Old 03-17-2009, 07:08 PM   #1
Lothlorian's Avatar
Loganville , Georgia
Dexter axles putting them on facing correctly
I have had my old axels off for awhile. Does anybody have a picture of the correct way those new dexters axels I bought should be facing. I do not want to put them on backwards. I need a diagram or photo. I don't want to hang them only to have to take them down and turn them around. Your diagarm or picture would really help.
Lothlorian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 03-17-2009, 07:18 PM   #2
slvrlng's Avatar
Lawrenceville , Georgia
before pics!
Are they different than the old ones?
Lewis
Lewis
http://55flyingcloud7909.blogspot.com
slvrlng is offline   Reply With Quote
Old 03-17-2009, 07:19 PM   #3
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
the swingarm faces to the rear (as in the pivot point is at front). From my math elementary school days... the "mouth" faces to the rear (the open angle from the pivot to the wheel drum).
Mount away!
Marc
Old 03-17-2009, 07:23 PM   #4
empresley's Avatar
1984 34' International
1977 Argosy 24
Central , Georgia
The Trailing Arm must "trail" behind the axle beam. Otherwise I don't think it would survive the first pot hole.
I thought you were going to install these "one at a time" which means one old axle would still be in place while you installed the first new unit.
Did you change the game plan?
http://i.b5z.net/i/u/1080235/f/Torfl...ation_4-04.pdf
Travelers by aluminum roadships, loyalists to one species,
masters of convenience, herdsmen steeped in maintenance and restoration.
empresley is offline   Reply With Quote
Old 03-17-2009, 07:40 PM   #5
Lothlorian's Avatar
Martin:
Yes I still have an axel on. I guess I worded the orginal post wrong when I posted it. I just want to make sure they both face in the same direction.
Brian
Brian & Adrienne
Old 03-17-2009, 08:40 PM   #6
1975 Argosy 26
1963 24' Tradewind
Both face the same way...
Marc
Dexter Axles BarryIowa 1960 - 1964 Overlander 67 03-18-2009 04:33 PM
Dexter Axles INSTALLED... TN-TUNDRA Axles 17 03-29-2008 09:09 PM
Dexter axles wol Axles 20 05-01-2006 11:07 PM
Does anyone know anything about putting safety skids on axles? 1959newbie Axles 7 05-01-2006 05:59 AM
Dexter Axles librarylady Axles 10 04-19-2006 10:02 AM
