Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 09-20-2013, 07:42 AM   #21
1963 22' Safari
marine , Minnesota
Originally Posted by ventport View Post
leedr, Did you see this thread was from 2004?
I thought if the trailer was a 60's something the process wouldn't change much, I agree. Some times in the "heat of battle" the info is absorbed without considering the post dates. thanks for the heads up. I just ordered an axel from Andy and getting ready to install so it was discerning to see the botch job....thanks for the heads up. ...everything is so expensive I don't want to make a stupid mistake...Dan
leedr is offline   Reply With Quote
Old 09-20-2013, 02:46 PM   #22
Phoenix , Arizona
The process is still the same so the info is still applicable. By the way, the earlier poster that put a 3,500# axle under his low 2,200# trailer does make sense since rubber torsion axles start riding good once you get about 60% or more of the rated weight on them. Leaf springs aren't that forgiving. Many axle manufacturers won't supply you with a decent axle, hubs, bearings, and brakes until you get around the 3,500# capacity.
M2HB is offline   Reply With Quote
Old 09-20-2013, 04:27 PM   #23
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
9 years later, and I'm still happy with the 3500# Dexter on my Caravel. I didn't do the install myself though, I paid some pros to make it happen
Stephanie
Tag axle shock rdm Mechanics Corner - Engines, Transmission & More... 9 04-21-2020 10:57 AM
Duratorque Axle Replacement Andy R Axles 18 03-19-2017 08:54 PM
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-29-2009 07:52 AM
Who made my axle? Pahaska Axles 44 07-25-2007 10:08 AM
Axle Offset Question DanLyle Axles 11 08-28-2002 09:35 AM
