11-23-2007, 01:34 PM
1970 31' Sovereign
Collierville
, Tennessee
Dexter Axles here with pics!!
11-23-2007, 01:37 PM
2002 25' Safari
Dewey
They look great. Now the fun begins. Keep us posted as you install them.
Richard
11-23-2007, 01:55 PM
1970 31' Sovereign
Collierville
, Tennessee
I'll take some pics on the install.
11-23-2007, 02:07 PM
1967 26' Overlander
Huntsville
, Alabama
Heh, heh, heh
Originally Posted by TN-TUNDRA
... These things are stout as ****. ... even came with ALL NEW hardware! ...
'69 Airstream? You already know you'll be drilling new holes in the mounting plates to get ANY new axle to fit.
Your profile does not list your age. I was 44 when I drilled holes for my new axles. Even with sharp drills & Milwaukee drill motors, the elation of admiring the new axles strapped together in the truck bed dimmed SIGNIFICANTLY with each of the eight, new mounting holes drilled to accommodate the investment.
I'd do it again, but drilling big holes in plate steel by hand was one of the least fun things I've done for my Overlander.
Congratulations on your new axles though. Since Ron helped you, I know you will be happy with the outcome.
Tom
11-23-2007, 02:20 PM
1970 31' Sovereign
Collierville
, Tennessee
It is actually a 70. All I should have to do is elongate 4 of the mounting holes and cut about 1/8th" of the "cut-out". I'm 36 and have a 36v Dewalt and cordless sawsall so shouldn't be that bad (I HOPE!). I checked Ron's pics of his and mine look exactly the same but the shock brackets will not have to be welded. We will see, I have new shocks also to go on there.
11-23-2007, 02:32 PM
1967 26' Overlander
Huntsville
, Alabama
You're in your prime
... All I should have to do is elongate ... I'm 36 and have a 36v Dewalt and cordless ...
Sounds like you've got it covered. How many battery packs are on standby?
Seriously, remember that nothing's ever easy. If Dexter did not include big washers to [literally] cover the wallered-out area, you might think about acquiring some.
Tom
p.s. I could have sworn your profile indicated '69 when I posted. Did you update it? I just turned 46 and would hate to think I'm already losing it.
11-23-2007, 02:43 PM
1970 31' Sovereign
Collierville
, Tennessee
I did just updated it. Your not losing it! I'll check on the "Wallered Waser"!!!! This will be the first time I've really tested this drill. I have 2 batts but they hyped it up to do "anything" and a price tag to prove it... I hope it is a easy install. Ron helped me A LOT with his already done and pics.
11-23-2007, 02:56 PM
2002 19' Bambi
Lafayette
A high-quality old-fashioned plug-in drill can outperform almost any battery drill, particularly when drilling big holes in thick steel. I use a 25+ year-old Makita and it has drilled a LOT of thick steel. Cutting fluid (usually sold for cutting threads) can help the job. Don't forget your safety goggles!
11-23-2007, 03:11 PM
2002 25' Safari
Dewey
I agree. When I need to do some serious drilling, I plug in the good old Milwaukee and get er done.
Safety glasses are a must, you can't find new eyes on E-Bay.
Richard
11-23-2007, 03:18 PM
1969 31' Sovereign
Broken Arrow
, Oklahoma
Before
These are the before pictures from the former owner,
Garry
11-23-2007, 03:20 PM
1970 31' Sovereign
Collierville
, Tennessee
Yea, Yea, BUT I have to try out my new drill and see how she does on a steel plate!
I have already had to go to the ER for a piece of steel in my eyeball. I had to wear a patch for a couple of days and have it "drilled" out (rusted very fast). I looked like a pirate. I'm SOOOO much more carefull now with my eyes... The saftey glasses are a MUST!!!!!!!!!!
11-23-2007, 05:35 PM
1977 27' Overlander
Trotwood
, Ohio
Before U drill.Go to the hardware and buy name brand drills. Dont try this with cheap Chinese drills. Hanson is a good name. Get several U will need em and by all means saftey Glasses with the side shutters. U cant be to carefull wif your eyes ya know HAVE FUN
Mike
11-23-2007, 05:47 PM
1970 31' Sovereign
Collierville
, Tennessee
Mike
Do you really think this 37 yo steel is THAT tough? If it is I'll be impressed!!
11-23-2007, 05:52 PM
1967 26' Overlander
Huntsville
, Alabama
Ergonomics
Do you really think this 37 yo steel is THAT tough? ...
No, but you've got to lay on your back to drill it. Drilling ANYTHING with your arms raised gets real tiring, real quick.
Tom
11-23-2007, 06:01 PM
Central
, Mississippi
Garry
Dude- a low rider with spinners?
11-23-2007, 06:03 PM
1970 31' Sovereign
Collierville
, Tennessee
Tom
Why can't I drill it from the wheel well???? After the tires are removed and the axle placed with a jack and centered and marked???? I would think that would be easier.
11-23-2007, 06:04 PM
1970 31' Sovereign
Collierville
, Tennessee
They don't spin, at least not for now!!!!!!
11-23-2007, 06:19 PM
1967 26' Overlander
Huntsville
, Alabama
Match-drilling
Good point. Maybe you will be able to do that. In my situation, there appeared to be less chance of hole misalignment to drill from the inside. I didn't want to chew a bigger hole in the axle flange than I already had.
Tom
11-23-2007, 06:26 PM
1970 31' Sovereign
Collierville
, Tennessee
Tom
I am hoping on just making a hole a little longer to fit the bolt. like this:
http://www.airforums.com/photos/show...00&userid=4331
11-23-2007, 08:15 PM
Salem
, Oregon
Hi, when drilling large holes in thick metal I usually drill a pilot hole with about an 1/8" drill bit first; Makes drilling a lot easier.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
