Old 09-22-2014, 02:50 PM   #1
2007 23' Safari SE
1972 25' Tradewind
St Cloud , Wisconsin
Dexter Axle
I recently acquired a 2007 23' Safari with dual axles. The Dexter owners manual says I have one of 3 options: Standard wheel bearing configuration, E-Z Lube, or Nev-R-Lube. Can you tell by looking at the outside what I have?
deer4200 is offline   Reply With Quote
Old 09-22-2014, 03:08 PM   #2
dznf0g's Avatar
Oswego , Illinois
No, If you pull the wheel off you MAY see a "Nev-r-lube" stamp on the dust cap. But look and see if the white label is still on one of the axle tubes. Take a photo of it and send to Dexter. They will return with all the specs on your axle.
-Rich-
Old 09-22-2014, 03:10 PM   #3
dznf0g's Avatar
Oswego , Illinois
I think, but am not sure, that Nev-r-lubes were standard only on Classics in 07. Not sure about EZ lubes. My guess is that you have standard bearings, unless PO ordered an option.
-Rich-
Old 09-22-2014, 03:42 PM   #4
2007 23' Safari SE
1972 25' Tradewind
Dexter Axle
Thanks, I crawled under the trailer and took this photo of nameplate.
Name:	name plate.jpg
Old 09-22-2014, 03:44 PM   #5
dznf0g's Avatar
Oswego , Illinois
That's it!
-Rich-
Old 09-22-2014, 04:08 PM   #6
There is only one way to be super sure.
Partially disassemble one hub & drum assembly.
Old 09-22-2014, 06:12 PM   #7
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Mine say Nev-R-Lube on the hubs.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 09-23-2014, 07:29 AM   #8
2007 23' Safari SE
1972 25' Tradewind
Thanks to all of you. I contacted Dexter Axle with the Dex#59058 and they responded quickly that it has standard bearings.
Dexter axle installation Inland RV Center, In Axles 22 09-20-2013 04:27 PM
Installing a new Dexter Axle Alumanutz Axles 23 08-21-2008 09:55 PM
Axle replacement - Dexter #10 w Disc brakes vs original FrenchBern Axles 27 05-22-2008 11:23 AM
Dexter Direct Bolt In Axle bikrmikey Axles 28 07-29-2006 10:16 AM
Dexter Axle Installation Started! Streamin 65 Axles 17 06-07-2006 04:02 PM
