Old 07-08-2010, 05:53 PM   #21
2007 23' Safari SE
McCall , Idaho
Wheel Alignment in Boise area ???
Originally Posted by Jim Foster View Post
Andy's right on.
With a long straight edge resting against the back sidewall of both tires, it should just miss the front sidewall of both tires. When held against both sidewalls of the front tire, it should then miss the rear tire. That's one of the checks they made at Hewitt.
The above is a good check, but does not insure proper alignment. Camber must also be correct.
AND........A good shop will check proper alignment with the center of the hitch for proper tracking going down the road. The axles may be in alignment in relation to one another, but that does not mean that they are pointing the right direction with regard to the center line of the trailer. They could both be pointing slightly to the left or the right, in which case the rear end of the trailer will track a little to the left or right of center going down the road. Should not be a problem unless it is excessive, but it's just not correct.
Proper wheel alignment on a trailer is not as simple as some would think. Bending an axle in such a manner as to get tow-in, camber and tracking all correct takes real know how, and good equipment. In our case, two very experienced guys spent nearly three hours, not including the initial check which took nearly an hour. The check took that long because they wanted to know exactly how far the axles were out of line. They wanted the numbers.
from mobytrout, McCall ID
need to locate a shop that can align the front axle of my 2007 Safari SE 23ft (maybe rear axle too) RT front tire exhibits significant uneven wear on outer tread pattern. Called factory and closest on their list is Eugene OR. Called R&R wheel in Boise and they can't do it. Request forum members input as to "local" shops in my area.
mobytrout is offline   Reply With Quote
Is alignment needed on new axles? fitzjo1 Axles 14 01-24-2009 01:56 PM
'77 31footer, needs axles and floor repair. Price check? offgrid Trailer Values 9 05-28-2008 09:21 PM
Alignment - Axles Ganglin Axles 5 02-03-2007 11:22 AM
Any way to check wheel alignment? glacierrunne Axles 12 06-28-2006 08:10 AM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 10:54 AM
