Old 06-21-2010, 10:10 PM   #1
lyn
1974 27' Overlander
selby , South Dakota
Dexter axles for 27' Overlander
hello-want to put new dexter axles under my overlander,think the old ones are maybe allright yet but want to get the coach higher off the ground. after haveing examined the dexter web site i have determined that a 45 degree angle and the nhigh profile side hanger is what i want. question is which axle groupe to get the 2300-3500 pound or the 4000-6000 pound? went to a dealer and he wants to put in the heavy ones but am thinking to stiff is not good. would really like to get in touch with a dealer or individual that has ordered dexter axles and could give me some part numbers perhaps. i called the factory and they really were not much help,thanks Lyn
lyn is offline   Reply With Quote
Old 06-22-2010, 06:57 AM   #2
Looking for John Galt
Dumpster's Avatar
Banjo , Montucky
Been There
Done that, and wish I would have gone with.......
#11 Axles at 3200# each.
K.C.C.O.
Just because you are unique, doesn't mean you are useful.
Dumpster is offline   Reply With Quote
Old 06-22-2010, 01:31 PM   #3
starting angles
A 45 degree starting angle, "is not" recommended by Airstream.
Old 06-23-2010, 06:46 AM   #4
Dumpster's Avatar
Banjo , Montucky
Correction
I now have it on good authority that the minimum weight rating on a #11 axle from Dex is 3,500 lbs., not 3,200. Sorry for the misinformation.
K.C.C.O.
Old 06-23-2010, 07:18 AM   #5
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I recently custom ordered axles for an Airstream. They were #9 axle (same tube size as the original and the spindle from a #10 axle so I could get the 10" brakes just like the originals. The original axles were 1850 lbs and I ordered 2000 lb axles with a 32 degree down angle. I spoke with Dexter engineering department before I ordered from the local dealer.
Here is what I would do: Call Dexter engineering and get the part numbers for the axle you want to order. I would custom order the Dexter with a 32 degree angle which will help with the height. You should also be able to order the #10 axle (2300 - 3500) in 100 lb increments and should also be the same tube size as the original. You can specify the spindle for the #11 axle for the 12" brakes. They will throw in the shock mounts with the 32 degree down angle and you will have to custom fit these. Not hard to do if you use the originals as a guide. (The shock mounts come installed on the 22.5 down angle axle.)
There should be a tag on the axle with the weight rating.
You could also order axles from Inland RV which will be an easy phone call but the price will be slightly higher.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 06-23-2010, 07:46 AM   #6
Bauxter's Avatar
1973 31' Sovereign
Columbus , Ohio
I called Dexter regarding my 73 Sovereign, and they wanted the axle model or serial from a tag on it. I haven't been able to locate it yet. When you say "They will throw in the shock mounts with the 32 degree down angle and you will have to custom fit" above, did it require welding?
Mike
Bauxter is offline   Reply With Quote
Old 06-23-2010, 08:41 AM   #7
87MH's Avatar
1978 31' Sovereign
Images: 292
They are on the axle - you have to crawl underneath the trailer to read them -
take a wire brush with you when you submerge beneath the belly of the beast.
Here's a closeup of one of the original tags off of the '78 Sovereign.
The tags were located on the frontal tube face about a foot inboard from the driver's side main frame.
The shock mounts will require welding - but it is an EASY job - anyone with a cracker box or a simple wire feed welder could do it. Place the mount about a 1/2" closer to the front of the trailer than the original equivalent to allow for the extra rotation required by the additional start angle. I used a 45 degree start angle, but a 32 to 35 degree start angle would give you almost the same amount of lift. The angle and lift amounts are well covered in the Dexter catalogues and literature available on their website.
For what it's worth, the #11 Dexter tube body is more substantial than either the original Henschen or the #10 Dexter - well worth the extra bucks to me. I went with the #11's with the rubber cut down to a 3600 lb rating when I replaced mine a couple of years ago - with 20/20 hindsight I would do pretty much thing again if I had to do it over.
I WOULD order 16" rims for the wheels, though, I have determined (my own personal thoughts and obversations only - your results may vary) that ALL of the 15" special trailer (ST) tires are crap, and have gone to LT tires for the trailer - the last blow out on the Sovereign caused enough cosmetic damage to keep me busy for a couple of weeks.
Do a search on Forum Member "PizzaChop" for a good tutorial on a DIY axle replacement.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 06-23-2010, 08:33 PM   #8
lyn
1974 27' Overlander
ok,so the 45 degree is a nogo,any other sugestions as to how to get it to sit higher??? and what size were the original brakes on a 27ft international? what do you measure when you mesure the brakes for size? thanks
Old 06-23-2010, 08:57 PM   #9
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
If you were just replacing the brakes, this would be the replacement....
Trailer Parts Superstore - 12" x 2" Electric Brake Assembly - Right Hand / 5.2k #K23-106-00 <a name="5331010"></a>
Old 06-23-2010, 09:17 PM   #10
Central , Mississippi
Several folks have gone with the 45 degree and been very pleased...do some 'searchin' on the threads for 87MH's stuff.
"A 45 degree starting angle, "is not" recommended by Airstream."
Does this mean that Airstream is on record recommending that a 45 degree angle is not to be used? nah... ("Airstream recommends that a 45 degree angle is not to be used") OR is there a lack of recommendation that any particular angle is to be used..? besides the generic "use the OEM..."
You probably have 12" brakes and newer-non-OEM axles will probably have 10" brakes...The 10" Brake size scare tactics are arguable...8,000lbs of braking on a 4,500 trailer is a case of too much is not good...Peterbuilt brakes on a Prius won't give you an extra margin of safety, they simply lock up and loose control way too quick.
weed thru the threads, listen to the advice---then make up you own mind and proceed!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 06-23-2010, 10:07 PM   #11
Your trailers original brakes were 12 inch.
There are a number of opinions that may differ.
But staying with the original Airstream specs, is not too shabby.
Old 06-23-2010, 10:18 PM   #12
Emerson75's Avatar
1975 25' Tradewind
Hanover , Pennsylvania
Before welding new shock mounts, I would ask Dexter about it. I installed a new set of Dexters last September, and I was told that any modifications to the axles (like welding of any kind, including the brackets) would void the warranty.
I not saying don't do it, I'm just mentioning it as an FYI, and that it may be worth asking about first.
-Eric
Eric, Stacey, Easton, Annabelle, Gretzky (boxer), & George Bailey (basset hound)
1975 Tradewind - Family owned and operated since 1975
2005 Chevy Tahoe Z71
Emerson75 is offline   Reply With Quote
Old 06-24-2010, 08:16 AM   #13
-Eric
Different manufacturers have different thoughts about welding the shock brackets.
Dexter says that will void the warranty.
Henschen says that it will not void their warranty, as it's not a problem, since they have done it for many years in production.
Axles Axles Axles GeocamperAS Axles 33 11-20-2015 12:01 PM
Dexter Axles for Overlander phoney Axles 25 05-23-2009 11:04 PM
Dexter axles for '65 Overlander ?s dreadydreame Axles 12 03-20-2009 08:10 PM
Dexter Axles librarylady Axles 10 04-19-2006 10:02 AM
