Old 10-06-2010, 10:38 AM   #1
1989 29' Excella
Seattle , Washington
Cost of new axles? W/ disk brakes?
What is the cost of swapping out the original axles for new ones (on a two axle unit), and is there any real advantage of converting to disk brakes at the same time?
Dan
Streamer Dan is offline   Reply With Quote
Old 10-06-2010, 12:29 PM   #2
Dan
Dan.
Disc brakes are many times superior to electric brakes, especially on a travel trailer.
More stopping power for the trailer, plus in case your TV brakes fail, that additional stopping power can be a saver.
They don't fade, and the cost of maintenance is less.
We cannot post a price on anything we sell. Sorry.
Old 10-07-2010, 06:48 AM   #3
1972 Travelux Princess 25
Cobourg , Ontario
What about trailers that are seldom used? Experience with car and truck brakes suggests disc brakes will get rusty and freeze up while drum brakes, being enclosed, will stay good much longer.
Size and weight would also be a factor. Drum brakes might be adequate on a small, older trailer that is not used a lot while a new, heavy model would need the discs.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 10-07-2010, 07:58 AM   #4
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
How much are the ones you don't sell and are yours more or less than that?
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 10-07-2010, 08:41 AM   #5
The ones we don't sell are free.
They are stacked in a dumpster.
The ones we do sell cost a little more than a dollar two ninety eight.
American money, that is.
Old 10-07-2010, 09:54 AM   #6
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I think that Dan is looking for some ballpark figures with which to base some decisions on.
The last time that i checked into a disc brake conversion for my 2005 Safari tandem axle, the cost was running around $2500. It could run a little less if you were replacing the axles at the same time. As far the advantage to going to discs, they supposedly stop the trailer a lot better.
A far as new axles go, I have no idea.
Brian
SuEllyn & Brian McCabe
Old 10-07-2010, 10:05 AM   #7
Brian
Brian.
The cost you estimated, is way way too high.
Old 10-07-2010, 10:48 AM   #8
1989 29' Excella
From a little bit of research I think new axles and disk brakes installed is gonna run about $3-3.5K, I've factored in about $1000 for labor as I think it's quite a long install time. Probably worth getting it all done at the same time.
Dan
Old 10-07-2010, 11:05 AM   #9
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Southwest Wheel Company
Old 10-12-2010, 07:09 PM   #10
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
It looks like the axles from Southwest Wheel have a max width of 80". If that is correct, the are too short for a 'Widebody" and maybe for a normal body Airstream?
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Vacuum Disk Brakes APB Brakes & Brake Controllers 22 09-03-2009 10:22 PM
Disk Brakes jfowler218 Brakes & Brake Controllers 3 01-05-2009 07:59 PM
Trailer Brakes - Drum to disk upgrade safarinight Brakes & Brake Controllers 26 07-17-2007 05:32 PM
disk brakes HubbyBear Member Introductions 2 04-03-2006 10:50 AM
Rotors for vacuum disk brakes wvmiller Brakes & Brake Controllers 4 10-21-2002 04:43 PM
