Old 05-22-2010, 04:54 AM   #1
muddy_hollow's Avatar
1965 20' Globetrotter
1956 22' Caravanner
Mendon , Massachusetts
Send a message via AIM to muddy_hollow Send a message via Yahoo to muddy_hollow
Converting axle underslung to overslung
On my Caravanner I replaced the axle with a new axis one and the clearance between the axle and the frame is not very much. It rides well but I noticed that during a really bumpy road that it grounded out (i.e. axle hit the belly pan).
Since this is a leaf spring suspension, what are the implications of converting it to an overslung configuration? Meaning, mount the axle under the leaf spring versus ontop as it is now...
Mud
56' Caravanner 'The Broomstick'
muddy_hollow is offline   Reply With Quote
Old 05-22-2010, 05:17 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Mud
I did this on a Boles Areo a few months ago. It worked quite well, though I wasn't able to reconnect the shock absorbers. You'll have to drill a hole for the locating pin through the top of the axle tube, and maneuver everything into place.
Old 05-22-2010, 06:56 AM   #3
1956 22' Caravanner
How much gained?
The axle is a straight axle with leaf spring perch welded on, so I figure I could just flip so the perch is positioned over the pin at the bottom side of the spring. How much height did you gain?
I'm a bit concerned about raising it to much.
As for shocks, I've got new spring plates with sock mounts welded on. I think I would need longer shocks.
I was also thinking of purchasing longer leaf spring shackles. Are there drawbacks to longer shackles?
Old 05-22-2010, 08:18 AM   #4
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
The longer the shackles,the more sway you will incur,ran many 50`s Chevys with the long shackles,looked cool,wouldn`t corner worth a da**. Dave
easyride is offline   Reply With Quote
Old 05-22-2010, 10:03 AM   #5
Images: 59
If you have a straight axle with 12" brakes, I don't think you can invert the axle because the mounting flange for the backing plate is a 5 hole design.
10" brakes may work because the flange is a 4 bolt pattern.
You could cut off the perches and weld them back on?
The rise you get will equal the thickness of the spring pack, plus the distance from the perch to the centerline of the axle.
You may need to buy a taller step.
Old 05-22-2010, 10:21 AM   #6
1956 22' Caravanner
Shackles
It's a funny thing, that without the perch on the axle I think there would be enough clearance to the frame. I saw the axle work on vintageairstream.com and he must have ordered his with the hole in the axle already as his doesn't have a perch..... Could the axle be drilled?
I thinking that putting the axle under the spring will make the trailer way to high so that leaves me with having longer shackles.
What about bump guards on the frame? Weld on some poly bump guards with the idea that if hitting a good sized bump that a guard would at least cushion it. Any thoughts on bump guards?
Old 05-22-2010, 10:29 AM   #7
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
Check with your trailer supply store. My local trailer supply place sells the perches separately, so I bought two and welded them on to move the axle and raise my trailer. Saves some labor and makes it easy to put it back the way it was.
Like markdoane says, some measurements will tell you exactly how much this will raise your trailer.
Sam
samb is offline   Reply With Quote
Old 05-22-2010, 11:55 AM   #8
Images: 59
I don't think it's a good idea to go without perches. Every time you apply the brakes the axle will transfer torque to the leaf springs. Kind of like torque wrap-up in reverse.
That will start to wallow out the hole you drill in the axle, or worse start to shear the head off the bolt that is holding your spring pack together. Might work ok for a couple of years.
Bumpers and longer shackles might get you enough clearance. Also, good shocks will prevent some bottoming out.
Old 05-22-2010, 12:28 PM   #9
JimW's Avatar
1997 30' Limited
Omaha , Nebraska
Mud, you stated you replaced the axle, but didn't say if you replaced the springs. Due to a broken spring on my 5 year old SOB, (which I sold today!) I ended up replacing all 4 springs. The new springs raised the trailer enough that I had to raise the ball on the hitch. The trailer sat 2 to 3 inches higher than before. I was amazed at how much the springs had settled in 5 years.
So my point is, would a new set of leaf springs give you the clearance you need?
Rig: '97 30' Limited
Towed by: '13 Silverado 2500 Duramax
WBCCI #22116
JimW is offline   Reply With Quote
Old 05-25-2010, 11:56 AM   #10
1956 22' Caravanner
Springs Redone
Yesterday I called over to Spring Rebuilders and dropped them off at lunchtime. Today they were ready and the guy said I should get 2-3 inches out of them!!!.. They replaced all the clamps and replaced the second leaf layer with a new one. They look great and much more sturdy than a week ago.
Waiting on my leaf plates to arrive, then taking them over to a Friends to stick weld the shock mounts. I'll post progress.
Old 05-25-2010, 03:19 PM   #11
Images: 59
You don't say what tires you have, but if you have bias tires and want to switch to radials, be sure you have enough clearance for the shocks when you weld on the new mounts.
I welded mine to the opposite side of the spring plate to gain enough clearance. The upper shock mount was moved to inside the frame
Old 05-25-2010, 03:28 PM   #12
1956 22' Caravanner
I've got bias tires and doubt I'll change to radials in the short term. The trailer had shocks originally, and the planned configuration is similar to how it was before. I did order taller shocks just in case I need them. The old ones are in good shape still.
Need to get this all wrapped up to field test it around town and then head out to the birthday bash at Bakers Acres.
Even ordered new vintage hubcaps today....
Old 05-26-2010, 03:47 PM   #13
1956 22' Caravanner
bolted together nice and smooth
After work last night I went over to the spring show and purchased new plates and shackles. Spent the evening grinding the shackles and fitting everything. Just need to purchase some new bolts for the shocks, but otherwise almost ready for tires.
I re-used the original shock mounts and bolted them to the leaf spring plate. This should do fine, as I upsized the u-bolts and leaf spring plate to 5/8" diameter u-bolts vs. 9/16". Pretty beefy.
I don't see it on other trailers but would a nylong bolt be good to spin?
Here are some pictures.
Old 05-26-2010, 03:58 PM   #14
1956 22' Caravanner
one more
Fron the side
Not converting to LP --- I'll try this DrPlay Generators & Solar Power 5 03-16-2009 10:31 PM
My Converter stopped converting thecatsandi Batteries, Univolts, Converters & Inverters 16 01-03-2008 10:05 AM
Converting double to twin davenpow General Interior Topics 10 12-30-2007 07:18 PM
Converting '64 Globetrotter to Caravanner everyman 1960 - 1964 Globetrotter 2 04-26-2007 07:44 PM
Converting to Bubble PoconoAir 1950-1955 Flying Cloud 27 02-05-2007 08:37 PM
