Old 05-31-2015, 03:52 PM   #1
kellykellyi's Avatar
1952 15' Cruisette
1967 20' Globetrotter
2010 19' International
La Caņada Flintridge , California
Cruisette Axel
I have '52 Cruisette with leaf springs and a straight axle. Currently working in a full frame off reno and am wondering if anyone has any suggestions or advice on replacing the axel? What is there is definitely not original. Should I change it to a torsion axle that Airstream says they will custom make for us or go with new leaf springs and a straight axle? Decision, decisions!
kellykellyi is offline   Reply With Quote
Old 06-03-2015, 01:44 PM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
It will be less cost and period correct to stick with leaf springs. Leaf spings will have an added benefit of having a longer service life and if you need to in the future the leaf spings are servicable independant of the axle. (NOt so with a torsion axle)
>>>>>>>>>>>>Action
Old 06-03-2015, 02:02 PM   #3
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
My 55 FC has a leaf spring axle which is clearly not original but I see no reason to switch to a torsion axle.
Mine is quite robust and a bit taller than the original, which gives me a bit more ground clearance :-)
BambiTex is offline   Reply With Quote
Cruisette :: 1951 Airstream Cruisette cruisette51 Airstream Registry Discussions 0 01-26-2014 02:13 PM
Axel ratio- need to discuss my rear end.... crazylev Tow Vehicles 21 12-30-2005 10:13 AM
controller for tag axel brake lorcaweb Classic Motorhomes 5 07-01-2005 09:32 AM
Tag Axel Brake Voltage / Amperage 87MH Mechanics Corner - Engines, Transmission & More... 1 11-11-2003 09:25 AM
