Old 04-20-2006, 08:01 PM   #1
wol
1974 27' Overlander
memphis , Tennessee
Dexter axles
I have talked to three dexter dealers and none of them will order the axles I want with 12" brakes. They all tell me to get the 12" brakes I have to go with 6000# axles (I DON'T THINK SO). Can any body tell me who to talk to who to call?
wol is offline   Reply With Quote
Old 04-20-2006, 08:23 PM   #2
Images: 59
Where are you located?
Their website clearly shows 4000# to 6000# axles with a #11 spindle and 12×2" brakes.
http://i.b5z.net/i/u/1080235/f/6-8K%...0_res_2-05.pdf
Old 04-20-2006, 08:24 PM   #3
wol
1974 27' Overlander
memphis , Tennessee
memphis TN
Old 04-20-2006, 08:30 PM   #4
wol
1974 27' Overlander
memphis , Tennessee
I need 2 axles that are 3000 or 3500# axles. That's the problem.
Old 04-20-2006, 08:31 PM   #5
Images: 59
Originally Posted by wol
memphis TN
There aren't any official Dexter distributors in Memphis. I'm suprised.
Maybe that's why you can't find a good local source. Call the National Sales Office and see if they can hook you up with a more co-operative local dealer.
Old 04-20-2006, 08:33 PM   #6
Images: 59
Yeah, that's the problem.
Old 04-20-2006, 08:35 PM   #7
Somewhere , Indiana
The problem.......
The problem is ......
All in how you ask. You need to talk to the factory - Dexter has around 300 (give or take) dealers accross the USA. Most don't sell many axles that are "custom". Start with the factory based in Elkhart, Indiana. They will help you define your request. Once defined "clearly" - your dealer will say - ok, we can do that.
Just two cents from a retired axle dude!
Regards,
Henry
axleman is offline   Reply With Quote
Old 04-20-2006, 08:43 PM   #8
StingrayL82's Avatar
San Angelo , Texas
Images: 37
Henry,
Correct me if I'm wrong but, with tandem axles, aren't 10" brakes sufficient to do the job, especially with an Overlander?
Frederic
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 04-20-2006, 08:48 PM   #9
wol
1974 27' Overlander
memphis , Tennessee
Custom Springs sells axles but they just order them out of a catolog. they would custom do the mounting plates but not the brakes.
I will check with factory and see what they say.
Old 04-20-2006, 08:56 PM   #10
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Originally Posted by StingrayL82
Henry,
Frederic
Frederic,
I don't know, but on my 1979 Safari which is 23' long, I have dual axles with 12" brakes.
Bill
Just my personal opinion
Old 04-20-2006, 10:07 PM   #11
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Henry,
Frederic
I don't think so. My brand new 12x2 brakes ( 1971 TradeWind) were less than satisfactory on long and steep descents.
Uwe
www.area63productions.com
Old 04-20-2006, 10:44 PM   #12
1960 24' Tradewind
santa barbara , California
Hello eveyone,
Most sob tandems usually do have 10" drums ,not 12" ,My auto shop does alot of trailer service ,chassis mostly ,springs brakes etc. But definately does not mean they are enough braking .I would get the 12" if I could ,but the 3000 to 3500 probably could be custom built as axleman suggests.It would take some looking around for the right supplier to help out. disc brakes are the drum brake solution though no doubt about it.The 12" seem to be only on the larger coaches with the heavier axles .
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 04-21-2006, 07:21 AM   #13
Somewhere , Indiana
The axle industry says......
10" brakes are standard on 3500# axles - certain applications possibly even up to 3900# depending on the brake.
4000# and larger axles typically run 12" brakes.
This is typically a function of spindle diameter and requirements by DOT.
A lot like shocks - Airstream does things a little different.
I do agree with Uwe that I would prefer the stopping power of the 12" brakes, well actually, I would prefer the stopping power of disc's.
Just my two cents,
Henry
Old 04-21-2006, 07:59 AM   #14
San Angelo , Texas
Images: 37
So if I were to go with discs (I'm assuming that there is a 12" rotor as well?), I'd have to get rid of the factory aluminum mags then, correct?
Frederic
Frederic
AIR # 8239
EX-WBCCI # 8371
Axles Axles Axles GeocamperAS Axles 33 11-20-2015 12:01 PM
Dexter Axles here with pics!! TN-TUNDRA Axles 27 11-23-2007 09:32 PM
Dexter axles - What I wanted & what I got LI Pets Axles 18 02-21-2007 01:53 AM
Dexter Axles librarylady Axles 10 04-19-2006 10:02 AM
