Old 03-29-2013, 11:09 AM   #15
1971 31' Excella 500
Anderson , South Carolina
Originally Posted by Inland RV Center, In View Post
Checking the axle alignment, takes 2 people and a good steel tape.
Measure from the very backside if the jack post, to the most forward lower part of the axle mounting plate.
That dimension should be "EXACTLY" the same.
Assuming that they are the same, then as long as you moved each axle, exactly the same, then you can be assured that the axles are in perfect alignment with the shell.
In the early 70's the axle mounting plates from one side to the other, were SOMETIMES welded 1/8", 1/4" or 3/8" off from one another.
That then means the holes from one side must to be changed to match the other side EXACTLY, in order for the axles to be in perfect alignment with the shell.
If that correction is not made, then the trailer will tow "dog legged", which in turn will cause unusual tire wear.
Any owner of an early 70's Airstream as well as an Argosy trailer should check their coach for proper alignment of the axles, by performing the above stated measurement.
It's an easy fix, but first a determination must be made.
Andy, are you talking about the rear stabilizing jack posts ?
Mrad7777 is offline   Reply With Quote
Old 03-29-2013, 11:35 AM   #16
No.
Reference was made to the lifting jack, that's mounted on the front of the A-frame.
Old 03-29-2013, 12:41 PM   #17
1976 31' Sovereign
Oswego , Illinois
When you stated early 70's does this include 76's, as I am getting ready to install new on 76 sover.
Old 03-29-2013, 01:42 PM   #18
Could be.
It only takes a few minutes to check it out.
Suitable vent lid replacement? louaxtjr Windows, Doors, Locks & Vents 6 05-16-2013 06:49 PM
Axle replacement Dan S All Argosy Trailers 46 04-27-2012 12:36 AM
1972 trade wind bathroom sink replacement treid Sinks, Showers & Toilets 2 04-01-2012 08:28 PM
1955 #0 7108 25' Tandem Axle Airstream Travel Camper Trailer VTG Restore Project eBay Watch Airstreams on eBay 0 03-16-2012 02:20 PM
