Old 11-23-2007, 06:01 PM   #15
Central , Mississippi
Originally Posted by garry
These are the before pictures from the former owner,
Garry
Dude- a low rider with spinners?
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 11-23-2007, 06:03 PM   #16
1970 31' Sovereign
Collierville , Tennessee
Originally Posted by TomW
No, but you've got to lay on your back to drill it. Drilling ANYTHING with your arms raised gets real tiring, real quick.
Tom
Why can't I drill it from the wheel well???? After the tires are removed and the axle placed with a jack and centered and marked???? I would think that would be easier.
TN-TUNDRA is offline   Reply With Quote
Old 11-23-2007, 06:04 PM   #17
1970 31' Sovereign
They don't spin, at least not for now!!!!!!
Old 11-23-2007, 06:19 PM   #18
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Match-drilling
Good point. Maybe you will be able to do that. In my situation, there appeared to be less chance of hole misalignment to drill from the inside. I didn't want to chew a bigger hole in the axle flange than I already had.
Tom
Old 11-23-2007, 06:26 PM   #19
1970 31' Sovereign
Tom
I am hoping on just making a hole a little longer to fit the bolt. like this:
http://www.airforums.com/photos/show...00&userid=4331
Old 11-23-2007, 08:15 PM   #20
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, when drilling large holes in thick metal I usually drill a pilot hole with about an 1/8" drill bit first; Makes drilling a lot easier.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 11-23-2007, 08:20 PM   #21
1970 31' Sovereign
I'm not drilling new holes but just elongating a hole.
How in the world do you back up that AS in that space in your avatar? That is awesome.
Old 11-23-2007, 08:37 PM   #22
[QUOTE=TN-TUNDRA]Thanks to PizzaChop I have my new Dexters with oem shock brackets!!! These things are stout as ****. Specs are #11 with 12" electric brakes, 3500lbs, 22.5 down angle (required for oem shock bracket), even came with ALL NEW hardware! Thanks again for all the help. Now next weekend is the install...
Most owners that replace the torsion axles, want a 35 degees downward starting angle.
It helps rigging to a high profile tow vehicle.
Makes a big difference, especially since the cost for the change of angle is zero.
Old 11-23-2007, 08:42 PM   #23
Salem , Oregon
Images: 18
Hi, I understand that you only plan on elongating the holes, But other's on this thread mentioned drilling new holes.
Hi, very carefully.
Click on picture for a larger view.
Name:	airstream mods 070 (Small) (Medium).jpg
ID:	49809   Click image for larger version
Name:	Airstream Mods 037 (Medium).jpg
2005 Safari 25-B
Old 11-23-2007, 08:52 PM   #24
1970 31' Sovereign
[quote=Inland RV Center, In]
Andy, PLEASE DON'T START................
I purchased the shocks from you and will buy more stuff. BUT, the axel thing is done. I don't won't this to end up deleted or a war. I have made my
The term decision may refer to:
Decision is a act or process of deciding, which is called decision making. Choices, arrangements, or conclusion after consideration, of individual specific mental..
Please don't kick it up to a "YOU SHOULD HAVE DONE THIS".....
Mark
Old 11-23-2007, 09:03 PM   #25
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
Mark,
I used a metal removal bit (burr) and a pneumatic die-grinder to elongate the holes. Please call me before you begin as there are a couple of details I can explain which will help you in the overall changeout.
Congrats on the shock mount brackets. That will save you a lot of time!
P.S.- If ground clearance becomes an issue (22.5 deg vs 35 deg), you could probably achieve the 3/4" gain (or whatever it is) by taking advantage of the mounting slots on the Dexter axle brackets. I would insert some sort of spacer between the top of the bracket flange and the frame, as well as tack weld the side of the bracket to the frame (which is what I ended up doing anyway, just to be safe.)
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is online now   Reply With Quote
Old 11-23-2007, 09:08 PM   #26
LJH
LJH's Avatar
1985 27' Sovereign
Defiance , Ohio
robsunrus, can I come to your house for backing lessons?
LJH is offline   Reply With Quote
Old 11-23-2007, 09:25 PM   #27
Salem , Oregon
Images: 18
Hi, you sure can; And just towing through the LA area to get here will give you some real driveing skills.
2005 Safari 25-B
Old 11-23-2007, 09:32 PM   #28
1970 31' Sovereign
I can only IMAGINE!!!!!!!!!
Dexter axles - What I wanted & what I got LI Pets Axles 18 02-21-2007 01:53 AM
Dexter actuator ? richnritab Brakes & Brake Controllers 20 07-23-2006 12:25 PM
Dexter axles wol Axles 20 05-01-2006 11:07 PM
Dexter Axles librarylady Axles 10 04-19-2006 10:02 AM
Dexter E/H Actuator Buttercup Brakes & Brake Controllers 17 05-25-2005 09:00 AM
