Old 06-01-2006, 03:39 PM   #1
AirstreamGypsy's Avatar
1961 16' Bambi
Mancos , Colorado
Send a message via Skype™ to AirstreamGypsy
Closing my Eyes, Crossing my Fingers and Ordering Axle
Well, I have read every post I could find on axles. In the end, since I knew I wasn't going to install them myself, I went to my local RV dealer/repair shop. These guys have been really good to me since I moved here three years ago and was living in the trailer while building my home.
So, here is what I am getting and you can all yell and scream if you want. But I had to do something!!!
(A good thing to since I had forgotten that on a trip almost a year ago I discovered loose lug nuts on one of my rims and it slightly damage the "bolts?".)
My Trailer - 1961 Bambi 13" - 4 lug/4 1/2" bolt pattern - with apparantly added later shocks.
What I am getting...
Dexter - 2300 lb. rated axle - 5 lug pattern - inset rims (it is what I have now) New brakes 10" . Keeping tires - 13" trailer steel radials C rating - Heritage - No shocks - Brackets to install with bolts as my axle is welded on.
Will give you the price after all is said and done but his estimate was good and I know they are honest and fair.
I'm pumped!
AirstreamGypsy
___________
Charter Member FCU WBCCI 1818 CP(Courtesy Parking) Wi-Fi
My Earthship
AirstreamGypsy is offline   Reply With Quote
Old 06-02-2006, 11:09 AM   #2
I'm pumped!
You will "ONLY" have two problems.
One, the brackets won't fit.
Two, you will shortly damage the axle, since 2300 pound rating is "grossly" under rated, plus, if it has a small spindle, you will shear one off, because of the under rating.
The axle, is by far, the most important part of an Airstream. Without them, you stay home. Lose an axle on the road, and grandma will spank you.
The early Bambi's and Caravels are all shearing the spindle's, because of what we know today, are too small, therefore they are fatigue cracking.
Yet in spite of warnings, some owners just don't want to hear it.
We replace at least one axle per week, for someone that has sheared a spindle, while traveling.
Then, of course, their trip becomes very unhappy.
Old 06-02-2006, 02:22 PM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Andy,
This Bambi, with about half provisions, has 2270 lbs on the axle (the scale reading--which includes the weight of the tires, drums, brakes, and wheels, which are not being supported by the axle, they're supported by the tires). Add 10 gals of water, 50 lbs food, 100 lbs camping gear, and maybe the occasional rider and you get about 350 lbs additional load, almost all of which would be on the axle, not the tongue. That's 2620 lbs. Then subtract the drums, wheels, and tires to get the maximum sprung weight--about 2500 lbs. The usual max (without a rider, would be under 2400 lbs). So maybe 2300 lbs is slightly under rated. To be grossly under rated, the spec would have to be off 25-33% or 600-800 lbs, or more.
Unless I don't correctly recall the other many axle posts I've seen, don't you advocate rating the axle at slightly less than the absolute maximum load expected? This gives a softer ride and, as I've seen you post elsewhere, a major objective is to reduce the stress/beating on the Airstream for the normally expected bumps, nes pa?
Now, considering that this is a 1961 and that that was the first year that Airstream used torsion axles, maybe they had a problem with the early ones, particularly the spindles. But this will be a modern axle that is rated for 2300 to 3000 lbs, where only the rubber rod length is varied to provide different load ratings. IMHO, the spindles are way tough enough if their design load is 3000 lbs.
Is it possible the scale that Airstrmgypsy used isn't accurate? Do you think the weight is way off?
Yes, the brackets will be different, particularly because this early Bambi has the axle welded on. I wonder if that is the original installation? Knowing this particular Bambi, I'd guess that it is original. Ooh, shame on Airstream!
Old 06-02-2006, 02:30 PM   #4
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
My trailer weighs 2800lbs loaded, it came with a 3000lb axel, and we replaced it with a 3500lb Dexter. We've been happy with the ride, despite the extra capacity (some indicated it would be too stiff, but it is a much better ride than the old worn out axel).
A 3000lb axel wasn't available at the time, Dexter only makes certain capacity axels and 3000lb wasn't an option. I don't know if that has changed.
Stephanie
Old 06-02-2006, 03:55 PM   #5
Axle ratings
Zeppelinium
The original axle on your trailer was rated at 3000 pounds.
By todays standards, we can also say what a piece of junk, GM, Chrysler and Ford built, back then.
Lets be fair and understand that something built 45 years ago, has certainly been improved upon since then.
All too often some owners ridicule Airstream for something they built 30, 40, 50, 60 and even over 70 years ago.
Airstream was a leader then and they have maintained that reputation ever since. Gosh do they build a perfect product? Heck no.
Back then Art Costello was asked why Airstream could not build a perfect product. His answer was, "I have written to JC to send me some perfect employees, but he hasn't answered my letter yet". Humor, yes, Serious, also yes.
Until such time as any manufacturer of anything can find perfect employees, products can and will have problems. We invented the "robots", but we still have problems.
Accordingly then it usually is not wise, as an individual to try to out engineer Airstream or for that matter, anyone else. It is far better to inquire, when there has been failures, to find out the what and why's regarding those failures. Following that up with how do we do it today, especially for the older models, and why, solves the problems.
To install a Dexter axle on an Airstream that is over or under rated is not the thing to do. For that matter, the same holds true for Henschen axles.
Bottom line, is, there are facts and figures that have been made available to us, by Henschen and Airstream, regarding the upgrading of axles as well as their ratings, and to "do not exceed" upper as well as lower limits.
That information was very carefully compiled many years ago. As a result, replacement axle ratings on many of the older models have been changed to further improve the performance of the suspension systems on the trailers.
Dexter indeed, does make good torsion axles. However, they will not build anything other than their standard ratings, which "seldom" are correct for an Airstream or Argosy trailers.
As a result, typically, using an Dexter axle will be an excessive or inadequate rating.
Axle ratings are very carefully compiled by a group of engineers, and not simply guessed at, as many owners may think.
Bottom line in your case, is anything "over" or "under" a 3000 pound rating, will not meet the approval of the engineers, nor will it stand the test of time.
That has been proven over and over again. We will not supply an axle other than 3000 pounds for any Bambi or Caravel built prior to 1969.
Guess work, for an torsion axle rating, has never been one of the formulas mathematical elements.
But, as always, to each his own. With the popularity of E-bay, all of can get rid of any nightmare that we may have created, on purpose, or otherwise.
It happens every day.
Unfortunately, current laws can't do much about fraud.
Old 06-02-2006, 04:27 PM   #6
1961 16' Bambi
Mancos , Colorado
Red face Ducking for cover
I called early this morning because I was so nervous. And yes, I was able to bump up the rating.
Yes, Dexter does make a 3000lb axle.
Soooooo, I'll let you know.
AirstreamGypsy
___________
My Earthship
Old 06-02-2006, 04:30 PM   #7
1961 16' Bambi
Mancos , Colorado
sorry Zep
I'm goin' with my trailer guy.
AirstreamGypsy
___________
My Earthship
Old 06-02-2006, 04:55 PM   #8
1961 16' Bambi
Mancos , Colorado
Thanks for you input Andy, but I am a bit confused by these two positions....
So let's just say there is no margin for the small trailers?
That has been proven over and over again. We will not supply an axle other than 3000 pounds for any Bambi or Caravel built prior to 1969....Andy
Your records show that you received two 3000 (three thousand) pound axles on July 10th, 2003.
Additionally, a single axle trailer cannot take a huge increase in weight ratings, unless, it will always be heavily loaded.
Henschen says no more that 3000 pounds for the small trailers. We did have a request for 3500 pounds for a small coach, and Henschen refused to build it.
They assure that it would cause a problem. Since they are the engineers, not me, I must respect their opinions.
see link below
http://www.airforums.com/forum...89-post26.html
AirstreamGypsy
___________
My Earthship
Old 06-02-2006, 05:10 PM   #9
see link below
Two entirely different years and lengths of Airstreams.
Old 06-02-2006, 05:25 PM   #10
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 36
My Head Hurts...
This always seems to happen when we start talking replacement axles.
Andy, just give a 40% discount to members of Airstream Forums, and that will solve everything.
Ken L
1966 Tradewind 24
2018 GMC Yukon XL Denali
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 06-02-2006, 05:44 PM   #11
Great idea.
Unfortunately, to stay in business today, especially California, there is that old saying that "you must make a porfit" or you will be like the old movie, "Gone with the wind".
We still are proud that we sell the Henschen products for considerably less than the Airstream factory.
Costs went up almost 20 percent, and we have still "held the line".
Maybe if we could get the feds to give us a subsidy. Yeah, right!!!
Maybe if we could reduce our overhead to zero? Never know.
Old 06-02-2006, 06:33 PM   #12
scf31's Avatar
1977 25' Caravanner
Jeffersonville , Kentucky
What is the date for the 40% off sale ????
Movie Stars and Film Crews come to Me from hundreds of miles enticed by My knowledge, My imagination,expertise, creativity and innovations!
scf31 is offline   Reply With Quote
Old 06-02-2006, 06:35 PM   #13
Alumaholic's Avatar
1966 24' Tradewind
Images: 36
Great idea.
Andy, I hope you know that I'm only jerking your chain, and when the time comes I will order my axles from you. I need a straight forward, remove and replace, guaranteed right the first time installation. So, I'll pay the price. Just let me get my damn building built.
Ken L
1966 Tradewind 24
Old 06-02-2006, 06:35 PM   #14
Septober 2006
