wiltrakis Our Community 7 11-17-2002 12:47 AM
How many axles replaced Jabba Axles 7 10-21-2002 01:21 PM
Axles on a Avion 68 Suburban Axles 0 10-06-2002 12:10 AM
Motor Home Tag Axles - winner General Motorhome Topics 0 05-25-2002 04:56 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
Other recommended Airstream sites
