Old 02-07-2012, 10:15 AM   #1
ASNomads's Avatar
1978 28' Ambassador
Byfield , Massachusetts
Curved Axles?!
Hi everybody,
The axles on my 1978 Ambassador are not straight and have a curve from one wheel to the other (see attached pictures).
Is this a sign of worn out axles as well? I read Andy's article from Inland RV regarding signs of worn out axles, however this "issue" is not mentioned in it, although I have seen it in a few vintage trailers.
Thanks for any advice.
Best,
Georgie
ASNomads is offline   Reply With Quote
Old 02-07-2012, 10:22 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
This is normal, not a bad sign.
Richard
Old 02-07-2012, 10:26 AM   #3
1971 29' Ambassador
Leonardtown , Maryland
Looks like someone jacked the trailer up from that point on the axle. I am not knowledgable enough to know what part that would play in your wheel alignment and tire wear.
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 02-07-2012, 10:27 AM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Kind of hard to tell from the pics (the first one is pretty blurred, too) but it looks more bent than curved to me. Like some put a jack under it and jacked up the trailer.
Vaughan
Old 02-07-2012, 10:35 AM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The factory bends the axles to give the proper amount of camber to the wheels. All torsion beam axles have this bend.
Old 02-07-2012, 10:44 AM   #6
WineStream's Avatar
2005 30' Safari
Pleasanton , California
Images: 24
This is normal. It is bowed from the factory. Most full-width trailer axles are bent this way whether they are torsion axles or not; Airstream or not.
WineStream is offline   Reply With Quote
Old 02-07-2012, 10:48 AM   #7
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I had a prospective buyer for one of my trailers tell me I must drove over somethin cause the axles were bent. I explained the real deal , but he was not biting. Sold it later to someone with a better brain.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 02-07-2012, 10:50 AM   #8
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
How does the torsion arm angle look on your axle when referencing the drawings in Andy's article?
Bud
Ridgerunner3 is offline   Reply With Quote
Old 02-07-2012, 11:02 AM   #9
ASNomads's Avatar
1978 28' Ambassador
Thanks to everybody for the quick replies!
@Ridgerunner3 the torsion arms still have a positive angle.
I'm thinking about replacing the axles in any case, since we will have to do a full shell off frame/floor repair and this would be the best opportunity to replace the axles as well and upgrading to disc brakes.
I was just wondering if this curve is stock or a wear issue
Best,
Georgie
Old 02-07-2012, 11:05 AM   #10
Originally Posted by ASNomads View Post
Hi everybody,
Best,
Georgie
Georgie.
The bend in the axles is normal.
That is how the axles are aligned, when manufactured.
You might check the position of the torsion arms as it appears they may have out lived their usefullness.
Old 02-07-2012, 12:51 PM   #11
1981 31' Excella II
New Market , Alabama
The bend is to keep the wheels vertical when under load. An axel will tend to bow under load and become U shaped. They put a bend in there so it actually bends itself straight. Solid axels are made this way as well. It is like a leaf spring in the other direction. It is bent with no load and flattens out under load.
Perry
Old 02-07-2012, 01:11 PM   #12
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The technical term is called "camber". When you take your TV in to have it aligned part of the process of alignment is to set the camber, caster and toe in to the specs for that vehicle.
On a trailer axle the camber is set to "full" and the toe in is "zero"
If you stand with your two big toes touching and your heals apart, it's toe in, if your heals are together and big toes apart it's toe out.
If you stand with your feet flat on the floor, then rock each ankle outward it's akin to "camber".
Does that make sense?
TG Twinkie is online now   Reply With Quote
Old 02-08-2012, 01:05 PM   #13
1977 23' Safari
1986 34' Limited
Idaho Falls , Idaho
Wow! Thanks! I had noticed the bend in the axles on our new-to-us '64 Overlander and had said nothing to my husband, thinking to delay the bad news of damaged axles, but now I don't have to worry. Whew, that's a load off for sure.
Vivian
Richard and Vivian
Caliban The Wonder Dog: gone but not forgotten
Cerberus
Too many vintage A/Ss...
Landshark is offline   Reply With Quote
Old 02-08-2012, 02:39 PM   #14
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
That makes complete sense to me. But then again, I been hitting thr bourbon. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Towing with Bad Axles CF Av8or Axles 15 02-11-2012 05:19 AM
I suspect it needs axles DKB_SATX Axles 22 04-26-2011 09:39 PM
