Old 12-03-2007, 05:56 PM   #1
1970 31' Sovereign
Collierville , Tennessee
Dexter Axles INSTALLED...
I did get the new Dexters installed this weekend. It went pretty good. I decided to use a RotoZip with a metal tip for the elongation of the bolt holes. I used my 4.5" angle grinder for the "C" channel wideing. The hardest part was MOVING the axles. The Dexters did weigh more than the Henschens. Thanks to my dads help. (He did ok for an old guy) Also thanks to PizzaChop for the help on what and how to order! The only problem was the new Dexters had the Nev-R-Lube hubs and these are over 4" the stock AS wheels are 3.?". SO if you are going to get the Nev-R-lube option remember the wheels WILL NOT FIT... I forgot my camera so I didn't any pics sorry. Now on to the reefer and awning.
TN-TUNDRA is offline   Reply With Quote
Old 12-03-2007, 07:36 PM   #2
GreatPumpkin's Avatar
Colville , Washington
Images: 70
My wheels fit great with the Nev-R-Lube, but I had already replaced the original split rims.
Enjoy the ride!
JB
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 12-03-2007, 07:47 PM   #3
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Congrats, I'll bet you're going to be happy with them. I sure have been happy with my Dexter, which we put on in 2004. Mine had a different hub - EZ Lube or Qwik-Lube or something like that. The old wheels fit fine.
Stephanie
Old 12-03-2007, 09:04 PM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Congrats on the new axles. Did you gain any clearance height with the new install.
Old 12-04-2007, 06:26 AM   #5
1970 31' Sovereign
A LOT higher now. Looks like I put on a lift kit!
Old 12-04-2007, 07:00 AM   #6
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by TN-TUNDRA
I did get the new Dexters installed this weekend....thanks to PizzaChop for the help on what and how to order! The only problem was the new Dexters had the Nev-R-Lube hubs and these are over 4" the stock AS wheels are 3.?". SO if you are going to get the Nev-R-lube option remember the wheels WILL NOT FIT....
Congrats on completing a major upgrade!
PizzaChop has been a HUGE help to many here on the Forums...
On your center hole problem - I installed the AS wheels over the #11 Nev-R-Lube hubs/drums with no problem...I might suggest you check out the actual weight rating stamped on your wheels.
Auto/Truck rims were sometimes substituted for trailer type wheels, and the auto/light truck version are typically rated for 1860 lbs or so. The lighter (auto) rated rims center hole are 3.19". The AS rims should be 3.65" ID on the pilot hole.
It's best not to run with an under rated wheel.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 12-04-2007, 07:17 AM   #7
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
This is a project I need to tackle in the not to distant future on my 71.
What is a RotoZip?
Now that it's all said and done if you had to do it over again would you still go with the Dexters rather than Henschens?
Old 12-04-2007, 10:02 AM   #8
1970 31' Sovereign
What is a RotoZip?
A RotoZip is like a bigger Dremal tool.
I would do it again with the Dexters. The hardest parts was moving the axles they both weight a lot. The bolt hole and "c" channel was easy and I still have pleanty of $$$ for new wheels and tires. Cost was $480 per axle and I ordered them through TruckPro here locally.
Old 12-04-2007, 10:08 AM   #9
1970 31' Sovereign
The center bore on the AS wheels were 3.65" but the hubs were 4" so no way they were going to fit. What size are your hubs? Maybe they have made them larger now?
Old 12-04-2007, 10:09 AM   #10
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
didn't know you could cut anything that thick (especially, "metal") with the rotozip.
what is this "c-channel widening" of which you speak?
so that price: includes brakes?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 12-04-2007, 10:32 AM   #11
1970 31' Sovereign
I purchased a "tile" bit at HomeDepot for the rotozip. They are powerfull little tools. I could have used and air die grinder but was having a hard time finding a burr on time. It worked good.
The "c" channel is the "slot" in which the axles go up into. The Dexter axles are 3" wide and the Henschens are 2.75 so about 1/8th" needs to be ground off both sides. It wasn't bad with with a fresh 4.5" angle grinder.
Complete with brakes and even the shock brackets. Shipping was another $100 and taxes on top of that.
Took us about 6 hours from start (jacking trailer) to finish (putting up tools).
Old 12-04-2007, 11:52 AM   #12
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Oh, ok, I get it. "C" channel. But it only looks like a "C" if you turn your head 90-degrees to the right. Maybe it should be called an 'n' channel?
Those roto-zips are great. The masonry bit makes sense...that's pretty hard. I have the right-angle attachment for it, too, but I don't think they have anything that could actually make it into a real "grinder"...almost. I've used the cutoff wheel, but otherwise, it just has "sanding disk" attachments. Unless they've come out with something new, which they do all the time. I should check.
anyway...
go take some pictures!
Air:291
Wbcci: 3752
'73 Safari 23'
Old 12-04-2007, 12:01 PM   #13
1970 31' Sovereign
anyway...
It is 90 miles from me now. I just used the roto for the bolt holes. I used a Dewalt angle grinder for the "n" channel.
Old 01-02-2008, 03:49 PM   #14
1972 27' Overlander
Greenwood , South Carolina
TN-T, did you spec the axles on the Dexter work sheet or did they look at your axle and copy; also, who did the shock mounts?
Smead
smead42 is offline   Reply With Quote
Dexter Axles here with pics!! TN-TUNDRA Axles 27 11-23-2007 09:32 PM
Dexter axles - What I wanted & what I got LI Pets Axles 18 02-21-2007 01:53 AM
Dexter axles wol Axles 20 05-01-2006 11:07 PM
Dexter Axles librarylady Axles 10 04-19-2006 10:02 AM
New Axles Installed Buttercup Axles 7 07-25-2005 05:39 PM
